Bluepica 4th Gear April 19, 2015 Share April 19, 2015 Went for 2nd tire rotation after 20kInner wall all "eaten" up. Suggest to go alignmentWent and done... Results as shown. Question: why after alignment still got Red for camber? Seriously I wonder why I didn't take note when he pass the results to me after I asked for it... ↡ Advertisement Link to post Share on other sites More sharing options...
Mkl22 Twincharged April 19, 2015 Share April 19, 2015 Looks good. Just ignore the red for the rear camber. It's fine Link to post Share on other sites More sharing options...
Fuelsaver Supercharged April 19, 2015 Share April 19, 2015 Went for 2nd tire rotation after 20k Inner wall all "eaten" up. Suggest to go alignment Went and done... Results as shown. Question: why after alignment still got Red for camber? Seriously I wonder why I didn't take note when he pass the results to me after I asked for it... Ur is torsion beam or independent suspension at rear. If latter, tie rod can b adjusted for correct camber. Link to post Share on other sites More sharing options...
Enye Hypersonic April 19, 2015 Share April 19, 2015 Ts, did you lower your car? Link to post Share on other sites More sharing options...
Ivanpaseo 2nd Gear April 19, 2015 Share April 19, 2015 camber looks normal to me on front and rear within specs. ignore red. Link to post Share on other sites More sharing options...
Leroyluo85 1st Gear April 19, 2015 Share April 19, 2015 Are u on lowering spring? If so, maybe this is the best camber until u install camber kit/bolt Link to post Share on other sites More sharing options...
Bluepica 4th Gear April 20, 2015 Author Share April 20, 2015 ok...thanks all... thought I need to go back and rectify the red color... everything stock... Link to post Share on other sites More sharing options...
Fuelsaver Supercharged April 22, 2015 Share April 22, 2015 ok...thanks all... thought I need to go back and rectify the red color... everything stock...Now that I've compared ur readings, I think Alignment shop didn't adjust ur camber at all, wc I think they should. Link to post Share on other sites More sharing options...
Kb27 Supersonic April 22, 2015 Share April 22, 2015 ok...thanks all... thought I need to go back and rectify the red color... everything stock... Your car camber cannot be adjusted, so it's not done. The only thing they do is probably the toe. Excessive toe is usually the case that eats your tyre, generally not camber problem. Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged April 23, 2015 Share April 23, 2015 ok...thanks all... thought I need to go back and rectify the red color... everything stock... Very good overall specs already and I am actually impress how they manage to even out the camber on the rear when it cannot be adjusted. Reason being red, the factory specs at 1.3 while the actual is 1.4. Even adjust till 1.31 also be in red. 0.1 difference is very very minor. My favorite place to test alignment, MCE lane 1 from Keppel to KPE. If you can travel at 100km/hr, drive straight & hands off steering wheel, the car go stays within lane for 10 secs & steering wheel never move = very good job. 1 Link to post Share on other sites More sharing options...
Knoobie Supercharged April 23, 2015 Share April 23, 2015 Very good overall specs already and I am actually impress how they manage to even out the camber on the rear when it cannot be adjusted. Reason being red, the factory specs at 1.3 while the actual is 1.4. Even adjust till 1.31 also be in red. 0.1 difference is very very minor. My favorite place to test alignment, MCE lane 1 from Keppel to KPE. If you can travel at 100km/hr, drive straight & hands off steering wheel, the car go stays within lane for 10 secs & steering wheel never move = very good job. remember to smile and say cheeesssseeee!!!!! you can throw in a pieee after the flash! Link to post Share on other sites More sharing options...
Johnnylim 5th Gear April 23, 2015 Share April 23, 2015 remember to smile and say cheeesssseeee!!!!! you can throw in a pieee after the flash! He probably knows where the cameras are located for the 10secs testing ↡ Advertisement Link to post Share on other sites More sharing options...
Crash test results
Crash test results
Any recommended tyre shop
A level results for University Courses
O level results coming out soon!
Do I need to change tire ?
Used Truck / tractor tires.
