IDrago 3rd Gear February 19, 2010 Share February 19, 2010 Hi Friends... Need your thoughts on the subject again... Namely what are the pros and cons of each of them (DC5 GSR) & (DC5 type S JDM) Would really appreciate if friends here DO NOT side track into stuffs like "Bro, Go for Type R" with reasons being, yeah, R is cool, but out of my range!!! Thanks in advance!!! ↡ Advertisement Link to post Share on other sites More sharing options...
Piyopico Supercharged February 19, 2010 Share February 19, 2010 Negligible difference. Just buy the one with better value. Alternatively go to www.integra.sg for more info. Link to post Share on other sites More sharing options...
IDrago 3rd Gear February 19, 2010 Author Share February 19, 2010 Negligible difference. Just buy the one with better value. Alternatively go to www.integra.sg for more info. Thanks bro!! Link to post Share on other sites More sharing options...
Piyopico Supercharged February 19, 2010 Share February 19, 2010 In case you really want to know. I give you a big hint. The DC5 type S got speed cut at 180km/hr. The GSR does not......... Link to post Share on other sites More sharing options...
IDrago 3rd Gear February 19, 2010 Author Share February 19, 2010 In case you really want to know. I give you a big hint. The DC5 type S got speed cut at 180km/hr. The GSR does not......... wow... I smell a petrolhead here!! lol!! Link to post Share on other sites More sharing options...
Mnns 4th Gear February 19, 2010 Share February 19, 2010 Hi Friends... Need your thoughts on the subject again... Namely what are the pros and cons of each of them (DC5 GSR) & (DC5 type S JDM) Would really appreciate if friends here DO NOT side track into stuffs like "Bro, Go for Type R" with reasons being, yeah, R is cool, but out of my range!!! Thanks in advance!!! hmm. Sunroof (GSR) vs No Sunroof (Most Type S, reported someone PI in type S with sunroof). Sunroof = higher insurance premium for most insurers, adddtional item to maintain. My brother had trouble closing the sunroof once and had to go to kah motor for help. Nowadays I don't use it =p Auto available for GSR, JDM Type S only manual locally. Link to post Share on other sites More sharing options...
IDrago 3rd Gear February 19, 2010 Author Share February 19, 2010 hmm. Sunroof (GSR) vs No Sunroof (Most Type S, reported someone PI in type S with sunroof). Sunroof = higher insurance premium for most insurers, adddtional item to maintain. My brother had trouble closing the sunroof once and had to go to kah motor for help. Nowadays I don't use it =p Auto available for GSR, JDM Type S only manual locally. Wow.. thanks for the inputs... how bout the performance... shouldnt differ much rite?? Link to post Share on other sites More sharing options...
Kungming 1st Gear February 19, 2010 Share February 19, 2010 Engine-wise both use the same. Omv-wise, for the same yr, the type s is much higher. diff of 5-7k. type-s does not come with sunroof but comes with factory fitted struts. Link to post Share on other sites More sharing options...
IDrago 3rd Gear February 19, 2010 Author Share February 19, 2010 Engine-wise both use the same. Omv-wise, for the same yr, the type s is much higher. diff of 5-7k. type-s does not come with sunroof but comes with factory fitted struts. Thanks bro... is there any distinct advantage of whichever model that pertains to speed or handling?? Link to post Share on other sites More sharing options...
Mnns 4th Gear February 19, 2010 Share February 19, 2010 Wow.. thanks for the inputs... how bout the performance... shouldnt differ much rite?? Perf wise if you getting same manual transmission and stock settings shouldn't differ much as they using same engine as pointed out by kungming. Handling wise, I don't think (imho) you will see a huge difference, there are things you can do to improve it e.g. increasing your tire width, adding struts bar (subjective sometimes) etc. Auto GSR depending on what you did to your car and driving habits, typically FC around 9-11 km per litre for 17" tires. One thing i like about the car is the steering feels relatively 'heavy', just a personal thing =) Link to post Share on other sites More sharing options...
Jtis 4th Gear February 19, 2010 Share February 19, 2010 On surface, minimal differences other than sunroof for GSR and no sunroof for JDM Type S. But massive difference under the skin. Strengthened facelifted chassis compared to the GSR which is only pre-FL chassis specs. Significantly different undercarriage parts, thicker driveshafts, improved brakes system components etc. Other than the engine, which is still same as GSR, and no sunroof, the FL JDM type S is better in every way than the GSR. Link to post Share on other sites More sharing options...
IDrago 3rd Gear February 19, 2010 Author Share February 19, 2010 On surface, minimal differences other than sunroof for GSR and no sunroof for JDM Type S. But massive difference under the skin. Strengthened facelifted chassis compared to the GSR which is only pre-FL chassis specs. Significantly different undercarriage parts, thicker driveshafts, improved brakes system components etc. Other than the engine, which is still same as GSR, and no sunroof, the FL JDM type S is better in every way than the GSR. Thanks for enlightening!!! Any idea how whats the difference in insuring each vehicle... Type S which is sans sunroof should be cheaper rite bro?? Link to post Share on other sites More sharing options...
Icebrush79 4th Gear February 19, 2010 Share February 19, 2010 On surface, minimal differences other than sunroof for GSR and no sunroof for JDM Type S. But massive difference under the skin. Strengthened facelifted chassis compared to the GSR which is only pre-FL chassis specs. Significantly different undercarriage parts, thicker driveshafts, improved brakes system components etc. Other than the engine, which is still same as GSR, and no sunroof, the FL JDM type S is better in every way than the GSR. Wow... impressive analysis.. Link to post Share on other sites More sharing options...
Icebrush79 4th Gear February 19, 2010 Share February 19, 2010 Engine-wise both use the same. Omv-wise, for the same yr, the type s is much higher. diff of 5-7k. type-s does not come with sunroof but comes with factory fitted struts. And factory fitted HID too... Link to post Share on other sites More sharing options...
Jin78sg Neutral Newbie March 18, 2010 Share March 18, 2010 Retractable side mirrors too. ↡ Advertisement Link to post Share on other sites More sharing options...
What type of car air freshener ?
Laundry Drying system - Pull-down/Push-up type
Lotus Type 130 - The First New Lotus in 11 Years Will Be ...
Just booked my car - what type of PPS to recommend?
2018 Megane RS vs Golf GTi Vs Civic Type R
M'sia car thief like to steal what car type?
2018 Honda Civic Type R Black Edition
