IPB
Welcome Guest ( Log In | Register )
Keyword: Search Button
Advanced Search
Most Viewed Discussions
Most Active Discussions
2 Pages V   1 2 >
Reply to this topicStart new topic
Shouyi
Shouyi post Jun 21 2006, 09:08 PM
Post #1
4th Gear
Warn: X----
Hi,
with the rumours of a new 1.8L Dual VVT-I corolla, I am wondering what are the major differences b/w a Dual VVT-I unit and a I-VTEC DOHC unit. And which is more advanced. Let's discuss!
http://fd2motoringblog.blogspot.com/
My humble car blog. Welcomed to visit!
Go to the top of the page
+Quote Post
Normal_aspirated
Normal_aspirated post Jun 21 2006, 09:42 PM
Post #2
Supercharged
Warn: -----
wow, seems like the trend of japs & koreans upsizing their engines for new models. gossip.gif
+Quote Post
EventH
EventH post Jun 21 2006, 10:36 PM
Post #3
5th Gear
Warn: -----
Donno about which being more advanced.
The old Dual VVTi Altezza produce some 210hp (6MT) from 2L with 21kg.m torque. That is nearly a Honda "R" engine spec.
The new Dual VVTi V6 2.5L in the Mark X (6AT) does 212hp from 2.5L but had 26.5kg.m torque at just 3800rpm.
Actually toyota just need to put the 1.8L VVTLi from the SS2 Celica into the Corolla and the thing will also fly.
+Quote Post
Chenqien
Chenqien post Jun 21 2006, 10:43 PM
Post #4
3rd Gear
Warn: -----
eh dual vvt-i means cam phasing in both intake and exhaust valves...
i-vtec in the k block integra type R engine uses cam phasing only on the intake but has cam changing ( the traditional vtec where there is a wild cam ) thingy.. same concept as the vvtl-i.. the rest of the i-vtec i not so sure...
both are good.. but for everyday driving there is no really need for a wild cam..
+Quote Post
Gary84
Gary84 post Jun 22 2006, 02:24 AM
Post #5
Warn: -----
+Quote Post
Odyssey02
Odyssey02 post Jun 22 2006, 04:44 PM
Post #6
5th Gear
Warn: -----
i think i'll say honda produces better engines. they're renowned for it. maybe this'll be a biased viewpoint. laugh.gif furthermore, there seems to be some sludging problems with some toyota engines.
+Quote Post
Tanjkp
Tanjkp post Jun 22 2006, 04:54 PM
Post #7
5th Gear
Warn: -----
Pardon me, you mean the dual VVTi also have the higher cam lift as the the Honda Vtec ?
+Quote Post
W210k
W210k post Jun 22 2006, 06:47 PM
Post #8
5th Gear
Warn: -----
I don't think all Dual VVTi engines have the wild cam. It's dual because its required for the V6 engine's setup (quadcam vs DOHC for in-line engines).
Toyota's VVTi-L is more akin to Honda's i-VTEC. Both have phased valve timing and lift control.
V6 Quad-cam 24v 231 BHP RWD
IL-6 DOHC 24v 192 BHP x-Drive
+Quote Post
Webbyboy
Webbyboy post Jun 22 2006, 08:58 PM
Post #9
2nd Gear
Warn: -----
QUOTE
There's Corolla XRS in USA with 2ZZ-GE engine but tuned to 170bhp only. on Celica GT-S/SS2 is 190bhp. add in toyota supercharger it will be bout 215bhp. adding blitz supercharger can go till like 270bhp.
+Quote Post
Tanjkp
Tanjkp post Jun 22 2006, 09:08 PM
Post #10
5th Gear
Warn: -----
O, thks, got it. So all make now want to boost more power so as not to fall behind KR starting with DVVT.
+Quote Post
Watwheels
Watwheels post Jun 22 2006, 09:11 PM
Post #11
NOS-ed
Warn: -----
Sallah spelling lah! It's VVTL-i
ALWAYS GIVE 100% AT WORK: 12% MONDAY + 23% TUESDAY + 40% WEDNESDAY +20% THURSDAY + 5% FRIDAY
+Quote Post
Watwheels
Watwheels post Jun 22 2006, 09:32 PM
Post #12
NOS-ed
Warn: -----
Sigh! So many fancy terms, what wild cams lah ....what lift control.
Pls lah dun confuse readers can or not?
@ high rpm the air intake valves will move deeper to allow more air to enter the combustion chamber (i.e when ECU detect more air hence add more fuel to produce more power). The idea is to let in more air into the combustion chamber.
But there's a limit, the cams (shaft with offset lobes) cannot move the valves too deep or else they will hit the piston head.
It's the same concept which u learn in secondary sch on combustion nothing fancyful like u guys mentioned. More air + more fuel + ignition = bigger combustion.
This post has been edited by Watwheels: Jun 22 2006, 09:35 PM
+Quote Post
EventH
EventH post Jun 22 2006, 09:39 PM
Post #13
5th Gear
Warn: -----
I can still remember the advert where the sheep out run the race horse.
I think the main problem with the VVTLi and wild cams vtec is that the power and torque come in (shiok feeling) at rather high rpms (5-6k) That is like the redline for a regular car. Quite tiring to drive like that day in day out.
