Charmaine12 3rd Gear November 19, 2014 Share November 19, 2014 HiJust went for a full service and noticed that coolant is at minimum level.Techician check and didnt discover any external leaks.. visual check.Today the coolant level drop again.Any idea what is the course and where can i get repaired ? ↡ Advertisement Link to post Share on other sites More sharing options...
ER-3682 Twincharged November 19, 2014 Share November 19, 2014 Ask mechanics do a "Pressure Test" to comfirm.. By the way,did they changed the coolant during the full servicing.? Link to post Share on other sites More sharing options...
Jtb 6th Gear November 19, 2014 Share November 19, 2014 Hi Just went for a full service and noticed that coolant is at minimum level. Techician check and didnt discover any external leaks.. visual check. Today the coolant level drop again. Any idea what is the course and where can i get repaired ? chk any leak after car is parked, chg new tank or hose.may leak during your drive so cant chk easily. Link to post Share on other sites More sharing options...
Charmaine12 3rd Gear November 19, 2014 Author Share November 19, 2014 Only top up coolant. I didnt see any coolant on the floor after overnight parking. Any recommended workshop with pressure test? Link to post Share on other sites More sharing options...
Jman888 Moderator November 20, 2014 Share November 20, 2014 Did you turn on heater in the car lately? The leak could be along the pipe to aircon, happened to mine where they can't find any leak until it drip on my feet. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged November 20, 2014 Share November 20, 2014 Hi Just went for a full service and noticed that coolant is at minimum level. Techician check and didnt discover any external leaks.. visual check. Today the coolant level drop again. Any idea what is the course and where can i get repaired ? i use this mechanic shop "tyre house" at Lorong ampass off balestier road. U google for their number n call the boss Lois ask them any idea what's going on. Link to post Share on other sites More sharing options...
Adrianli Hypersonic November 20, 2014 Share November 20, 2014 If no external leaks, most likely, internal leak. Head gasket is the main suspect. If too much coolant accumulate in the cylinder and u try to start the engine = engine piang. Better send car to workshop to check further. Link to post Share on other sites More sharing options...
Mustank Hypersonic November 20, 2014 Share November 20, 2014 Did you turn on heater in the car lately? The leak could be along the pipe to aircon, happened to mine where they can't find any leak until it drip on my feet. the exact same thing happened to me! Link to post Share on other sites More sharing options...
Yuan 6th Gear November 20, 2014 Share November 20, 2014 Hi Just went for a full service and noticed that coolant is at minimum level. Techician check and didnt discover any external leaks.. visual check. Today the coolant level drop again. Any idea what is the course and where can i get repaired ? What car you driving? Link to post Share on other sites More sharing options...
Adrianli Hypersonic November 20, 2014 Share November 20, 2014 What car you driving? I think its the Latio. See other thread. Link to post Share on other sites More sharing options...
Yuan 6th Gear November 20, 2014 Share November 20, 2014 I think its the Latio. See other thread. Then TS is advised to go workshop and check the car. Coolant dropping and topping it up from time to time is quite common for TC cars but not for NA vehicles. Even then for TC vehicles, it is not very often done. Link to post Share on other sites More sharing options...
Adrianli Hypersonic November 20, 2014 Share November 20, 2014 TS also disappear when it is resolved w/o informing the rest of what is actually rectified. http://www.mycarforum.com/topic/2696713-idle-and-died-off-at-traffic-light/?p=5335283 Link to post Share on other sites More sharing options...
Opel17 6th Gear November 20, 2014 Share November 20, 2014 TS also disappear when it is resolved w/o informing the rest of what is actually rectified. http://www.mycarforum.com/topic/2696713-idle-and-died-off-at-traffic-light/?p=5335283 It should be basic courtesy to update when the issue is resolved. Link to post Share on other sites More sharing options...
Charmaine12 3rd Gear November 20, 2014 Author Share November 20, 2014 Roger..will update the thread. As for this cAse.. likely to be head gasket gone. But it will be a big repair. So workshop advise to wash the radiator first.. (may solve the prob). Radiator was replaced as alot of the vents are choked up. Damaged 300. And cant guaranteed that problem will be solved. 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 20, 2014 Share November 20, 2014 Roger..will update the thread. As for this cAse.. likely to be head gasket gone. But it will be a big repair. So workshop advise to wash the radiator first.. (may solve the prob). Radiator was replaced as alot of the vents are choked up. Damaged 300. And cant guaranteed that problem will be solved. seriously your workshop is unprofessional. a pressure test is all it takes to know where the leaks come from. unless they dont have it then...... Link to post Share on other sites More sharing options...
Jamesc Hypersonic November 20, 2014 Share November 20, 2014 Hi Just went for a full service and noticed that coolant is at minimum level. Techician check and didnt discover any external leaks.. visual check. Today the coolant level drop again. Any idea what is the course and where can i get repaired ? Just check the engine oil if its milky then good news its not disapprearing, its just going into the engine. Your workshop is very good you always go there. Try to find a bad work shop that you never go to. 1 Link to post Share on other sites More sharing options...
Yuan 6th Gear November 20, 2014 Share November 20, 2014 Roger..will update the thread. As for this cAse.. likely to be head gasket gone. But it will be a big repair. So workshop advise to wash the radiator first.. (may solve the prob). Radiator was replaced as alot of the vents are choked up. Damaged 300. And cant guaranteed that problem will be solved. For the amount of work that is being done, i.e. replace radiator and fixing/cleaning up etc., the cost of S$300 is pretty much a bargain if you ask me. Link to post Share on other sites More sharing options...
Aaronlkl Supersonic November 20, 2014 Share November 20, 2014 Hi Just went for a full service and noticed that coolant is at minimum level. Techician check and didnt discover any external leaks.. visual check. Today the coolant level drop again. Any idea what is the course and where can i get repaired ? Did your car overheat before? Likely engine head gasket gone. Big job! ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Coolant question
Coolant question
S’pore Fitness Studio ‘Disappears’ Overnight With Website Deleted, Instructors & Members Uninformed. Kyklos Studio was previously known as X Fitness.
What is the purpose of coolant
WhatsApp to introduce disappearing messages
Coolant overflowing from expansion tank
Anti-Freeze or Coolant?
VW Sharan 'drinks coolant.?
