Mitsubishi Lancer Evolution VIII - 2nd hand in Thailand - Many problems
Nina
Hi I joined the forum to learn a bit more about cars.
I bought a used Evo VIII from a dealer in Bangkok and a test revealed that it's got many problems.
Now I want to try to get them fixed and learn a bit about it at the same time.
Here is a list of all the issues.
For a start maybe someone can comment on what the most important thing to fix would be, the most dangerous, etc ..
Engine
- damaged oil sump
- deteriorated drive belt
Fuel System
- bent fuel pipe under
- dent intercooler
Exhaust system
- deteriorated exhaust pipe mount rubber
Suspension
- deteriorated rear arm bush
Chassis and body
- dented front left door
- dented front right door
- dented rear left door
- dented rear right door
- fits poorly boot-trunk seal
- fits poorly front right door adjust
- general paint and body work poor condition
- lose shape door trunk seal
- missing under engine panel
- repainted body
- repaired A, B, C-pillar high
- repaired body engine compartment
- repaired front cross member lower upper
- repaired front left fender high
- repaired front right fender high
- repaired rear left fender high
- repaired rear right door high
- repaired rear right fender high
- repaired roof high
- repaired trunk lid high
- replace rear structure body
- scrape / dent longitudation member
Braking system
- bent brake pipe under
- parking brake retardation is below limit value
Tires
- missing spare wheel
- nail stab rear right tire
- scraped rim
Electric System
- broken combination light
- defective battery
- defective from wiper system
- front and rear nozzle washers do not work
- headlight direction not correct
Transmission
- oil leak from gearbox
Interior
- loose front console box
- loose front left side panel cover plastic
- loose rear left side panel cover plastic
- missing rear safety belt
- scratch front console
I'm not sure about the accident, but this type of car doesn't exit in Thailand and it's possible that it has been put together from parts from Japan, and not even imported as one entire car from Japan, but I don't know if there is any way to know that.
1,200,000 Thai Baht
There were some other 2003 EVo VIII on sale for about 1,600,000 Thai Baht.
Sounds very screwed up and definitely an accident car. Probably a insurance write-off.
If it is an everyday car, don't be surprised that the repairs come up to be about the cost of the car itself. If it is to be a track car then great! Since everything is gonna be chucked out for better racing parts and the chassis will be strengthened.
I only got it yesterday so for now I'm stuck with it, I have an engine warranty from the dealer which they might or might not honour, verbally they already refused to honour it after I told them about the issues, so next thing lawyer will call them.
I am prepared to spend some money on things that need to be fixed, just not sure if a garage in Thailand can get parts, or if they can use lancer parts or how to go about repairing each issue, so I I will get some quotes in the coming days I think.
Supercharged
Nina, hv u tried posting in Thai forum racing forum. They are in a better position to advise u.
Do a google & u can find one.
I found one but it's in Thai which I can't read or write. If you find an English one please post the link. Thank you!
