Kezg 1st Gear November 25, 2015 Share November 25, 2015 Dear Forummers Can anyone teach/show me how to dismantle this burner so that I can get a replacement....as can see from the pic..the rim is warp...Thank you in advance ↡ Advertisement Link to post Share on other sites More sharing options...
Pinobii Hypersonic November 25, 2015 Share November 25, 2015 Just lift up? But not sure if you would be able to get a replacement What brand is this? Link to post Share on other sites More sharing options...
Kezg 1st Gear November 25, 2015 Author Share November 25, 2015 Just lift up? But not sure if you would be able to get a replacement What brand is this? its a Turbo brand....I have tried but the rim is not moving at all....??? Link to post Share on other sites More sharing options...
Adrianli Hypersonic November 25, 2015 Share November 25, 2015 See the steps I indicated in the photo. U never clean your stove before? I usually will remove everything to wash and clean, including the knob!!! U will need to go back to the maker to get the same type of burner. Link to post Share on other sites More sharing options...
BanCoe Hypersonic November 25, 2015 Share November 25, 2015 (edited) See the steps I indicated in the photo. U never clean your stove before? I usually will remove everything to wash and clean, including the knob!!! U will need to go back to the maker to get the same type of burner. post-17481-0-27315600-1448438749.jpg Maybe part 2 already jammed into another one more flat disc like thingy so badly that it cannot move; Wow ! 1st time i see anything until like this. TS must be having a factory of somekind at home; Usually I take out all the 2 or 3 inner ones and scrub and put in sun from time to time; the small centre one is usually made of brass the others of some kind of steel (when new very nice nice chromed; but when old - like that lah!) Edited November 25, 2015 by BanCoe 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic November 25, 2015 Share November 25, 2015 Maybe part 2 already jammed into another one more flat disc like thingy so badly that it cannot move; Wow ! 1st time i see anything until like this. TS must be having a factory of somekind at home; Usually I take out all the 2 or 3 inner ones and scrub and put in sun from time to time; the small centre one is usually made of brass the others of some kind of steel (when new very nice nice chromed; but when old - like that lah!) Mine part 2 and 3 are made of cast iron. I will wash everything if we have been frying stuff. Inside always very oily. Need to strip it completely to clean. If stuck, use a flat screwdriver and hammer to prise them apart. Since already spoilt, so "hard hard come". Link to post Share on other sites More sharing options...
Kangadrool Supersonic November 25, 2015 Share November 25, 2015 spray WD-40. Dear Forummers Can anyone teach/show me how to dismantle this burner so that I can get a replacement....as can see from the pic..the rim is warp...Thank you in advance Link to post Share on other sites More sharing options...
nazerath Turbocharged November 25, 2015 Share November 25, 2015 (edited) How come the ring will crack? I did you try to lift the base together? Clearer pics from the top? Without the support. Edited November 25, 2015 by nazerath 3 Link to post Share on other sites More sharing options...
Kezg 1st Gear November 25, 2015 Author Share November 25, 2015 Maybe part 2 already jammed into another one more flat disc like thingy so badly that it cannot move; Wow ! 1st time i see anything until like this. TS must be having a factory of somekind at home; Usually I take out all the 2 or 3 inner ones and scrub and put in sun from time to time; the small centre one is usually made of brass the others of some kind of steel (when new very nice nice chromed; but when old - like that lah!) ...previous heavy cooking for many hours( bak chang)...then become like that so now thought of replacing...I have enquired from a shop, they said have to go to agent somewhere at changi area to get spare parts.... See the steps I indicated in the photo. U never clean your stove before? I usually will remove everything to wash and clean, including the knob!!! U will need to go back to the maker to get the same type of burner. post-17481-0-27315600-1448438749.jpg thanks ..will try out again Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear November 25, 2015 Share November 25, 2015 ...previous heavy cooking for many hours( bak chang)...then become like that so now thought of replacing...I have enquired from a shop, they said have to go to agent somewhere at changi area to get spare parts.... thanks ..will try out again Kezg, From the photo, unable to tell which model. Have a look at this, and see if it is useful for you. http://www.hoekee.com.sg/uploads/T6219SS-T7529SS_ml.pdf Not sure if you tried calling hoekee. http://www.hoekee.com.sg/contact_us.php Main Branch Tel: (65) 6749 4521 Opening Hours: Daily from 10 AM - 6 PM IMM Showroom Tel: 6563 5088 Opening Hours: Daily from 11 AM - 9 PM Hoe Kee Superstore Tel: 6392 9909 Opening Hours: Daily from 10 AM - 7 PM Tajong Katong Showroom Tel: 6745 7055 Opening Hours: Mon - Fri 12 pm - 9 pm Saturday 11 am - 9 pm Sun & PH 10 am - 8 pm Kaki Bukit Showroom Tel: 6745 3839 Opening Hours: Mon-Sat from 9 am - 6 pm Sun & PH from 10 am - 6.30pm 2 Link to post Share on other sites More sharing options...
