Johnnylim 5th Gear April 22, 2014 Share April 22, 2014 Whenever I washed my car every few weeks, I observed that the 2 front wheel rims always have oil stains whereas the 2 back rims only have normal dirt. Is it normal or something is leaking somewhere? ↡ Advertisement Link to post Share on other sites More sharing options...
Quantum 5th Gear April 22, 2014 Share April 22, 2014 Whenever I washed my car every few weeks, I observed that the 2 front wheel rims always have oil stains whereas the 2 back rims only have normal dirt. Is it normal or something is leaking somewhere? it's abnormal, most probably drive shaft cover broken, better quickly go workshop to check, if the greases splash on brake disc, it will reduce brake friction, what car are you driving? Link to post Share on other sites More sharing options...
Beregond Supersonic April 22, 2014 Share April 22, 2014 Whenever I washed my car every few weeks, I observed that the 2 front wheel rims always have oil stains whereas the 2 back rims only have normal dirt. Is it normal or something is leaking somewhere? If very stickly like grease high chance its your drive shaf boots break, if not should be brake hose leaking, oil leak quite easy to detect, Link to post Share on other sites More sharing options...
Johnnylim 5th Gear April 24, 2014 Author Share April 24, 2014 Whenever I washed my car every few weeks, I observed that the 2 front wheel rims always have oil stains whereas the 2 back rims only have normal dirt. Is it normal or something is leaking somewhere? This is what I meant. 1st pic is the front rim. Link to post Share on other sites More sharing options...
Crossangel Neutral Newbie April 24, 2014 Share April 24, 2014 better get it check.. Safety First.. Link to post Share on other sites More sharing options...
Ivanpaseo 2nd Gear April 24, 2014 Share April 24, 2014 could be your brake fluid leaking also... Link to post Share on other sites More sharing options...
TVT Supercharged April 24, 2014 Share April 24, 2014 If very stickly like grease high chance its your drive shaf boots break, if not should be brake hose leaking, oil leak quite easy to detect, I also thinking it is one of these 2. But higher chance is the brake fluid. TS need to open up the boot and check the brake fluid level. Link to post Share on other sites More sharing options...
TVT Supercharged April 24, 2014 Share April 24, 2014 This is what I meant. 1st pic is the front rim. Sorry OT a bit - what brand of tyre is this? Something "Chao.... Link to post Share on other sites More sharing options...
Johnnylim 5th Gear April 24, 2014 Author Share April 24, 2014 Sorry OT a bit - what brand of tyre is this? Something "Chao.... Dun worry, it's not Chao CB . It's Chao Yang, some China brand. It's ady there when I bought this 2nd hand car. Spore got few agents carrying it. Link to post Share on other sites More sharing options...
Quantum 5th Gear April 24, 2014 Share April 24, 2014 Dun worry, it's not Chao CB . It's Chao Yang, some China brand. It's ady there when I bought this 2nd hand car. Spore got few agents carrying it. your car is optra? Link to post Share on other sites More sharing options...
Johnnylim 5th Gear April 24, 2014 Author Share April 24, 2014 your car is optra? It's Aveo..... Link to post Share on other sites More sharing options...
Bornno1 1st Gear April 24, 2014 Share April 24, 2014 (edited) if there is thick lubricants or oil stains on the inner parts of the rims, driveshaft or cover absorber kaput, If rims just dusty then its just brake dust. because front brakes use more force so wear out faster Edited April 24, 2014 by Bornno1 Link to post Share on other sites More sharing options...
Alan39 Neutral Newbie April 24, 2014 Share April 24, 2014 Mostly likely is your drive shaft cover broken..If really drive shaft cover broken..Need to get it done fast..Else sand went inside your shaft..U need to spend more $$.. Can try to bend down and use a torchlight to see..Should be quite obvious to see broken shaft cover.. ↡ Advertisement Link to post Share on other sites More sharing options...
Does rims change shape/warp over time?
Washing machine front loading
