Keithchue 5th Gear March 19, 2010 Share March 19, 2010 bros, need help here, my steering wheel vibrates when i gently brake starting from 80-60, then it just disappears. this happens when even when i have driven for quite some time. beentold by my mechanic that it is ABS kicking in. but that does not happen when i pressed harder and braking from the same range of speed. ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 19, 2010 Share March 19, 2010 bros, need help here, my steering wheel vibrates when i gently brake starting from 80-60, then it just disappears. this happens when even when i have driven for quite some time. beentold by my mechanic that it is ABS kicking in. but that does not happen when i pressed harder and braking from the same range of speed. =========== If your car is older, Have the suspension & steering joints checked by a good mechanic. Likely something is lose or worn. Maybe a bushing, linkage or something. Link to post Share on other sites More sharing options...
Route88 2nd Gear March 19, 2010 Share March 19, 2010 Warp rotor ? Change rotor might help Link to post Share on other sites More sharing options...
Hermit 1st Gear March 19, 2010 Share March 19, 2010 warp rotor Link to post Share on other sites More sharing options...
Yuan 6th Gear March 19, 2010 Share March 19, 2010 Warp rotor ? Change rotor might help Symptoms look likely to be the case. Link to post Share on other sites More sharing options...
Audiorook Neutral Newbie March 19, 2010 Share March 19, 2010 very like warped rotor.. as what others have mentioned. Link to post Share on other sites More sharing options...
Metalbone Clutched March 19, 2010 Share March 19, 2010 yes wrap motor...happen to me too but I havent changed yet :P Link to post Share on other sites More sharing options...
Lekkie Neutral Newbie March 19, 2010 Share March 19, 2010 My rotor warp also like this, but it happened when apply brake at >100km/h. Warp rotor was caused by car wash, when just reach those car wash. They spray water at the wheel and cause the rotor to have sudden cool down. This cause the metal to warp, so now when I reach the petrol station will 1st top up, than go in shopping 5 to 10 min before going to car wash. And during car wash, do not apply parking brake, do not step on the brake also, just put to P and enjoy the wash. As if the brake is apply, the other part of the rotor was cool down by the water spray, but the part with the brake pad clamping still very hot. This will cause the rotor to warp more. Link to post Share on other sites More sharing options...
Extramint Clutched March 19, 2010 Share March 19, 2010 thanks for the heads up. gonna prove useful for some of us here Link to post Share on other sites More sharing options...
Keithchue 5th Gear March 19, 2010 Author Share March 19, 2010 in this case, how much is a pair of original rotors, for vios03? do i have to change rear ones as well Link to post Share on other sites More sharing options...
Yuan 6th Gear March 20, 2010 Share March 20, 2010 (edited) in this case, how much is a pair of original rotors, for vios03? do i have to change rear ones as well Should be no more than S$200. Go to stockist instead of ADs. Change those that are warped or need to be changed. If your rear ones are still alright to use and not warped, there is no need to change them. Edited March 20, 2010 by Yuan Link to post Share on other sites More sharing options...
Fcw75 Hypersonic March 20, 2010 Share March 20, 2010 Go for skimming first. Rotors can be skim once. Cheaper option. Link to post Share on other sites More sharing options...
Thelord Neutral Newbie March 20, 2010 Share March 20, 2010 (edited) in this case, how much is a pair of original rotors, for vios03? do i have to change rear ones as well I changed b4, $90 1 side for front OEM, exclude brake pads and labour. and dont skim, skim also need money, downtime and from what i heard, reduce braking power. top abit more can change brand new OEM. and then oh ya, rear ones no need to change, chances are the front only. Edited March 20, 2010 by Thelord Link to post Share on other sites More sharing options...
Keithchue 5th Gear March 20, 2010 Author Share March 20, 2010 i have asked my mechanic, he said that my rotors are fine. there is nothing wrong with it, evern skimming also do not need Link to post Share on other sites More sharing options...
Fcw75 Hypersonic March 20, 2010 Share March 20, 2010 So did your mechanic say why got such a problem? Link to post Share on other sites More sharing options...
Celicar Turbocharged March 20, 2010 Share March 20, 2010 My rotor warp also like this, but it happened when apply brake at >100km/h. Warp rotor was caused by car wash, when just reach those car wash. They spray water at the wheel and cause the rotor to have sudden cool down. This cause the metal to warp, so now when I reach the petrol station will 1st top up, than go in shopping 5 to 10 min before going to car wash. And during car wash, do not apply parking brake, do not step on the brake also, just put to P and enjoy the wash. As if the brake is apply, the other part of the rotor was cool down by the water spray, but the part with the brake pad clamping still very hot. This will cause the rotor to warp more. This is something new to me, that car wash can cause warping. So what's the difference between the "parking brake", which you say should not be applied, and putting to P? I'm missing something here. Link to post Share on other sites More sharing options...
Keithchue 5th Gear March 21, 2010 Author Share March 21, 2010 he asked me to go to his shop again to determine the actual cause. i have not been to his shop and was just asking around first to have a understanding Link to post Share on other sites More sharing options...
Fcw75 Hypersonic March 21, 2010 Share March 21, 2010 he asked me to go to his shop again to determine the actual cause. i have not been to his shop and was just asking around first to have a understanding He haven't even seen your car and yet he can tell you your rotors are fine? Awesome mechanic! Can recommend to me? ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding - March 2024
Xiaomi EV is Coming
Xiaomi EV is Coming
Cars at Expo - Apr 2024
Steering leather wrapping
