Editt Neutral Newbie November 6, 2009 Share November 6, 2009 Hi everyone, I know this is a sarlet forum, but can I ask if any workshop has and able to do a engine swap for AE101 (corolla) to 4AGE 20V engine? Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
So_nice 6th Gear November 6, 2009 Share November 6, 2009 wow. power..it could be quite costly to swap locally. i think most rep workshops should be able to do it. good luck! Link to post Share on other sites More sharing options...
Alfisti168 1st Gear November 6, 2009 Share November 6, 2009 TS, how uu get the 4AGE 20V one? Is it the 165bhp version? Link to post Share on other sites More sharing options...
Kyojin 1st Gear November 6, 2009 Share November 6, 2009 Hi everyone, I know this is a sarlet forum, but can I ask if any workshop has and able to do a engine swap for AE101 (corolla) to 4AGE 20V engine? Thanks for a 1.6 AE101, it's an easy swap since it uses a A-series engine. but suggest you go JB to do. cheaper and more availability. Link to post Share on other sites More sharing options...
Guantanamera November 6, 2009 Share November 6, 2009 TS, how uu get the 4AGE 20V one? Is it the 165bhp version? This is the one http://www.mudah.my/Toyota-4AGE-20v-Blackt...box-4307611.htm Anyone know what is the diff btw silvertop & blacktop??? Link to post Share on other sites More sharing options...
Alfisti168 1st Gear November 14, 2009 Share November 14, 2009 This is the one http://www.mudah.my/Toyota-4AGE-20v-Blackt...box-4307611.htm Anyone know what is the diff btw silvertop & blacktop??? here: http://en.wikipedia.org/wiki/4AGE#4A-GE_.2820-valve.29 Link to post Share on other sites More sharing options...
So_nice 6th Gear November 14, 2009 Share November 14, 2009 risky job as the wiring and layout looks different. easily gets into trouble when pop bonnet. but it sure looks like an sweet mod. Link to post Share on other sites More sharing options...
Deng7 Neutral Newbie November 22, 2009 Share November 22, 2009 Bro call me for details i know workshop 98202047. I also driving AE 101. Link to post Share on other sites More sharing options...
Kukuter Neutral Newbie November 29, 2010 Share November 29, 2010 I recently bought a AE101 1992 Corolla. Manual. Hi guys , may i ask any good forum to go to to discuss about this car? And where have good workshop to do up this car? I really need help pls thanks in advance! Link to post Share on other sites More sharing options...
Starletgt Neutral Newbie November 29, 2010 Share November 29, 2010 Gratz in your new car. Well basically there's a lot of performance stuff to be put into your car. You can look around zerotohundred forums and ask some kakis around here for advice cause starlet and corollas share most of the same parts. Link to post Share on other sites More sharing options...
Kukuter Neutral Newbie November 29, 2010 Share November 29, 2010 Wow I did not know starlet and corolla share parts. To be honest i very new to toyota. May i ask where to get original steering wheel? Which scrap yard in sg to go to? Link to post Share on other sites More sharing options...
Starletgt Neutral Newbie November 30, 2010 Share November 30, 2010 You can try Ong Boon Kwee at Woodlands Industrial Park E. Link to post Share on other sites More sharing options...
Starletgt Neutral Newbie November 30, 2010 Share November 30, 2010 Wow I did not know starlet and corolla share parts. To be honest i very new to toyota. May i ask where to get original steering wheel? Which scrap yard in sg to go to? If you need any help in terms of technical wise you can give me a call. 81383538 David Link to post Share on other sites More sharing options...
Kukuter Neutral Newbie November 30, 2010 Share November 30, 2010 Thanks i will try to go to the scrap yard. Actually no much stuff at the moment. I jus got car so need to drive around to see what i need to fix and stuf. Currently only need to fix steering pump leaking , Wat are the common parts hav problem?? Thanks Bro. Oh yah any Old Corolla club in sg or forum? Link to post Share on other sites More sharing options...
Kukuter Neutral Newbie November 30, 2010 Share November 30, 2010 Oh by the way Bros!!... i jus notice one thing... my idling abit kee seow........ it goes from 900 to 1600..... i dun think its normal....wats usually wrong... Link to post Share on other sites More sharing options...
Starletgt Neutral Newbie December 6, 2010 Share December 6, 2010 Thanks i will try to go to the scrap yard. Actually no much stuff at the moment. I jus got car so need to drive around to see what i need to fix and stuf. Currently only need to fix steering pump leaking , Wat are the common parts hav problem?? Thanks Bro. Oh yah any Old Corolla club in sg or forum? Steering pump leaking you can just get a one from the scrap yard. Anyway starlet ones and corollas steering pump are the same. Common parts having problems are the drive shalfs, suspensions and also old and worn out oil seals. Do take note of them. Also monitor whether your car will overheat if you leave your car idling for long with aircon on. Link to post Share on other sites More sharing options...
Starletgt Neutral Newbie December 6, 2010 Share December 6, 2010 Oh by the way Bros!!... i jus notice one thing... my idling abit kee seow........ it goes from 900 to 1600..... i dun think its normal....wats usually wrong... Hmmnn it might be your idling solenoid or the aircon control valve. Got to check with the mechanic. Link to post Share on other sites More sharing options...
Kukuter Neutral Newbie December 7, 2010 Share December 7, 2010 Steering pump leaking you can just get a one from the scrap yard. Anyway starlet ones and corollas steering pump are the same. Common parts having problems are the drive shalfs, suspensions and also old and worn out oil seals. Do take note of them. Also monitor whether your car will overheat if you leave your car idling for long with aircon on. Thanks do u know where in SG carry new stock parts for the car? Like shocks , bushing , fuel pump and orther stock parts? Or do u hav a place in JB to do? Thanks in Advance!! EX owner bypass the thermo... fan always running full time... so currently temp looking good.if i ever redo radiator then i will get it to run back normal. now i will jus leave with this. kekekekeke ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Corolla Cross
Toyota Corolla AE86 Revival! Initial D Fans COME IN!
2022 Toyota GR Corolla
All new Altis 2014
All new Altis 2014
Toyota GR Corolla Debuting March 31 New Teaser Reveals
$488,888. If you know you know!
