Yattokame 4th Gear May 17, 2009 Share May 17, 2009 Hi, I was just looking around for a convertible for the missus, and came across one which she has quite taken a fancy to. Price was good, certified as 'A' for inspection, etc; except that when I started the engine. The idling rpm was 1500 approx. Is this normal? The car has a manual transmission. What could be wrong with the car? Anything else I should check? thanx! ↡ Advertisement Link to post Share on other sites More sharing options...
Chickensoup 1st Gear May 17, 2009 Share May 17, 2009 On cold start there is auto choke function to up rpm due to rich mixture...Normal After you drive the car for say 1km or even lesser, the engine will be warm and the autochoke will be off, then the rpm will be below 1000 Link to post Share on other sites More sharing options...
Throttle2 Supersonic May 17, 2009 Share May 17, 2009 Hi, I was just looking around for a convertible for the missus, and came across one which she has quite taken a fancy to. Price was good, certified as 'A' for inspection, etc; except that when I started the engine. The idling rpm was 1500 approx. Is this normal? The car has a manual transmission. What could be wrong with the car? Anything else I should check? thanx! the idling should drop to normal after a minute or two. if it doesnt, it could be purposely tuned up so that it doesnt die. anyway if you identify the car, maybe some fellas here have owned it before and can advise better. Link to post Share on other sites More sharing options...
Maffie Neutral Newbie May 17, 2009 Share May 17, 2009 (edited) Hi, I was just looking around for a convertible for the missus, and came across one which she has quite taken a fancy to. Price was good, certified as 'A' for inspection, etc; except that when I started the engine. The idling rpm was 1500 approx. Is this normal? The car has a manual transmission. What could be wrong with the car? Anything else I should check? thanx! Some cars have high idle on cold start. It is done to heat up the engine and other components quickly so it can meet emission requirements. Most evident is an RX-7... the cold start idle is about 3000rpm[sweatdrop] Here's what you have to do to check it... slip the clutch and move off. It should come down quickly Edited May 17, 2009 by Maffie Link to post Share on other sites More sharing options...
Yattokame 4th Gear May 17, 2009 Author Share May 17, 2009 (edited) thanx for the reply. :))) From wikipedia, "Chokes were nearly universal in automobiles until fuel injection replaced carburetion in the late 1980" so.... is it still the choke function? The car is a very new performance model... Edited May 17, 2009 by Yattokame Link to post Share on other sites More sharing options...
Yattokame 4th Gear May 17, 2009 Author Share May 17, 2009 (edited) the idling should drop to normal after a minute or two. if it doesnt, it could be purposely tuned up so that it doesnt die. anyway if you identify the car, maybe some fellas here have owned it before and can advise better. Hi there, thanx for reply I have identified the car in another thread and asked for feedbacks but no replies so far :((( it's actually this car http://www.sgcarmart.com/used_cars/info.ph...590&DL=1172 The dealer refuses to let me test drive so I cant really check the condition of the car. I'll try it again to see if the rpm drops... thanx! :)) Edited May 17, 2009 by Yattokame ↡ Advertisement Link to post Share on other sites More sharing options...
Electric cars
Electric cars
Unusual or Rare Cars - Part 3
Cars at Expo - Apr 2024
Cars We Don't Get to Drive in Singapore
Forklift operators in Spore charged for bribery!
30 Discontinued Cars That Won't Make It To 2024
Citroen Cars
Citroen Cars
