IPB
Welcome Guest ( Log In | Register )
Keyword: Search Button
Advanced Search
Most Viewed Discussions
Most Active Discussions
60 Pages V   1 2 3 4 5 > »
Reply to this topicStart new topic
Maddriver
Maddriver post Jan 31 2008, 12:20 AM
Post #1
Sponsor
Warn: -----
Hi.. I guess it will be good for me briefly describe the application method in case you have forgotten..
Step 1 Part no #901 shampoo
This shampoo is really foamy..A cap for a big pail of water..If you intend to claybar..go for 2 caps to have more lub..Do not follow instruction..3 caps for a gallon.. You will have foam party..
After washing and rinsing your car.. Dry with a waffle weave or the drying towel you have.. For waffle weave user..each time before you use..soak into water..dry it and you can start drying the car.
Step 2 Part no #101 / #501 polish
Use a micro-fiber applicator..dam applicator with a bit of water..Apply polishes on to applicators.. a size of a 10cent coin is good enough..Apply onto panel..Thin layer.. hazy and cloudy effect is good enough..Avoid circular direction.. Need not use too force to apply unless for stuborn stains.. Apply whole car and wait for 5 minsto haze and you can start buffing off with a MF cloth.
Step 3 #601 PBA
This step is applicable to those using PBA..if you are not using it..You can proceed to step 4. For PBA..it is very transparent..you may not see the hazy or cloudy effect..Thin layer will do..Need not dam applicators with water..
Step 4 Part no #105
Use a micro-fiber applicator..dam applicator with a bit of water..Apply on to applicators.. a size of a 10cent coin is good enough..Apply onto panel..Thin layer... cloudy and hazy effect is good enough.. Haze for about 10 mins and you can start buffing off..
If you wish to apply #951 aquawax.. you may do so but not for #521 or #921 quick detailer.. Quick detailer comes in between washes or for fresh water spot..tree sap or bird poo..
If you have both #951 and #521 .. Use #951 weekly or bi-weekly..for daily use will be #521/#921 quick detailer..If you intend to have a coat of #951 aquawax..you can use #521/#921 QD to clean up surface and proceed to #951 aquawax..If you do not intend to use #951 AW.. Simply go round with QD will do.. Just remember #951 is alway the last step...
Take note..For #951 aquawax.. the result will be better after when is cure..some of use have notice the different on the following day..
Tips
Instead of dam applicators with water for #105..Spray a bit of #951 Aquawax on applicators or panel first follow by applying #105..hehe..dun ask me why..try it and you might see something different.
Or after buffing away #105..you can apply #951 AW on applicator and apply on panel.. apply evenly and walk away..No buffing require.. This steps require little bit of skill..hehe.. or else you will get unbuff AW stick on the panels..
Happy detailing guys n .. feel free to discuss if you have any doubts
This post has been edited by Maddriver: Jan 31 2008, 12:23 AM
Website Duragloss Car Care products
Website Optimum Car Care products
Contact : Call / SMS / WhatApps 93387370 Benny
Go to the top of the page
+Quote Post
Beei
Beei post Jan 31 2008, 12:54 AM
Post #2
6th Gear
Warn: -----
Before buffing off any wax/sealant, can spray some QD first to buff off easier? That is what I do..
The secret to enjoying your job is to have a hobby that is even worse.
+Quote Post
Latioboy
Latioboy post Jan 31 2008, 01:14 AM
Post #3
6th Gear
Warn: -----
Yay! This weekend, all those who collected their stuff from me and MD, all busy doing uptheir cars alr!!
Jia you ! Kim kim for CNY !
+Quote Post
Linchong
Linchong post Jan 31 2008, 08:00 AM
Post #4
1st Gear
Warn: -----
QUOTE
Just to clarify... So I have to soak the cloth in water, then hang out to dry before it can be used? Or you mean that I have to soak and then squeeze out the water then use? confused.gif
+Quote Post
Maddriver
Maddriver post Jan 31 2008, 08:13 AM
Post #5
Sponsor
Warn: -----
This is also another way as long THIN layer.. very easy to buff..
+Quote Post
Maddriver
Maddriver post Jan 31 2008, 08:14 AM
Post #6
Sponsor
Warn: -----
Paiseh.. soak into water..squeeze it dry and you can start to dry the car...After using..air dry will be good..do not leave it under the sun to dry
This post has been edited by Maddriver: Jan 31 2008, 08:17 AM
+Quote Post
Jerry
Jerry post Jan 31 2008, 09:08 AM
Post #7
2nd Gear
Warn: -----
QUOTE
Bro,if avoid circular direction then how should we do it?Up down sequence?
