Mrmilktooth Supercharged December 19, 2014 Share December 19, 2014 How do you change gears. From 1 to 2....Juat interested to know how majority do it...From n to 1 to n to 2 and so on...Or from n to 1 to 2 to n to 3 and so on...If you drove paddles, or +/_ type. Then not applicable.. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Igto 2nd Gear December 19, 2014 Share December 19, 2014 for me, it is N to 1 to 2. 2 Link to post Share on other sites More sharing options...
Gnahp Supercharged December 19, 2014 Share December 19, 2014 Unless it is a sequential manual gearbox, the H pattern box will go pass neutral between gears, no? 1 Link to post Share on other sites More sharing options...
Zxcvb Turbocharged December 19, 2014 Share December 19, 2014 What kind of trick question is this?? Normally, N -1 - 2 - 3 - 4 - 5 - (6) if have sixth gear. When overtaking or "wanna play" mode, will drop from cruising gear (5) to (3) and rev it speed up acceleration. 1 Link to post Share on other sites More sharing options...
Kevin613 1st Gear December 19, 2014 Share December 19, 2014 1-2-3-4-5, i dont go neutral unless i'm having a long wait at traffic light. 1 Link to post Share on other sites More sharing options...
Xers007 Supercharged December 19, 2014 Share December 19, 2014 Unless it is a sequential manual gearbox, the H pattern box will go pass neutral between gears, no? i think what he meant is to pause a while at N before shifting to other gear... but when i drive manual, i will not pause at N but just shift straight to next gear.. 2 Link to post Share on other sites More sharing options...
Naimed 5th Gear December 19, 2014 Share December 19, 2014 Too tedious to go N-1-N-2-N-3-N-4...during your daily drive to rev match/double clutch everytime you down shift. In Singapore's driving condition, just relac drive la. 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic December 19, 2014 Share December 19, 2014 Unless it is a sequential manual gearbox, the H pattern box will go pass neutral between gears, no? You have to. It's designed to be so. 1 Link to post Share on other sites More sharing options...
Mrmilktooth Supercharged December 19, 2014 Author Share December 19, 2014 Haha... So easy to misread my question... From starting pt. Always at n. When u change gear n to 1. Then do you go to n then to 2 or st from 1 to 2.. My dad thought me to do 1 to n to 2.. But I lazy to do so.. Means more time spend to change gear.. It does not mean letting car go to neutral... For gears 3,4,5 all Wil pass through n ma.. If u realise.. Haha.. Just a though Link to post Share on other sites More sharing options...
Albeniz Turbocharged December 19, 2014 Share December 19, 2014 If the car is starting from stand still, then it is in sequence from N->1->2->3->4->5 If the car still has some momentum, instead of going from N to 1, I go straight from N to 2. During slowing down, I usually put the gear from 5 to N and then when the speed becomes significantly slower, change from N to 3, i.e. 5->N->3. Link to post Share on other sites More sharing options...
Jamesc Hypersonic December 19, 2014 Share December 19, 2014 Haha... So easy to misread my question... From starting pt. Always at n. When u change gear n to 1. Then do you go to n then to 2 or st from 1 to 2.. My dad thought me to do 1 to n to 2.. But I lazy to do so.. Means more time spend to change gear.. It does not mean letting car go to neutral... For gears 3,4,5 all Wil pass through n ma.. If u realise.. Haha.. Just a though You dad is correct. But only for very old cars from the 60s and 70s when there is no synchromesh or for cars that the synchromesh is spoilt. For new cars with perfectly good synchromesh no need. But matching engine revs to road speed is a must. 4 Link to post Share on other sites More sharing options...
Badieboy 1st Gear December 19, 2014 Share December 19, 2014 Of course is 1-2 la, do 1-N-2 for what? Got benefits meh? Link to post Share on other sites More sharing options...
Jamesc Hypersonic December 19, 2014 Share December 19, 2014 Should ask your dad why he goes to n and maybe he will tell you when he learn to drive this is what he was taught. Link to post Share on other sites More sharing options...
Mrmilktooth Supercharged December 19, 2014 Author Share December 19, 2014 i think what he meant is to pause a while at N before shifting to other gear... but when i drive manual, i will not pause at N but just shift straight to next gear.. you got the point!!!... not pause.. but go through the step only.. all gear change have to go through Pt. N ma... [sweatdrop] im not overthinking and doing rev match upshift/ downshift.. even from 5 to 3 you also pass to Pt. N.. getit??.. so seems like most of you go from 1 to 2 sttraight since its a st line down.. and not 1 to N to 2.. cos need to go through 2 "Ls" not trying to confuse you .. 1 LN _ | 2 Link to post Share on other sites More sharing options...
Mockngbrd Supersonic December 19, 2014 Share December 19, 2014 It depends on your gearbox. Link to post Share on other sites More sharing options...
Mrmilktooth Supercharged December 19, 2014 Author Share December 19, 2014 You dad is correct. But only for very old cars from the 60s and 70s when there is no synchromesh or for cars that the synchromesh is spoilt. For new cars with perfectly good synchromesh no need. But matching engine revs to road speed is a must. i guess this is the best answer.. u must be from that era.. 1 Link to post Share on other sites More sharing options...
Xers007 Supercharged December 19, 2014 Share December 19, 2014 (edited) you got the point!!!... not pause.. but go through the step only.. all gear change have to go through Pt. N ma... [sweatdrop] im not overthinking and doing rev match upshift/ downshift.. even from 5 to 3 you also pass to Pt. N.. getit??.. so seems like most of you go from 1 to 2 sttraight since its a st line down.. and not 1 to N to 2.. cos need to go through 2 "Ls" not trying to confuse you .. 1 LN _ | 2 I think manual gear box is something like below... even a straight line down from 1 to 2 it will pass thru N ... N is not only between 3rd and 4th gear when ur hand release the gear stick where it will spring back to... 1 3 5 NNNNNNN >>>> this space is consider N 2 4 R Edited December 19, 2014 by Xers007 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic December 19, 2014 Share December 19, 2014 i guess this is the best answer.. u must be from that era.. Mmmm between you and me yes. If there are any syts listening I am a much younger man. ↡ Advertisement Link to post Share on other sites More sharing options...
Grab feature pairing women drivers with women passengers
Singapore Reckless Drivers Part XIV
BMW M Cars Are Done With DCTs, and Soon, Manuals Too
Looking for a manual car because real men use three pedals!