Voodooman Supersonic November 25, 2015 Share November 25, 2015 ...previous heavy cooking for many hours( bak chang)...then become like that so now thought of replacing...I have enquired from a shop, they said have to go to agent somewhere at changi area to get spare parts.... thanks ..will try out again Happiness is the agent for Turbo products in Singapore. http://www.happiness.com.sg/contactus.htm Link to post Share on other sites More sharing options...
Count-Bracula Twincharged November 25, 2015 Share November 25, 2015 Sorry TS, ot a bit. Any bro know how to increase the 'power' of the flame for a 3 ring burner? Is it becos something is stuck in the pipe and block the flow of gas. My CO always complain no wok hei. Looks like TS and me need to change stove? Or is it the gas, tiagong some brand burns hotter. Is it true? Link to post Share on other sites More sharing options...
Evillusion Supersonic November 25, 2015 Share November 25, 2015 (edited) Sorry TS, ot a bit. Any bro know how to increase the 'power' of the flame for a 3 ring burner? Is it becos something is stuck in the pipe and block the flow of gas. My CO always complain no wok hei. Looks like TS and me need to change stove? Or is it the gas, tiagong some brand burns hotter. Is it true? i just changed my hob to an Aerogaz tempered glass model. Cost me sgd428 for it and best thing is after installing the tech cant fire up the hob. He found out that it was due to the PUB gas supply. Called their technician and true enough the meter had to be changed....nb....waste my money siak! http://www.bestpricehub.com.sg/index.php?route=product/category&path=72_97 Edited November 25, 2015 by Eviilusion 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 25, 2015 Share November 25, 2015 Sorry TS, ot a bit. Any bro know how to increase the 'power' of the flame for a 3 ring burner? Is it becos something is stuck in the pipe and block the flow of gas. My CO always complain no wok hei. Looks like TS and me need to change stove? Or is it the gas, tiagong some brand burns hotter. Is it true? All this is anecdotal. Best is to go someone's house and compare. There's some differences but within limits. Some like Rinnai built in Burners are hotter. But they cost almost double the normal hobs. There's no way anyone with a home hob can match the wokhei of outside. They are using lpg canisters with much higher flow rates coupled with industrial grade Burners which allow them to reach high temperatures quickly which sear the food and create wokhei 2 Link to post Share on other sites More sharing options...
Count-Bracula Twincharged November 25, 2015 Share November 25, 2015 All this is anecdotal. Best is to go someone's house and compare. There's some differences but within limits. Some like Rinnai built in Burners are hotter. But they cost almost double the normal hobs. There's no way anyone with a home hob can match the wokhei of outside. They are using lpg canisters with much higher flow rates coupled with industrial grade Burners which allow them to reach high temperatures quickly which sear the food and create wokhei Yalah, CO always think at home can have zhi char jet propulsion stove. LOL! Thanks bro. i just changed my hob to an Aerogaz tempered glass model. Cost me sgd428 for it and best thing is after installing the tech cant fire up the hob. He found out that it was due to the PUB gas supply. Called their technician and true enough the meter had to be changed....nb....waste my money siak! http://www.bestpricehub.com.sg/index.php?route=product/category&path=72_97 Aiyoh! Hope it can be fixed. spray WD-40. Pffffft! Wa KHAW! Link to post Share on other sites More sharing options...
Evillusion Supersonic November 25, 2015 Share November 25, 2015 Yalah, CO always think at home can have zhi char jet propulsion stove. LOL! Thanks bro. Aiyoh! Hope it can be fixed. Pffffft! Wa KHAW! its working fine now after the pub tech changed the meter.....he told us many people only find out the meter problem after changing the hob. He told us we were somewhat lucky as we changed the hob after 20 yrs of use......some changed the hob after just 5 yrs of use thinking the hob was spoilt and only got to know it was actually the pub meter that was giving problems (very low pressure) after purchasing a new hob. PUB will changed the meter foc but new hob already bought....kns! Link to post Share on other sites More sharing options...
Hotamp 3rd Gear November 25, 2015 Share November 25, 2015 personally there are 2 things I don't mess around with, firstly is electricity and another is gas. maybe TS should consider changing the whole setup instead of changing the stuck burner. normally the burner is easily taken out, but you used until it warped and got stuck, maybe it is not a good idea to forced it out could accidentally damage it without knowing. damaged stove is a fire hazard. 3 Link to post Share on other sites More sharing options...
Meanmachine 6th Gear November 25, 2015 Share November 25, 2015 spray WD-40. Yeah, I removed the old burners, sprayed with WD 40 on all burners hole and allow some time to let it dissolve the tar, stains and residues inside, them used a good stainless mesh to scrub off the remaining stubborn residue. This should be it, wash and rinse off all parts and allow to sun it for at least an hour or so, make sure it a sunny day. I did mine last month, guess what, all those stucked up stains and oily residues all disappeared. and the hob cyclinders are firing all positions. Thx to WD 40. Its really works ↡ Advertisement 2 Link to post Share on other sites More sharing options...
No increase in gambling addicts since 2 casinos opened.
2022 6th Generation Honda Stepwagon
new member
new member
Harrier 2017
Harrier 2017
A young and driven development team needs your help
