Owen_fan 2nd Gear October 1, 2014 Share October 1, 2014 Hi Anyone can advisse me can I connect my TV to an external audio system thru the TV Audio out (as shown below, whcih usually red & white connection) using a AUX cable? I can local AUX in from my audio system main unit. ↡ Advertisement Link to post Share on other sites More sharing options...
Adrianli Hypersonic October 1, 2014 Share October 1, 2014 Yes u can. Just get the converter wire where one end is the red/white RCA connector and the other end is the 3.5mm headphone jack. Link to post Share on other sites More sharing options...
Steptronic Supercharged October 1, 2014 Share October 1, 2014 By the way, if you want quality output, should use better cables like HDMI. Usual A/V would not be of good quality. Link to post Share on other sites More sharing options...
Adrianli Hypersonic October 1, 2014 Share October 1, 2014 By the way, if you want quality output, should use better cables like HDMI. Usual A/V would not be of good quality. Usual tv audio out no HDMI out. Only HDMI inputs. Link to post Share on other sites More sharing options...
ins1dious Turbocharged October 1, 2014 Share October 1, 2014 Usual tv audio out no HDMI out. Only HDMI inputs. Actually, specs for HDMI has provision for "audio return" since 2 years ago I think. But you will need an AV/Receiver to take advantage of that. Link to post Share on other sites More sharing options...
ins1dious Turbocharged October 1, 2014 Share October 1, 2014 Hi Anyone can advisse me can I connect my TV to an external audio system thru the TV Audio out (as shown below, whcih usually red & white connection) using a AUX cable? I can local AUX in from my audio system main unit. Which is your external audio system? What inputs does it take? What outputs does it have? There's cables for everything Link to post Share on other sites More sharing options...
Jtb 6th Gear October 1, 2014 Share October 1, 2014 Hi Anyone can advisse me can I connect my TV to an external audio system thru the TV Audio out (as shown below, whcih usually red & white connection) using a AUX cable? I can local AUX in from my audio system main unit. http://www.connector.com.sg/catalog_item/639214-1.jpg Link to post Share on other sites More sharing options...
Vid Hypersonic October 1, 2014 Share October 1, 2014 Hi Anyone can advisse me can I connect my TV to an external audio system thru the TV Audio out (as shown below, whcih usually red & white connection) using a AUX cable? I can local AUX in from my audio system main unit. Just search for 3.5mm jack to RCA audio output (red + white). Loads on the Internet. Link to post Share on other sites More sharing options...
Yslim79 4th Gear October 1, 2014 Share October 1, 2014 New TV models come with digital audio out (optical cable) for better sound quality... Link to post Share on other sites More sharing options...
Steptronic Supercharged October 1, 2014 Share October 1, 2014 My TV is about 5 years old and I had HDMI output connected to my A/V receiver. But, you are right, it depends on the TV model / spec. Usual tv audio out no HDMI out. Only HDMI inputs. Link to post Share on other sites More sharing options...
Zxcvb Turbocharged October 1, 2014 Share October 1, 2014 Hi Anyone can advisse me can I connect my TV to an external audio system thru the TV Audio out (as shown below, whcih usually red & white connection) using a AUX cable? I can local AUX in from my audio system main unit. Can you take a picture of your 1) TV's audio outputs. 2) Audio system aux input. There are many different TV and audio system with different connections. Usually if audio only for consumer products, it's usually RCA to RCA (red/white). For professional sound setups (clubs, bars, disco, recording studio, events), it's 1/4 inch or XLR cables. Link to post Share on other sites More sharing options...
Owen_fan 2nd Gear October 2, 2014 Author Share October 2, 2014 Hi Anyone can advisse me can I connect my TV to an external audio system thru the TV Audio out (as shown below, whcih usually red & white connection) using a AUX cable? I can local AUX in from my audio system main unit. Hi all, Thanks for all you advise:) Problem solved. I went to those computer shop at Sim Lim & they told me to get a AUX cable by connecting 1 end to the TV audio out, the other end to microphone in on my old CD audio system. It work prefectly. ↡ Advertisement Link to post Share on other sites More sharing options...
Kia Cerato speakers spoilt. Advise pls
Speaker Tan Chuan-Jin, MP Cheng Li Hui resign
Is a subwoofer necessary?
Wireless Portable Speaker For Home Entertainment System
Barack & Michelle Obama to speak at Expo this Dec
Volvo launches external airbag technology