+Quote Post
Maddriver
Maddriver post Jan 31 2008, 09:23 AM
Post #8
Sponsor
Warn: -----
forward and back..or vertically
+Quote Post
Jerry
Jerry post Jan 31 2008, 09:24 AM
Post #9
2nd Gear
Warn: -----
Ok..Cant wait to get the products from you tonight so that i can start my polishing this weekend.Haha..
+Quote Post
Latioboy
Latioboy post Jan 31 2008, 09:57 AM
Post #10
6th Gear
Warn: -----
Goood goood bro....
We have brought out the detailing spirit in you...
Heehee!
+Quote Post
Keen
Keen post Jan 31 2008, 10:57 AM
Post #11
3rd Gear
Warn: -----
for 101 and 105... i understand that we apply to one panel at a time... but buff off after 5/10 mins... does it means i got to buff off that panel after 5/10 mins? or i apply to the whole then wait for 5/10 mins?
+Quote Post
Maddriver
Maddriver post Jan 31 2008, 11:31 AM
Post #12
Sponsor
Warn: -----
Bro keen.. for #101..u can do panel by panel..if you apply whole car..u need nt really need to wait 10mins..I use it to prep surfaces..to clean up before #105..
For #105.. apply whole car..wait 10mins and you can starting buffing off
+Quote Post
Keen
Keen post Jan 31 2008, 04:08 PM
Post #13
3rd Gear
Warn: -----
ok... thanks! is car wax a form of sealant too?
+Quote Post
Eviltrap
Eviltrap post Jan 31 2008, 07:31 PM
Post #14
4th Gear
Warn: -----
Hey bro, how about the Nu-glass #755? Do I apply it like #101 or #501? Wet applicator then put the wax on the applicator?
I realises that if I use my MF cloth, the wax will spread all around my MF cloth and I dun get much onto the windscreen. How many layers must I put?
+Quote Post
Linchong
Linchong post Jan 31 2008, 07:48 PM
Post #15
1st Gear
Warn: -----
QUOTE
Another newbie question.... Can #101, #501 or #521 prepare surfaces to such an extent that claybar is not necessary?
+Quote Post
Fedup
Fedup post Jan 31 2008, 07:53 PM
Post #16
Clutched
Warn: -----
Bro: when's yr next visit to Tampines?
i miss out yesterday on 30/1/08.
+Quote Post
Malie
Malie post Jan 31 2008, 08:50 PM
Post #17
4th Gear
Warn: -----
ups for you...will be getting 951 and 521 soon from you :)
+Quote Post
Latioboy
Latioboy post Jan 31 2008, 11:35 PM
Post #18
6th Gear
Warn: -----
Yes! Upz for MD!!!
Malie quick collect! CNY kim kim ride !
+Quote Post
Jimhow
Jimhow post Jan 31 2008, 11:50 PM
Post #19
2nd Gear
Warn: -----
remember to take the Duragloss car decal from benny if he still got left
+Quote Post
Latioboy
Latioboy post Feb 1 2008, 01:06 AM
Post #20
6th Gear
Warn: -----
Ohhh
You need it ?
+Quote Post
Similar Threads
    Topic Title Forum Replies Last Action
No New Posts   Review: Duragloss 921 (Quick Detailer) Detailing 44 13th June 2013 - 10:10 PM
Last post by: Samster69
No New Posts   Topic has attachmentsDuragloss Photo Gallery Detailing 1,821 9th June 2013 - 06:18 PM
Last post by: Throttle2
No New Posts   Topic has attachmentsDuragloss Nano Clear Seal vs Optimum Opti-Guard Detailing 133 21st May 2013 - 07:54 AM
Last post by: Optivax
No New Posts   Which Duragloss should I get for this job? Detailing 13 30th April 2013 - 08:31 PM
Last post by: Wesleyoh
No New Posts   Duragloss 271 on rubber trims. Now then i know Detailing 2 30th November 2012 - 11:19 AM
Last post by: Maddriver
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
GuidelinesTerms Of ServiceAbout UsModerators Lo-Fi Version     Time is now: 18th June 2013 - 12:52 PM RSS
