IPB
Welcome Guest ( Log In | Register )
Keyword: Search Button
Advanced Search
Most Viewed Discussions
Most Active Discussions
2 Pages V   1 2 >
Reply to this topicStart new topic
Whywhy68
Whywhy68 post Jul 5 2010, 05:51 PM
Post #1
1st Gear
Warn: -----
my rear seat car door lock is spoil.. passenger cannot open the door from inside but opening using the outside is ok..
how much will the repair roughly cost?
Go to the top of the page
+Quote Post
KapitanE
KapitanE post Jul 5 2010, 05:56 PM   |  In Reply To Whywhy68
Post #2
5th Gear
Warn: -----
QUOTE (Whywhy68 @ Jul 5 2010, 05:51 PM) *
u sure damaged? check the child lock switch, maybe some switch it on....
No signature is required
+Quote Post
Bavarian
Bavarian post Jul 5 2010, 06:20 PM   |  In Reply To Whywhy68
Post #3
2Fast2Furious
Warn: -----
如果借钱不用还那该多好!
+Quote Post
Whywhy68
Whywhy68 post Jul 5 2010, 11:00 PM   |  In Reply To KapitanE
Post #4
1st Gear
Warn: -----
QUOTE (KapitanE @ Jul 5 2010, 05:56 PM) *
ya quite sure cos left side rear door can open from both inside & outside, right side cannot open from inside, can only open from outside.
driving Toyota Vios, repair need hw much?
+Quote Post
Opel17
Opel17 post Jul 5 2010, 11:58 PM   |  In Reply To Whywhy68
Post #5
5th Gear
Warn: -----
QUOTE (Whywhy68 @ Jul 5 2010, 11:00 PM) *
The child-lock for left and right are separate and independently of each other.
Open the door, take a look at the door frame, look for a small mechanical lever/button with the label "child lock".
+Quote Post
Bavarian
Bavarian post Jul 6 2010, 11:26 AM   |  In Reply To Whywhy68
Post #6
2Fast2Furious
Warn: -----
Depends on what broke. Might be the central lock system or the mechanical parts eg. lever broke or something jammed. Think you need to get it checked by a workshop. Just dun go back to AD if you want to cut cost. cool.gif
如果借钱不用还那该多好!
+Quote Post
Davekiat
Davekiat post Jul 17 2010, 10:58 PM   |  In Reply To Bavarian
Post #7
1st Gear
Warn: -----
I've a similar problem and I am driving a 2007 FL Vios as well. Rear passenger door cant be open from inside but can be open from outside.
Did threadstarter managed to fixed this problem and how much did it cost?
+Quote Post
Kopites
Kopites post Jul 17 2010, 11:22 PM
Post #8
6th Gear
Warn: -----
+Quote Post
TVT
TVT post Jan 21 2013, 12:45 PM   |  In Reply To Kopites
Post #9
6th Gear
Warn: -----
Just now open my car's rear door there was a loud crack sound and then it cannot open from outside. This door is child lock activated so cannot open from inside as well. sad.gif
Any bros here know what I should do? Or is there any workshop here (to recommend) which can rectify the problem?
Thanks!
+Quote Post
Sk71
Sk71 post Jan 24 2013, 01:18 PM   |  In Reply To TVT
Post #10
Warn: -----
I had this problem previously.sent it for repair at a car accessory shop at sin ming autocare L2,cost <$30
+Quote Post
TVT
TVT post Jan 24 2013, 02:42 PM   |  In Reply To Sk71
Post #11
6th Gear
Warn: -----
QUOTE (Sk71 @ Jan 24 2013, 01:18 PM) *
Thanks. Do you have the accessory shop's name?
Any idea how they get the door open again?
+Quote Post
Pisces69
Pisces69 post Jan 24 2013, 03:01 PM   |  In Reply To TVT
Post #12
2Fast2Furious
Warn: -----
QUOTE (TVT @ Jan 24 2013, 02:42 PM) *
If cfm its not e child-lock any decent ws can chk fr u. Maybe just a lever came off n need to fix back or small job to replace a metal rod.
Seldom hear e actual lock spoil.
+Quote Post
TVT
TVT post Jan 24 2013, 03:11 PM   |  In Reply To Pisces69
Post #13
6th Gear
Warn: -----
QUOTE (Pisces69 @ Jan 24 2013, 03:01 PM) *
My worry now is whether any WS can even open up the door, as the handle outside cannot open, and from inside is child-locked...
+Quote Post
Pisces69
Pisces69 post Jan 24 2013, 03:17 PM   |  In Reply To TVT
Post #14
2Fast2Furious
Warn: -----
QUOTE (TVT @ Jan 24 2013, 03:11 PM) *
Leave it to e ws. A good mech can slip a metal rod between e window glass n hook e opening mechanism to open.
