Jacklim82 Neutral Newbie November 1, 2014 Share November 1, 2014 Anyone knows or is using hitachi car battery?So lucky my car no batt and get the onsite service.Ask them to provide amaron but when came say no amaron stock and use hitachi 40b19L. He claimed is as good as amaron.but no choice so take it.Anyone can advise. ↡ Advertisement Link to post Share on other sites More sharing options...
Ivanpaseo 2nd Gear November 1, 2014 Share November 1, 2014 http://en.wikipedia.org/wiki/Hitachi_Maxell#Batteries Maxell couldn't be bad Link to post Share on other sites More sharing options...
Roberttan 5th Gear November 19, 2014 Share November 19, 2014 Anyone knows or is using hitachi car battery? So lucky my car no batt and get the onsite service. Ask them to provide amaron but when came say no amaron stock and use hitachi 40b19L. He claimed is as good as amaron.but no choice so take it. Anyone can advise. had seen amaron battery terminal head got very bad corrosion till battery clamp gone Link to post Share on other sites More sharing options...
Kb27 Supersonic November 19, 2014 Share November 19, 2014 had seen amaron battery terminal head got very bad corrosion till battery clamp gone Imo, Amaron last too long to reach that state. Other battery failed long before corrosion even get a chance to start. And the main culprit I believe, is overtighening of the terminal. This causes stress in the plastic seal for the acid gas to escape and cause corrosion. Link to post Share on other sites More sharing options...
Tcx607 4th Gear November 19, 2014 Share November 19, 2014 Learned from my mechanic, just pour hot water on terminal if crystallize. Everything back to normal. Just hot water will do the job. Link to post Share on other sites More sharing options...
Roberttan 5th Gear November 20, 2014 Share November 20, 2014 Imo, Amaron last too long to reach that state. Other battery failed long before corrosion even get a chance to start. And the main culprit I believe, is overtighening of the terminal. This causes stress in the plastic seal for the acid gas to escape and cause corrosion. if what you said is truth, IMO Amaron should improve the Quality instead on blaming others. But honestly speaking hardly see battery got this kind of corrosion even on those batteries 2 to 5 years old yes pouring hot boiled water will help to remove those white powder, but if you do not do so when you see could be too late to know the clamp all eaten or broken Link to post Share on other sites More sharing options...
Jamesc Hypersonic November 20, 2014 Share November 20, 2014 Learned from my mechanic, just pour hot water on terminal if crystallize. Everything back to normal. Just hot water will do the job. And then put some petroleum jelly on it so it cannot corrode. If dun haf I think can try ky also. 2 Link to post Share on other sites More sharing options...
Lawrencekohsx Neutral Newbie December 26, 2014 Share December 26, 2014 Anyone knows or is using hitachi car battery? So lucky my car no batt and get the onsite service. Ask them to provide amaron but when came say no amaron stock and use hitachi 40b19L. He claimed is as good as amaron.but no choice so take it. Anyone can advise. Hi Jack, I had similar case about 9 to 10months ago. My car battery also die when i try to start in the morning when going to work. So i called up the onsite service from the internet and came with Hitachi MFX battery. There was no other choice as well. He also replaced my car with 40b19L on my Honda Jazz. Till date still serving well. I think anyhow, Jp battery on Jp car will be compatible. Hitachi also have their own factory in thailand and did a lot of OEM battery for car makers in Thai from what i heard through my workshop. So, sometimes it depend on luck as well. I had experience with a korean battery but died again barely 7month later. Link to post Share on other sites More sharing options...
Roberttan 5th Gear December 29, 2014 Share December 29, 2014 Hi Jack, I had similar case about 9 to 10months ago. My car battery also die when i try to start in the morning when going to work. So i called up the onsite service from the internet and came with Hitachi MFX battery. There was no other choice as well. He also replaced my car with 40b19L on my Honda Jazz. Till date still serving well. I think anyhow, Jp battery on Jp car will be compatible. Hitachi also have their own factory in thailand and did a lot of OEM battery for car makers in Thai from what i heard through my workshop. So, sometimes it depend on luck as well. I had experience with a korean battery but died again barely 7month later. is iti it is true that battery sometime is luck like anything I can only say average life span is plus minus 18 months Link to post Share on other sites More sharing options...
FastFixer February 17, 2015 Share February 17, 2015 Hi Jack, I had similar case about 9 to 10months ago. My car battery also die when i try to start in the morning when going to work. So i called up the onsite service from the internet and came with Hitachi MFX battery. There was no other choice as well. He also replaced my car with 40b19L on my Honda Jazz. Till date still serving well. I think anyhow, Jp battery on Jp car will be compatible. Hitachi also have their own factory in thailand and did a lot of OEM battery for car makers in Thai from what i heard through my workshop. So, sometimes it depend on luck as well. I had experience with a korean battery but died again barely 7month later. Hi Lawrence, What you say is so true - as with too many things in life - luck does play a part. Yet as some of the folks mentioned elsewhere in this thread, Amaron is better. We think so - and certainly the majority of the taxi companies (and the military) thinks so too. .. I'll say that luck has to do with the "probability of failure over a large number". And in this score, Amaron does well. One more suggestion I have for you is that when you call for battery service: Be clear and ask for Amaron (or any other brand you like/want. You are the customer and you have the right to your choice. This is what we believe at FastFix. We believe that everybody has the right to their choice and we work hard to be your choice. Feel free to visit us at www.fastfix.com.sg or our Facebook at www.facebook.com/FastFixRescue PS: We focus on Amaron batteries only. Do you know why? Amaron gives us our happiest customers and we get the least problem with Amaron batteries. :) Link to post Share on other sites More sharing options...
24hrsbatteryservices 1st Gear May 13, 2015 Share May 13, 2015 if anyone need help for car battery replacement can contact us at 91234455 http://www.mycarforum.com/topic/2698808-24-hr-car-battery-service-car-battery-replacement/ Link to post Share on other sites More sharing options...
Gauravsinghh12 Neutral Newbie May 19, 2015 Share May 19, 2015 Yes i'm using Hitachi Car battery, very good performance and cheaper in price. ↡ Advertisement Link to post Share on other sites More sharing options...
My EV journey to the i4
Battery Voltage up & down
2025 Mitsuoka M55
2025 Mitsuoka M55
