IPB
Welcome Guest ( Log In | Register )
Keyword: Search Button
Advanced Search
Most Viewed Discussions
Most Active Discussions
3 Pages V   1 2 3 >
Reply to this topicStart new topic
Karebu
Karebu post Aug 19 2012, 01:30 AM
Post #1
5th Gear
Warn: -----
What's the cheapest way of testing battery health?
I know for sure multimeter doesn't work.
Yesterday was my second time with flat battery. I did 'feel' a slightly slower crank about a month ago and this time round I've decided to test the batt with multimeter religiously. And even when it went dead, it was registering about 12.2v and 11.9v with ignition turned to accessory.
Both times I've monitored the indicators on the batteries. Two different brands. And they have obviously failed me.
I'm aware of battery load testers but they don't come cheap. I am doubtful of those $20 battery health meters (cigarette plug style found in autobacs) - or do they work?
I do carry jumper cables in the boot but I really dislike the idea of having to wait around for some kind soul to help. Are there any other ways to test?
This post has been edited by Karebu: Aug 19 2012, 01:31 AM
Go to the top of the page
+Quote Post
Aimnfire
Aimnfire post Aug 19 2012, 08:39 AM   |  In Reply To Karebu
Post #2
6th Gear
Warn: -----
QUOTE (Karebu @ Aug 19 2012, 01:30 AM) *
its when you crank, you need to measure that voltage
hire a hitman is far cheaper than hiring a lawyer
and it gets the job done
+Quote Post
Kb27
Kb27 post Aug 19 2012, 09:23 AM   |  In Reply To Karebu
Post #3
6th Gear
Warn: -----
Get a cheap digital voltmeter from ebay for car, about $15 and wire up to the battery.
Remove any surface charge - leave headlights on for 10 mins after engine shutdown. A fully charged battery is close to 12.66V
Remove fuel pump fuse, crank engine and hold for a couple of seconds.
Look at the meter reading during the crank/hold.
If the reading is near to 10.0V, I think it's time to change battery.
+Quote Post
Eyke
Eyke post Aug 19 2012, 09:23 AM
Post #4
6th Gear
Warn: X----
http://global.rakuten.com/en/store/yusayusa/item/10003211/
shaolin.sg
Spreadsheet for Depreciation v4.0!
+Quote Post
Trafficwatch
Trafficwatch post Aug 19 2012, 11:30 AM   |  In Reply To Karebu
Post #5
2nd Gear
Warn: -----
If you're willing to pay around S$ 130, then i can sell you a Battery Load Tester. ("AutoBac" selling S$ 230/- unit).
Cheap and most accurate of testing your auto battery condition vs "Midtronic" tester for testing CCA only.
What most important to know is all about the / our auto battery condition LOAD SUSTAINABILITY NOT CCA.
Determination of auto battery CCA is vary from brands of battery to another brands of battery (Just for sharing, different auto battery makers / models having different specs, formulation of Positive / Negative lead plates, different type of plates constructions -- plate constructions also determine the flow current - CCA, Separator materials used (Absorbed Glass Mat or PE materials, plastic materials), the acid SG reading for their batteries so by testing the auto battery CCA is not absolute precise method for this case)
+Quote Post
Yeobh
Yeobh post Aug 19 2012, 09:48 PM   |  In Reply To Karebu
Post #6
Supercharged
Warn: -----
Just Pm u
Visit My Facebook for the latest automotive breaking news & innovative specialty tools.
+Quote Post
Yeobh
Yeobh post Aug 19 2012, 10:48 PM   |  In Reply To Trafficwatch
Post #7
Supercharged
Warn: -----
Good explanation, most of the local mechs try to sell batteries base on CCA testing ( using sampling test) which is a test std more for cold countries. The best way is still to test each cell specific gravity using hydrometer.
+Quote Post
Karebu
Karebu post Aug 20 2012, 12:26 AM   |  In Reply To Yeobh
Post #8
5th Gear
Warn: -----
QUOTE (Yeobh @ Aug 19 2012, 10:48 PM) *
Hygrometer works for maint free dry cell?
