KARTer 2nd Gear July 10, 2011 Share July 10, 2011 I like to 'play' with the gas pedal and upshift gear although the car has an auto gearbox.... have you tried it?? ↡ Advertisement Link to post Share on other sites More sharing options...
D3badge 6th Gear July 10, 2011 Share July 10, 2011 I like to 'play' with the gas pedal and upshift gear although the car has an auto gearbox.... have you tried it?? release gas pedal, press clutch down, change gear, release clutch and press down gas pedal. No even when mine is a Manual Link to post Share on other sites More sharing options...
1fast1 Supersonic July 10, 2011 Share July 10, 2011 (edited) EDIT: Oh you meant upshift to save fuel (presumably). Sure, that'll work in most ATs - just feather the throttle. Edited July 10, 2011 by Turboflat4 Link to post Share on other sites More sharing options...
Jolie888 Clutched July 10, 2011 Share July 10, 2011 I like to 'play' with the gas pedal and upshift gear although the car has an auto gearbox.... have you tried it?? Yup, did that when I was running in my wife's car for her (for the first 1,000 km). This method quickens the upshifts (vs the car's normal auto upshift program) and allows one to keep RPMs to the minimum-possible ... especially while accelerating from zero. But I use this only for running-in automatic cars, including mine. Not for day-to-day driving. Link to post Share on other sites More sharing options...
Jolie888 Clutched July 10, 2011 Share July 10, 2011 A kickdown to force a downshift is a standard feature on almost every AT. I prefer a more hands-on approach - my Tiptronic 'minus' button. I find that releasing the gas pedal ever-so-gently, to initiate an upshift while accelerating, is more direct and quicker than relying on my wife's Audi Tiptronic (not the S-tronic/DSG, or multitronic/CVT), or my Merc's 7G-tronic ... or even my previous BMW's Steptronic. Somehow, I find that the automatic "xxx-tronics" of whichever marque, all have a bit of lag ... from the moment you downshift "-", to the time when the actuator actually shifts the gears. Link to post Share on other sites More sharing options...
1fast1 Supersonic July 10, 2011 Share July 10, 2011 (edited) I find that releasing the gas pedal ever-so-gently, to initiate an upshift while accelerating, is more direct and quicker than relying on my wife's Audi Tiptronic (not the S-tronic/DSG, or multitronic/CVT), or my Merc's 7G-tronic ... or even my previous BMW's Steptronic. Somehow, I find that the automatic "xxx-tronics" of whichever marque, all have a bit of lag ... from the moment you downshift "-", to the time when the actuator actually shifts the gears. Initially, I had misinterpreted TS's topic - I later realised he was talking about boring upshifts rather than fun downshifts, and edited my post accordingly. But going back to DOWNshifts, I find, at least for my Porsche, that just hitting '-' works almost instantaneously without perceptible lag, whereas a throttle kickdown is less efficient. So for instant overtaking power, I just hit minus on the steering and chiong. Maybe the Porsche manumatic is designed for better performance (quicker response), I dunno. Edited July 10, 2011 by Turboflat4 Link to post Share on other sites More sharing options...
KARTer 2nd Gear July 10, 2011 Author Share July 10, 2011 release gas pedal, press clutch down, change gear, release clutch and press down gas pedal. No even when mine is a Manual you joker... what i mean is 'manually' shifting an auto car's gear..... (there's no clutch) Link to post Share on other sites More sharing options...
KARTer 2nd Gear July 10, 2011 Author Share July 10, 2011 EDIT: Oh you meant upshift to save fuel (presumably). Sure, that'll work in most ATs - just feather the throttle. yes, if i m not in a hurry (ie dont need fast acceleration when the lights turn from red to green, for example), i will feather the throttle to make the upshift take place sooner and at lower rpm.... however, i m not sure if this will cause pre-mature wears and tears of the auto transmission setup Link to post Share on other sites More sharing options...
KARTer 2nd Gear July 10, 2011 Author Share July 10, 2011 (edited) Initially, I had misinterpreted TS's topic - I later realised he was talking about boring upshifts rather than fun downshifts, and edited my post accordingly. But going back to DOWNshifts, I find, at least for my Porsche, that just hitting '-' works almost instantaneously without perceptible lag, whereas a throttle kickdown is less efficient. So for instant overtaking power, I just hit minus on the steering and chiong. Maybe the Porsche manumatic is designed for better performance (quicker response), I dunno. talking about downshift/kickdown using an auto / semi-auto box, i find the simplest way is to floor the gas pedal and let the car's 'brain' do the rest..... in fact, i tried full auto vs triptonic mode tracking in the same far at Sepang and found the results not much of a difference although i feel in theory if we push the car real hard for hot laps, triptonic downshift/upshift should yield better lap times........... or it could be simply I am not up to it for track doesnt matter what gearbox the car uses Edited July 10, 2011 by KARTer Link to post Share on other sites More sharing options...
Throttle2 Supersonic July 10, 2011 Share July 10, 2011 EDIT: Oh you meant upshift to save fuel (presumably). Sure, that'll work in most ATs - just feather the throttle. dont do that , it tickles Link to post Share on other sites More sharing options...
1fast1 Supersonic July 10, 2011 Share July 10, 2011 talking about downshift/kickdown using an auto / semi-auto box, i find the simplest way is to floor the gas pedal and let the car's 'brain' do the rest..... in fact, i tried full auto vs triptonic mode tracking in the same far at Sepang and found the results not much of a difference although i feel in theory if we push the car real hard for hot laps, triptonic downshift/upshift should yield better lap times........... or it could be simply I am not up to it for track doesnt matter what gearbox the car uses Never driven an AT car on track, so dunno yet. But if I track my 911, I'll let you know. Link to post Share on other sites More sharing options...
1fast1 Supersonic July 10, 2011 Share July 10, 2011 dont do that , it tickles Would you say no to her and her feather duster? Link to post Share on other sites More sharing options...
Happily1986 5th Gear July 10, 2011 Share July 10, 2011 (edited) Would you say no to her and her feather duster? excellent match with a table wiper, aye? Edited July 10, 2011 by Happily1986 Link to post Share on other sites More sharing options...
D3badge 6th Gear July 10, 2011 Share July 10, 2011 you joker... what i mean is 'manually' shifting an auto car's gear..... (there's no clutch) I am just sharing shifting on my manual I just do the normal way Link to post Share on other sites More sharing options...
1fast1 Supersonic July 10, 2011 Share July 10, 2011 excellent match with a table wiper, aye? He wipes, and she dusts him down. Link to post Share on other sites More sharing options...
KARTer 2nd Gear July 10, 2011 Author Share July 10, 2011 Never driven an AT car on track, so dunno yet. But if I track my 911, I'll let you know. tomorrow i will up there.... hope you let your 911 stretch its 'legs' on track soon Link to post Share on other sites More sharing options...
1fast1 Supersonic July 10, 2011 Share July 10, 2011 tomorrow i will up there.... hope you let your 911 stretch its 'legs' on track soon Might go up with the P-club guys or Stuttgart, definitely not driving up alone. Safety in numbers. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear July 10, 2011 Share July 10, 2011 Auto gear...can control pedal to smoothen the upshift? Wow...u guys can feel when the upshift going to happen and then just split second ease up on the accelerator? I am impressed. I always let the auto gear box change without doing anything special with the pedal. ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding - March 2024
Xiaomi EV is Coming
Xiaomi EV is Coming
Cars at Expo - Apr 2024