If he dun know better find another more qualified mech. I can do it wh a wire clothes hangar. ph34r.gif
+Quote Post
Hjteo
Hjteo post Jan 24 2013, 04:45 PM   |  In Reply To TVT
Post #15
3rd Gear
Warn: -----
Hi TVT,
Child lock activated and you heard a loud crack sound when you lift the door handle. Sound like a portion of the door handle that catches the lock is broken. Happened to my car rear car doors before.
If the outside handle has broken to the part that is hooked to the lock, you can still try to open the door from the outside by trying the hook that portion that is linked to lock. using something with a small hook that's also firm.
Worst case (but purchase a new door handle 1st) - break the door handle from the out side to reach that part which is linked to the car lock.
Hope the above is clear.
Regards
+Quote Post
TVT
TVT post Jan 24 2013, 05:03 PM   |  In Reply To Hjteo
Post #16
6th Gear
Warn: -----
QUOTE (Hjteo @ Jan 24 2013, 04:45 PM) *
Yes, I think what you have described is what had happened - ie. outside handle broken to the part hooked to the lock. Now I lift the door handle, it is very loose (no weight at all), but it does not fall off.
If use a small hook, where to insert this hook into? From the window or behind the handle?
+Quote Post
Hjteo
Hjteo post Jan 24 2013, 05:21 PM   |  In Reply To TVT
Post #17
3rd Gear
Warn: -----
Seems like the same issue I had. Door handle is very 'light'. With a small hook, try to pull/push that part which is behind the door handle. Try to reach that part from the outside door handle. May need a torch light as well to see clearly that part that needs to be hooked. By the way, which car model is it?
I did that on my Accent (after breaking the handle for more access. Didn't try before breaking the handle off from the door. That time door handle was already broken but workshop accidentally activate the child lock. Good thing I had ordered a new door handle and was waiting for it's arrival).
From window, I think need to lower the window, use the slot from the window with a clothes hanger. I think to look for the part is linked to door latch. Maybe Pisces can help explain that portion.
This post has been edited by Hjteo: Jan 24 2013, 05:24 PM
+Quote Post
Pisces69
Pisces69 post Jan 28 2013, 11:17 AM   |  In Reply To Hjteo
Post #18
2Fast2Furious
Warn: -----
QUOTE (Hjteo @ Jan 24 2013, 05:21 PM) *
A bit hard to explain. But just get a wire clothes hanger n open up n take a free end n make a hook. Put it between window glass n rubber strip n try to hook e part that pulls e door catch open.
After a few trys u sud b able to open e door. If cannot...go to ws n let them do better.
+Quote Post
TVT
TVT post Jan 28 2013, 12:59 PM   |  In Reply To Pisces69
Post #19
6th Gear
Warn: -----
Hi bros, many thanks for all those who had replied me.
Last Sat tried to use the hanger to hook up the lock from in-between the window glass and rubber strip, but didn't succeed in opening it and gave up after 30 mins of trying. Drove to a nearby WS and a uncle mechanic took about 30 mins to open it up, using screwdrivers and metal hooks. It means to be more complicated than what bros Hjteo and P69 had described, I don't know why.
Anyway the door's child lock is now deactivated and door can now be open from inside. But the door handle is confirmed broken, so I need find time to go JB to buy a new part and replace it.
+Quote Post
Pisces69
Pisces69 post Jan 28 2013, 02:09 PM   |  In Reply To TVT
Post #20
2Fast2Furious
Warn: -----
QUOTE (TVT @ Jan 28 2013, 12:59 PM) *
Just try jb scrap yard or ws fr a 2nd hand piece cheaper. Then get ws to fix fr u.
Or just go jb n steal one. Hahaha.
+Quote Post
2 Pages V   1 2 >
Similar Threads
    Topic Title Forum Replies Last Action
No New Posts   Hyundai Avante 1.6A Maintenance Cost Korean Talk 118 19th May 2013 - 01:27 AM
Last post by: Rekcams
No New Posts   Pinned: Topic has attachmentsLeather Repair & Restoration Service Detailing 163 18th May 2013 - 08:33 AM
Last post by: Mazdacar
No New Posts   Aircon Repair, Cooling Coil Leak Maintenance & Repairs 35 17th May 2013 - 02:37 PM
Last post by: TVT
No New Posts   Labour cost for replacing springs Performance and Tuning 9 17th May 2013 - 11:37 AM
Last post by: Camron
No New Posts   Pinned: Topic has attachmentsCS-II Paint Protection 20% Discount & Paintless Dent repair Detailing 2,409 16th May 2013 - 06:38 PM
Last post by: Sealant
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
GuidelinesTerms Of ServiceAbout UsModerators Lo-Fi Version     Time is now: 21st May 2013 - 06:12 AM RSS
