Char 5th Gear January 24, 2015 Share January 24, 2015 My coolant tank was empty and found stain on the floor . Any opinion on my problem ? What should I do ? Can add water into the coolant tank ? ↡ Advertisement Link to post Share on other sites More sharing options...
lausai88 Hypersonic January 24, 2015 Share January 24, 2015 looks like there is a leak, you can add water but will empty again Link to post Share on other sites More sharing options...
Volvobrick Supersonic January 24, 2015 Share January 24, 2015 Add water, drive to workshop to fix. Could be hose, clamps, radiator or pump gasket etc. 2 Link to post Share on other sites More sharing options...
Char 5th Gear January 24, 2015 Author Share January 24, 2015 Thanks for the feedback .... I am stay in Jurong West area and any recommend workshop which open on Sunday ? Link to post Share on other sites More sharing options...
Ken1898 1st Gear January 24, 2015 Share January 24, 2015 Thanks for the feedback .... I am stay in Jurong West area and any recommend workshop which open on Sunday ? Stamford Tyres @ Lokyang Link to post Share on other sites More sharing options...
Fcw75 Hypersonic January 24, 2015 Share January 24, 2015 Don't drive already. Tow it to workshop. 1 Link to post Share on other sites More sharing options...
Char 5th Gear January 24, 2015 Author Share January 24, 2015 How to know if the engine is going to over heat ? I am driving Latio . Link to post Share on other sites More sharing options...
Cauldron 6th Gear January 24, 2015 Share January 24, 2015 I had this problem recently. Cooling fan broke down, aircon starts getting less cool. When i park and turn off the car, one of the hose feeding the coolant back to the radiator burst and coolant gushed out, fortunately no one was near the splash area. Topped up water and drive to work shop, but continue to monitor temperature. When it gets too hot, stop at road side. After repairs, the engine does seems to have some issue. The heat build up could leave a permanent damage to the engine etc. Better to tow in to workshop. Topping up water is a stop gap measure only as you do not know the extend of the leak. Hope it helps 2 Link to post Share on other sites More sharing options...
Sdexxxxd 2nd Gear January 24, 2015 Share January 24, 2015 My coolant tank was empty and found stain on the floor . Any opinion on my problem ? What should I do ? Can add water into the coolant tank ? I had same problem 3 weeks ago. Had to top up water and coolant continuously. In the end went to repair at the Caltex petrol station in Braddel CTE exit towards Bishan. Not sure if they open on sundays. 1 Link to post Share on other sites More sharing options...
Char 5th Gear January 25, 2015 Author Share January 25, 2015 One day can be done ? Link to post Share on other sites More sharing options...
Matrix0405 5th Gear January 25, 2015 Share January 25, 2015 One day can be done ? Just add tap water into the water tank and radiation when the car is cool. If car has 1 yr left, just top up with water regularly and monitor how long does it last to empty. More than 1 yr, consider to repair. 1 Link to post Share on other sites More sharing options...
Char 5th Gear January 25, 2015 Author Share January 25, 2015 Left 16 months and just wait to change car when COE at acceptable level . I just drove for 15km and just switch off the engine while waiting the traffic light .... So far I can see some leakage from the side . Link to post Share on other sites More sharing options...
Matrix0405 5th Gear January 25, 2015 Share January 25, 2015 Can the water level last for a day? If you don drive is it still leaking? Link to post Share on other sites More sharing options...
Sdexxxxd 2nd Gear January 25, 2015 Share January 25, 2015 One day can be done ? depend on where is the leak... mine is the top plastic part...got ex stock so only 2 hours job... Link to post Share on other sites More sharing options...
Char 5th Gear January 25, 2015 Author Share January 25, 2015 Will monitor first .... So far the water level seem lower a bit . Link to post Share on other sites More sharing options...
Ckchong8 1st Gear January 25, 2015 Share January 25, 2015 If leaking too rapid, possible that the casket on the engine block burnt. Need to change , not advisable to drive n topup as there still 16 months. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic January 25, 2015 Share January 25, 2015 16 mths is not a short time. U want to check and topup every 2 days? What's the point? Then if you forgot and the engine is damaged, how? Don't be penny wise pound foolish. 2 Link to post Share on other sites More sharing options...
Char 5th Gear January 25, 2015 Author Share January 25, 2015 plastic top crack need to change tank and cost $340 at wcega plaza autowheels motorworks two hours job . ↡ Advertisement Link to post Share on other sites More sharing options...
2021 3rd Generation Nissan Note (E13)
Nissan QashQai 2014 Part 2
Nissan Teana Experience
2023 Tan Chong Car Challenge
2018 Nissan Serena e-POWER
