Bluepica 4th Gear August 6, 2011 Share August 6, 2011 What is the best way to hammer the little nails from the trunking to the wall? I have difficulties holding the tiny nails while hammering it into the wall. and most of the time, the nail will bend or only can go half way. :( ↡ Advertisement Link to post Share on other sites More sharing options...
Silver_blade Turbocharged August 6, 2011 Share August 6, 2011 Unfortunate, just need to practice hitting the nail head squarely, lighting tapping it at first before hitting it harder. You may use double sided tape to stick the trucking base onto the wall 1st and that should free your hands to concentrate on the nail. Link to post Share on other sites More sharing options...
Freestylers09 5th Gear August 6, 2011 Share August 6, 2011 1 pair of chopstick, or flat surface piece of things..or flat ice-cream stick place the nail inbetween ,u can tape behind the chopstick for more secure grip.. then just hammer,when inside abit liao..u can remove ur chopsticks and continue hammer ur nail in Link to post Share on other sites More sharing options...
Bystander50 5th Gear August 6, 2011 Share August 6, 2011 This is what i did for my home. Instead of hammering nails in, which will result in bent nails most of the time, just get wall plugs n drill them in, secure with screws. Next time during repainting, the trunkings can be removed. Or the simplest way is to use double sided tapes, but this method is not very secure. Link to post Share on other sites More sharing options...
West_end Neutral Newbie August 6, 2011 Share August 6, 2011 It's heartening to know each and every helpful soul here, offering their sincere advice. Link to post Share on other sites More sharing options...
5936 1st Gear August 6, 2011 Share August 6, 2011 You will need to get the nail rammer. Not sure if its the actual name. But that is the purpose. Cost $10-$20. some kit came with set of assorted nails. Need to use with proper wall nails with washers. Not too expensive. I knew because I also learnt the PAINFUL way Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged August 6, 2011 Share August 6, 2011 U using right nail? Link to post Share on other sites More sharing options...
Hotamp 3rd Gear August 6, 2011 Share August 6, 2011 U using right nail? There are different nails for different jobs......i think for wall trunking you need to use the small black ones ( harder), those use for wood are generally softer so tends to bend easier. dunno right or wrong, i went to the hardware store the uncle recommended me the black ones say for wall use. Link to post Share on other sites More sharing options...
Opel17 6th Gear August 6, 2011 Share August 6, 2011 Recently when OpenNet contractor install the wires in our unit, I observed that the trunking c/w double-sided tape for fixing, and then followed with black concrete nail. They used long-nose pliers to hold the nail during hammering. Link to post Share on other sites More sharing options...
David Clutched August 7, 2011 Share August 7, 2011 You will need to get the nail rammer. Not sure if its the actual name. But that is the purpose. Cost $10-$20. some kit came with set of assorted nails. Need to use with proper wall nails with washers. Not too expensive. I knew because I also learnt the PAINFUL way Where can I get this in SIngapore? Link to post Share on other sites More sharing options...
5936 1st Gear August 7, 2011 Share August 7, 2011 Most well stocked hardware stores. Link to post Share on other sites More sharing options...
Moredhel 2nd Gear August 7, 2011 Share August 7, 2011 Hmmz.... Mine was done using the auto-fit nails. The nails that comes with a plastic holder. Just drill the trunking with the wall, position the nails and then hammer it in. The double sided tape seems like a good idea for viewing alignment if one man job. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear August 8, 2011 Share August 8, 2011 If using double sided tape. Then just need minimum nails. Link to post Share on other sites More sharing options...
5936 1st Gear August 8, 2011 Share August 8, 2011 I drive in 3 nails on the stand full length trunking. Both ends and one at centre. Link to post Share on other sites More sharing options...
Rainman 1st Gear August 8, 2011 Share August 8, 2011 What is the best way to hammer the little nails from the trunking to the wall? I have difficulties holding the tiny nails while hammering it into the wall. and most of the time, the nail will bend or only can go half way. :( Best way is to get small hammer for small nails... If nail too small, hammer too heavy/big u will tend to pak jiao/pew chew Link to post Share on other sites More sharing options...
JohnnyChaiMingFeng Neutral Newbie November 24, 2014 Share November 24, 2014 Hi..where can I buy this nail gun? Link to post Share on other sites More sharing options...
Mustank Hypersonic November 24, 2014 Share November 24, 2014 Homefix Taobao Amazon Hardware shop Link to post Share on other sites More sharing options...
GLZT 6th Gear November 24, 2014 Share November 24, 2014 Just use those mounting tape can solve the issue. ↡ Advertisement Link to post Share on other sites More sharing options...
Simple home DIY repairs
Home Aircon
Home Aircon
Home renovation tips
House painting
House painting