+Quote Post
Tanjkp
Tanjkp post Jun 22 2006, 09:42 PM
Post #14
5th Gear
Warn: -----
For those who ever read about 3 stage Vtec will know what is all about.
Not necessary need to ram to red line, 2nd stage lift came in at around 2K RPM.
+Quote Post
Iforu
Iforu post Jun 22 2006, 09:45 PM
Post #15
3rd Gear
Warn: -----
3stages vtec is not for racing 1.
3stages = save fuel, 2k+ switch 12 to 16valves.
+Quote Post
EventH
EventH post Jun 22 2006, 10:15 PM
Post #16
5th Gear
Warn: -----
The 3 charts are manufacturer figures for SS1, SS2 and USDM 2006 Civic Si respectively.
If you look at the charts, for cruising (at 3000rpm (110km/h?), both 1.8L Celicas had around 60hp while the 2.0L Civic Si had around 80hp.
All the engines produce around 90-100hp at 4000rpm.
Even at 6000rpm, both SS1 and SS2 produce around 140hp
while the 2006 Civic Si had around 160hp.
Off course the SS1 run out of power at 6k while the rest goes all the way to around 8k rpm.
But who drive at 6-8k all the time ... even when overtaking?
This post has been edited by EventH: Jun 22 2006, 10:16 PM
Attached File(s)
+Quote Post
Tanjkp
Tanjkp post Jun 22 2006, 10:20 PM
Post #17
5th Gear
Warn: -----
Post: 3stages vtec is not for racing 1.
That's right, that's how it sells with economy + power.
+Quote Post
Tanjkp
Tanjkp post Jun 22 2006, 10:23 PM
Post #18
5th Gear
Warn: -----
Thks for the charts, they are talking about max torgue, max power.
The Vtec lift don't kick in at high RPM only.
Most drivers will hardly use up to that high power / RPM.
This post has been edited by Tanjkp: Jun 22 2006, 10:26 PM
+Quote Post
EventH
EventH post Jun 22 2006, 10:27 PM
Post #19
5th Gear
Warn: -----
The amazing thing for the new vtec engine is that its max torque can be achieved at 3000rpm.
+Quote Post
Davidtch
Davidtch post Jun 22 2006, 11:03 PM
Post #20
Supercharged
Warn: -----
In modern era car technology, variable valve technology is basically split into 2 school:
1. Cam-Changing VVT; &
2. Cam-Phasing VVT.
Cam-Changing VVT
For eg, Honda VTEC, basically, it use the intake camshaft to vary the timing of valve. For 3 stage Honda VTEC, @ low RPM, 1 intake valve is open. @ Medium RPM, rocker arm connect both intake valve. @ High RPM, rocker arm will open both valve for a longer period. All this happen during the intake phase.
Cam Phasing VVT
For eg, Toyota VVT-I or BMW Vanos. Basically, otto cycle engine comprised of 4 cycle, intake, compression, explosion & exhaust. B4 VVT, all these cycle operate independantly. Under Cam Phasing VVT, there will be overlapping between this cycle. Under this set-up, Cam Phasing VVT, can be implemented in either intake valve only or both intake/exhaust.
For intake valve only, during compression cycle, intake valve do not close up until piston reach certain angle. This allow more air into combustion chamber to achieve a leaner burner. This is the basic set-up for Toyota VVT-i. The i (stand 4 intelligence) allow ECU to vary the timing of intake valve depending on engine load & other factors.
For intake/exhaust, compression cycle is the same as intake valve. The only difference is that exhaust valve continue to open during intake cycle. This is the basic set-up for Toyota dual VVT-I and BMW double vanos.
Cam-changing + cam-phasing VVT
It combine both technology during intake cycle, which allows more petrol into combustion during high RPM. This is found in Honda I-VTEC & Toyota VVTL-I. However, honda I-VTEC toward lean burning. The reason Toyota VVTL-I is not as powerful as Honda VTEC is the component used. If Toyota Celica using VVTL-I upgraded to TRD engine parts, power output will increase from 180HP to 200HP. Do rem that Toyota celica is 1.8L
+Quote Post
2 Pages V   1 2 >
Similar Threads
    Topic Title Forum Replies Last Action
No New Posts   Topic has attachmentsRare 1st series car plates side by side General Car Discussion 63 Yesterday, 09:17 AM
Last post by: Pisces69
No New Posts   Simota Dual Spiral Jet Performance and Tuning 19 11th May 2013 - 06:24 PM
Last post by: Chucky2007
No New Posts   Topic has attachmentsBMW 3 Series GT General Car Discussion 31 25th April 2013 - 05:21 PM
Last post by: Juliagezm1
No New Posts   BMW 5 Series Facelift undisguised General Car Discussion 12 28th February 2013 - 02:03 AM
Last post by: Mercs
No new votes   Poll: Dual Citizenship For Singapore? Your Views? Lite & EZ 126 19th February 2013 - 09:11 PM
Last post by: GemLeo
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
GuidelinesTerms Of ServiceAbout UsModerators Lo-Fi Version     Time is now: 22nd May 2013 - 10:54 AM RSS
