Kazuo Neutral Newbie August 21, 2008 Share August 21, 2008 A set of 4, how much will it cost? ↡ Advertisement Link to post Share on other sites More sharing options...
Robo 2nd Gear August 22, 2008 Share August 22, 2008 around 1k... Link to post Share on other sites More sharing options...
King 1st Gear August 22, 2008 Share August 22, 2008 so ex now Link to post Share on other sites More sharing options...
Kyojin 1st Gear August 22, 2008 Share August 22, 2008 koni 1k??? can almost get coilovers already Link to post Share on other sites More sharing options...
Robo 2nd Gear August 22, 2008 Share August 22, 2008 eh... around but not exact. probably around that amt with springs.. if u extending coe might as well get coilovers. Link to post Share on other sites More sharing options...
So_nice 6th Gear August 22, 2008 Share August 22, 2008 1k add abit can get d2 le.. Link to post Share on other sites More sharing options...
Kyojin 1st Gear August 22, 2008 Share August 22, 2008 with install and alignment somemore... Link to post Share on other sites More sharing options...
Datsunking Neutral Newbie August 22, 2008 Share August 22, 2008 $500++ lar for yellow koni shocks, red cheaper, fsd most ex Link to post Share on other sites More sharing options...
Steam Neutral Newbie August 22, 2008 Share August 22, 2008 hmmmm... seems like most of them are very familiar with the price... just got koni? Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie August 24, 2008 Author Share August 24, 2008 coilover how much? Link to post Share on other sites More sharing options...
Route88 2nd Gear August 24, 2008 Share August 24, 2008 A set of 4 yellow konis,adjustable cost ard $400 ++,butt tat was many years back. Now, dont know,can't be $1K Link to post Share on other sites More sharing options...
Robo 2nd Gear August 24, 2008 Share August 24, 2008 yeah tts y i said with springs... Link to post Share on other sites More sharing options...
Ronnchee Clutched August 24, 2008 Share August 24, 2008 eh... around but not exact. probably around that amt with springs.. if u extending coe might as well get coilovers. What is the different between Shock, Coilover, suspension ... ? Thanks Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie August 24, 2008 Author Share August 24, 2008 400++? hmm... i just got a $500++ quote leh... where you got yours? Link to post Share on other sites More sharing options...
Kyojin 1st Gear August 24, 2008 Share August 24, 2008 as it's name implies, suspension is what keeps your car "suspended" - so you don't feel every bump and rut on the road. most suspension systems are made of springs and shocks. the spring is meant to absorb impact and the shocks (gan tong) are what prevents the spring from going "BOING!!!" most systems are coil springs over shocks, which gives the name coilovers. but most people use it interchangeably to refer to aftermarket performance suspension systems that come with spring and shocks. Link to post Share on other sites More sharing options...
Ronnchee Clutched August 24, 2008 Share August 24, 2008 Thanks for the explanation bro. To lower the car, is to change the spring or entire coilover ?? Link to post Share on other sites More sharing options...
Kyojin 1st Gear August 24, 2008 Share August 24, 2008 technically, to lower the car, you change the springs. but it depends on the spring rate of the new spring and the return rate of your shocks. that's why when people want to lower their cars, they generally change to aftermarket shocks too - or get a complete "coilover" set. Link to post Share on other sites More sharing options...
Ronnchee Clutched August 25, 2008 Share August 25, 2008 Thanks for the info bro. Now have a better understanding of spring, shock and coilover. ↡ Advertisement Link to post Share on other sites More sharing options...
All about springs and shocks(dampers)
Anyone has Koni Sport Shocks (8471) Adjustment Knob?
Changing of shocks - Any good workshop to recommend?
Where to get Bilstein Shocks?
Didnt know Tokico Shocks are much more affordable
Cheap shocks to recommend for 2004 RX300
KW coilovers or Koni yellow/Eibach pro-kit