+Quote Post
Yeobh
Yeobh post Aug 20 2012, 07:58 AM   |  In Reply To Karebu
Post #9
Supercharged
Warn: -----
Not suitable for MF batteries ( sealed )
+Quote Post
Yeobh
Yeobh post Aug 20 2012, 08:46 AM
Post #10
Supercharged
Warn: -----
This post has been edited by Yeobh: Aug 20 2012, 08:48 AM
+Quote Post
Trafficwatch
Trafficwatch post Aug 20 2012, 01:50 PM   |  In Reply To Karebu
Post #11
2nd Gear
Warn: -----
Hydrometer don't use on MF Battery and the "Magic Eye" is not really telling you the status of battery but to confirm if sufficient acid level that pass thru the bottom base of "Magic Eye" path. (For auto MF Battery, it's not 100% dry type but appprox. 30% to 40% with acid content in it and it's just Maintenance Free due to you can't check the acid SG level and open the 6 x cell vent plugs)
+Quote Post
Yeobh
Yeobh post Aug 20 2012, 07:19 PM
Post #12
Supercharged
Warn: -----
BATTERY HYDROMETER PROFESSIONAL DISC TYPE
This post has been edited by Yeobh: Aug 20 2012, 07:22 PM
+Quote Post
Batlim
Batlim post Aug 24 2012, 12:16 AM
Post #13
3rd Gear
Warn: X----
Hi guys I got a CCA tester, if any1 of you need - we could do a CCA test for you free - do comeby by appointment pls - also U need to you your battery CCA rating as they should be stated on your battery biggrin.gif biggrin.gif
+Quote Post
HAW
HAW post Aug 24 2012, 09:42 PM   |  In Reply To Karebu
Post #14
Warn: -----
sweatdrop.gif rule of thumb batteries for car last about 2 years in sg due to our hot and humid weather,there is a cheaper load tester in the market which cost about $70 you can get hold of this in a electrical shop in king geoge ave.
+Quote Post
Neutrino
Neutrino post Aug 24 2012, 10:57 PM
Post #15
6th Gear
Warn: -----
Now and again when I come back from overseas my battery will be flat.
Each time I call out AA to start the car.
Each time the AA guy does a battery test and tells me my battery is a dead loss and I should buy a new one.
Each time I tell him thank you but I'll carry on with this one.
Each time I use it without problem for another 6 months at which time I go overseas again.
This has been happening for 6 years now and still on the original battery.
There is no law without enforcement
+Quote Post
Yeobh
Yeobh post Aug 24 2012, 11:44 PM   |  In Reply To Neutrino
Post #16
Supercharged
Warn: -----
The AA guy should not conduct a high discharge test on a drained battery. It does not serve any purpose as the battery is already short of "juice". The battery must be slowly charge up to full charge status. At this stage the battery can then be subjected to a high discharge test.
The other possibility - there is a parasite drain taking place even when you completely shut down the engine and other electrical systems. Unless the drain is detected and "plug" if not even a brand new battery will be drain off very far.
+Quote Post
Yeobh
Yeobh post Aug 24 2012, 11:49 PM   |  In Reply To HAW
Post #17
Supercharged
Warn: -----
High discharge testers load consists of fix resistor wires. Most of the cheap version have resistor wires that can take load up to 70 amp. Generally it's is best to use a 100amp load discharge tester for more accuracy and longer tester natural life.
+Quote Post
Batlim
Batlim post Aug 25 2012, 10:27 AM   |  In Reply To Neutrino
Post #18
3rd Gear
Warn: X----
QUOTE (Neutrino @ Aug 24 2012, 10:57 PM) *
How long are your trips normally ?
Have you tried fully charging your battery before the trip ?
What is the brand or the battery & your ride ?
+Quote Post
Jim
Jim post Aug 25 2012, 11:02 AM   |  In Reply To Neutrino
Post #19
3rd Gear
Warn: -----
Why don't you disconnect the battery before you go overseas then? Just make sure you lock all the doors before disconnecting.
I think I always take good care of my battery but it always dies exactly at 2 years interval. Ironically, the car can be untouched for 10+ days and start without problem, but dies on me at the most ridiculous times, like during petrol top up after a 2 hour drive. I'm always envious of people who can keep their battery alive for more than 2 years. Hope I have better luck now with nanopulser.
+Quote Post
Karebu
Karebu post Aug 25 2012, 11:48 AM   |  In Reply To Jim
Post #20
5th Gear
Warn: -----
How do u take care of your battery?
I've only heard of leaving accessories all off till you've started engine.
+Quote Post
3 Pages V   1 2 3 >
Similar Threads
    Topic Title Forum Replies Last Action
No New Posts   Topic has attachmentsJump Start Battery Maintenance & Repairs 24 Today, 09:12 AM
Last post by: Yeobh
No New Posts   Recommendation for car battery Maintenance & Repairs 20 Yesterday, 11:45 PM
Last post by: Rezorn86
No New Posts   Boliden MF battery : Any Comment Maintenance & Repairs 13 16th May 2013 - 10:55 PM
Last post by: Dark_flan
No New Posts   Topic has attachmentsSigns of Alternator or battery failing ? Maintenance & Repairs 40 11th May 2013 - 03:57 PM
Last post by: Kb27
No New Posts   Topic has attachmentsWhich battery to get Maintenance & Repairs 94 5th May 2013 - 02:40 PM
Last post by: Yuan
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
GuidelinesTerms Of ServiceAbout UsModerators Lo-Fi Version     Time is now: 18th May 2013 - 04:08 PM RSS
