Forummer Neutral Newbie August 21, 2012 Share August 21, 2012 Hi I'm driving a almost 5 yr old jap car. Just now a few minutes after I started the car, my car's rpm dropped, went up and there was a slight jerk forward at a stationary position. My foot was still on brake pedal and gear in D mode. Any idea what happened? Pls advise. Thanks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
Snookium 1st Gear August 21, 2012 Share August 21, 2012 Some idling problem. Look out at throttle body or ur IACV Link to post Share on other sites More sharing options...
Kchew21 1st Gear August 21, 2012 Share August 21, 2012 Hi: Have u check or change the spark plugs? Link to post Share on other sites More sharing options...
MFIB Neutral Newbie August 21, 2012 Share August 21, 2012 it happen to me 2 wks ago, the mechanic had change the spark plug and cln the part called 'throttle' if i'm not wrong and the problem resolve. the thing they cln looks like the place where the air flows with flippers....sorry if u can't understand bcos i'm not familiar with car mechanical parts.... Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic August 21, 2012 Share August 21, 2012 its either the spark plug or the throttle too low, can set from engine Link to post Share on other sites More sharing options...
Elmo 4th Gear August 21, 2012 Share August 21, 2012 it happen to me 2 wks ago, the mechanic had change the spark plug and cln the part called 'throttle' if i'm not wrong and the problem resolve. the thing they cln looks like the place where the air flows with flippers....sorry if u can't understand bcos i'm not familiar with car mechanical parts.... That's the throttle body I think you are referring to. And the flippers are the butterfly valves. Link to post Share on other sites More sharing options...
Davidlim Neutral Newbie August 21, 2012 Share August 21, 2012 What's your car's mileage? It could be due to some slight wear with the engine mounting. I've personally experienced this on my 8-year old Sienta. Link to post Share on other sites More sharing options...
Jiex 2nd Gear August 21, 2012 Share August 21, 2012 try cleaning throttle body.. if problem still there and getting more serious, its probably time to replace engine mountings Link to post Share on other sites More sharing options...
Forummer Neutral Newbie August 21, 2012 Author Share August 21, 2012 I cleaned my throttle body about 6 months ago. My spark plugs were changed 20,000 km ago and they were iridium. Normally I use 98 Esso petrol so knocking is out. Link to post Share on other sites More sharing options...
Aj123 Neutral Newbie August 21, 2012 Share August 21, 2012 currently driving a Chevy and experience same issue. I manage to isolate my issue, as such it only happen when my aircon is on. if my aircon is off, no jerk at all. maybe u want to isolate the issue before heading to the right specialist. this is to avoid unnecessary cost. btw, I choose to live with it, for now. do share ur experience if u manage to get it resolved. Link to post Share on other sites More sharing options...
Happily1986 5th Gear August 21, 2012 Share August 21, 2012 Hi I'm driving a almost 5 yr old jap car. Just now a few minutes after I started the car, my car's rpm dropped, went up and there was a slight jerk forward at a stationary position. My foot was still on brake pedal and gear in D mode. Any idea what happened? Pls advise. Thanks in advance. I also feel it could be your idle control valve. Link to post Share on other sites More sharing options...
Edms Clutched September 2, 2012 Share September 2, 2012 send to wksp to clean ur throttle body, if problems still persist, mostly likely is ur idle valve Link to post Share on other sites More sharing options...
WolfT Neutral Newbie March 31, 2014 Share March 31, 2014 currently driving a Chevy and experience same issue. I manage to isolate my issue, as such it only happen when my aircon is on. if my aircon is off, no jerk at all. maybe u want to isolate the issue before heading to the right specialist. this is to avoid unnecessary cost. btw, I choose to live with it, for now. do share ur experience if u manage to get it resolved. Sorry to bring out an old thread. I face the same problem as above. Everytime my car is stationary, my rpm will drop a bit and car vibrates.This happen every 5-8seconds but when i switch off my air con,no more issue! Anyone experience before? Link to post Share on other sites More sharing options...
DMSG 3rd Gear April 1, 2014 Share April 1, 2014 Hi there, Check your throttle body, if it's dirty, have it cleaed. Check your ignition coil and ignition plugs and also your fuel sensor switches. Get your trusted workshop to do all these checks. It's small issues if as of above-mentioned. Cheers! Link to post Share on other sites More sharing options...
Badieboy 1st Gear April 1, 2014 Share April 1, 2014 clean throttle body plus the idle air control valve (IAC) Link to post Share on other sites More sharing options...
Ren2 1st Gear April 1, 2014 Share April 1, 2014 i also have the same problem. after servicing , car will jerk slightly when driving. also the car will vibrate prominently and then dissappear. i asked another mechanic to check he its just the aircon valve, wich i dont understand. how much wld a iac cost ? Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 1, 2014 Share April 1, 2014 i also have the same problem. after servicing , car will jerk slightly when driving. also the car will vibrate prominently and then dissappear. i asked another mechanic to check he its just the aircon valve, wich i dont understand. how much wld a iac cost ? If this problem started soon after u service yr car I wud n very careful of the ws that did the service. Either they r lousy n damage something or ty sabo yr car so ty can make more money repairing yr car. Many WS wil sabo customers cars to earn more n get more biz. This is quite common in SG n JB WS cos ty see customer dun know anything about his cars so ty just cheat them. Link to post Share on other sites More sharing options...
rongjiechung Neutral Newbie April 3, 2014 Share April 3, 2014 agreed. If this problem started soon after u service yr car I wud n very careful of the ws that did the service. Either they r lousy n damage something or ty sabo yr car so ty can make more money repairing yr car. Many WS wil sabo customers cars to earn more n get more biz. This is quite common in SG n JB WS cos ty see customer dun know anything about his cars so ty just cheat them. ↡ Advertisement Link to post Share on other sites More sharing options...
Radiator slight crack
Mercedes Benz A Class Gearbox Jerking Issues
Car slight jerk at idle and jerks when pressing throttle
25yr old man Jailed for threat to sell sex videos of ex-gf
Transmission gives a slight jerk when stationary
Ramky Carpark barrier dropped on my car
Light jerk in auto transmission going from 1st gear to 2nd
Why hasn't utility prices dropped?
