nizmo89 3rd Gear September 30, 2014 Share September 30, 2014 It happened before so what would u do if do if you are on the expressway and suddenly when u press brakes your car doesnt slow down at all? ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Hotshot85 4th Gear September 30, 2014 Share September 30, 2014 (edited) Use gears to downshift if manual, if not, even auto can engage lower gears to make use of engine brake. Keep hands on steering wheel and keep driving the car. When it has slowed down enough, just pull handbrake I guess? Edit: Assuming you aren't speeding when there's heavy traffic. Otherwise, good luck. Edited September 30, 2014 by Hotshot85 3 Link to post Share on other sites More sharing options...
Pms 3rd Gear September 30, 2014 Share September 30, 2014 Use handbrake. Notch by notch. Link to post Share on other sites More sharing options...
Vid Hypersonic September 30, 2014 Share September 30, 2014 Bump into the car in front. No choice. Then sue the car manufacturer and let insurance handle the damage. 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic September 30, 2014 Share September 30, 2014 (edited) Maybe Ris Low is in your car. "Boomz!" It happened before? So what was the cause? If one of the brake hose gave way, you still have 3 more. The most important ones are the front brakes. I believe the car is still able to gradually come to a stop. Edited September 30, 2014 by Watwheels 8 Link to post Share on other sites More sharing options...
Toothiewabbit Supersonic September 30, 2014 Share September 30, 2014 Punch through the floorboard with your legs and let your feet absorb all the frictional drag of the road until your car comes to a stop....oh yeahhhh!!! 4 Link to post Share on other sites More sharing options...
Watwheels Supersonic September 30, 2014 Share September 30, 2014 Punch through the floorboard with your legs and let your feet absorb all the frictional drag of the road until your car comes to a stop....oh yeahhhh!!! "Yabadabadoo!" 6 Link to post Share on other sites More sharing options...
nizmo89 3rd Gear September 30, 2014 Author Share September 30, 2014 Punch through the floorboard with your legs and let your feet absorb all the frictional drag of the road until your car comes to a stop....oh yeahhhh!!! lol ur shoes GG 2 Link to post Share on other sites More sharing options...
Dfx16 6th Gear September 30, 2014 Share September 30, 2014 (edited) It happened to me before, 1 of the brake hose give way U can feel spongy brake instantly when u tap brake and car arent slowing down as usual Signal left and try your best filter to road shoulder, pull over Go gentle with the brake and use handbrake at the same time Dont keep going heavy jamming the brake, u will lost even more braking effect as more oil being force out Last call your prefer mechanic to arrange for tow car, car never safe to drive without brake Edited September 30, 2014 by Dfx16 9 Link to post Share on other sites More sharing options...
2BDriver Hypersonic September 30, 2014 Share September 30, 2014 It happened before so what would u do if do if you are on the expressway and suddenly when u press brakes your car doesnt slow down at all? Down shifting to lowest gear for engine braking, switch on hazard lights and check blind spots for front and left clearance, immediately filter into road shoulder to display break down sign and call tow truck for assistance towing to workshop. 10 Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged September 30, 2014 Share September 30, 2014 If impossible to stop depending on scenario. find barrier, approach with a gentle angle to minimize damage to car. If have to crash to another car, use the full of the front and full of the rear of the other car. Increase surface area to minimize shock impact. Avoid dump trucks as dump trucks don't have bumper. The first contact point of dump truck to car will most probably be the windscreen already. If really have to hit dump truck, aim for one of the Tyres then the whole rear. How I got all these ideas? Because I did plan for in event of brake failure while driving a Toyota P/S, Just joking about the Toyota, it's more of a rental car. 3 Link to post Share on other sites More sharing options...
Nzy Twincharged September 30, 2014 Share September 30, 2014 (edited) Just downshift and use engine brake to slow down. Can slow down quite quickly then when at lower speed already start using the handbrake. Edited September 30, 2014 by Nzy 2 Link to post Share on other sites More sharing options...
Holdenutessv Turbocharged September 30, 2014 Share September 30, 2014 (edited) Downshift and use engine braking. If all else fails, just wind resistance. http://youtu.be/r6YBIHc0LAY?t=4m12s From 4:12 onwards... Edited September 30, 2014 by Holdenutessv 2 Link to post Share on other sites More sharing options...
Vega Turbocharged September 30, 2014 Share September 30, 2014 last resort, release your rear boot lid and use it as a air brake. Link to post Share on other sites More sharing options...
2BDriver Hypersonic September 30, 2014 Share September 30, 2014 last resort, release your rear boot lid and use it as a air brake. You have successfully given car manufacturers to launch new car with "Parachute Brakes" in the next 5 years in model renewal and sales development 3 Link to post Share on other sites More sharing options...
Super7 Turbocharged September 30, 2014 Share September 30, 2014 Bump into the car in front. No choice. Then sue the car manufacturer and let insurance handle the damage. Check first, in case in front is Ferrari, or SP1 number plate!! 1 Link to post Share on other sites More sharing options...
Vega Turbocharged September 30, 2014 Share September 30, 2014 You have successfully given car manufacturers to launch new car with "Parachute Brakes" in the next 5 years in model renewal and sales development this idea not new already lah. just that our boot lids are bigger and suppose to be more effective in braking. https://www.youtube.com/watch?v=mvfG_jEXosw 1 Link to post Share on other sites More sharing options...
Super7 Turbocharged September 30, 2014 Share September 30, 2014 You have successfully given car manufacturers to launch new car with "Parachute Brakes" in the next 5 years in model renewal and sales development Always put an anchor in car, now can throw it out to hook a big tree to stop the car? ↡ Advertisement Link to post Share on other sites More sharing options...
What is your favourite radio channel?
Gaps between cars when stationary!
FORCE Big Brake Kit promotional Price
Brakes specialist?
Brakes specialist?
