| Joint membership: You may login to MyCarForum using your sgCarMart username & password |
Blackyv
Apr 14 2010, 11:58 AM
Post
#1
![]() NOS-ed Posts: 10,515 Warn:
just ask for my bil... he is driving a wish... recently, theaircon is not functioning normally... when driving or car moving,,... aircon is cool.. normal... but when stationary, the aircon suddenly will become not coold and blow hot air sometimes....... what's wrong??...
he asked a ws and that mechanics said dont know where blocked and need to strip open everything to check and that cost $700-$800 bucks.... i suspect that's bs ..if chocked, it will not be cool, right?.. and not intermittent... anyone has such similar problem before??... |
Sorrow
Apr 14 2010, 12:03 PM | In Reply To Blackyv
Post
#2
3rd Gear Posts: 390 Warn:
just ask for my bil... he is driving a wish... recently, theaircon is not functioning normally... when driving or car moving,,... aircon is cool.. normal... but when stationary, the aircon suddenly will become not coold and blow hot air sometimes....... what's wrong??... he asked a ws and that mechanics said dont know where blocked and need to strip open everything to check and that cost $700-$800 bucks.... i suspect that's bs ..if chocked, it will not be cool, right?.. and not intermittent... anyone has such similar problem before??... I'm having a similar prob ..but mine is a coe car....my mech told me compressor leaking... .anyways....why dun u try going the a/c workshops as suggested in the forums... i think ur symptoms would aso include if raining, even stationary , the aircon will be cold right...except during hot weather or noon. -------------------- Sorrow Club AE |
Contax
Apr 14 2010, 12:24 PM
Post
#3
6th Gear Posts: 4,498 Warn:
check aircon fan or fan switch .
check gas level check for leak no need to dismantle everything . Do a Search and there is several good automobile aircon wksp around. |
Chiangauto
Apr 14 2010, 12:36 PM | In Reply To Sorrow
Post
#4
![]() 3rd Gear Posts: 457 Warn:
as from your description,it seem to be compressor issue or compressor valve issue.i would suggest you send to air con specialist. for Wish compressor is about 700 to 800 bucks.but for only valve change,it could be 250plus bucks.Any WS should know the issue as it is common issue.
Yuan
Apr 14 2010, 02:28 PM | In Reply To Chiangauto
Post
#5
![]() 2Fast2Furious Posts: 22,436 Warn:
as from your description,it seem to be compressor issue or compressor valve issue.i would suggest you send to air con specialist. for Wish compressor is about 700 to 800 bucks.but for only valve change,it could be 250plus bucks.Any WS should know the issue as it is common issue. Could it be an aircon filter issue? I realise that aircon filter is something which a lot of people fails to change or maintain it. -------------------- |Genuine Original Equipment Manufacturer (OEM) Parts-Specifications|Stoptech Street Performance Brake Pads|3M Crystalline Solar Film|Sachs Race Engineering (SRE) Kit|Orange TPMS|RCD 510-Navigation System|Battery Checker|Itronics ITB-100HD| |
Bavarian
Apr 14 2010, 02:30 PM | In Reply To Blackyv
Post
#6
![]() 2Fast2Furious Posts: 24,223 Warn:
just ask for my bil... he is driving a wish... recently, theaircon is not functioning normally... when driving or car moving,,... aircon is cool.. normal... but when stationary, the aircon suddenly will become not coold and blow hot air sometimes....... what's wrong??... he asked a ws and that mechanics said dont know where blocked and need to strip open everything to check and that cost $700-$800 bucks.... i suspect that's bs ..if chocked, it will not be cool, right?.. and not intermittent... anyone has such similar problem before??... Its normal I think... When I open window, car not moving also not cold. Must move then got cold. Has been like dat for the last 30 years. -------------------- 如果借钱不用还那该多好! |
Mustank
Apr 14 2010, 02:50 PM | In Reply To Blackyv
Post
#7
NOS-ed Posts: 15,590 Warn:
Bro,
i suspect is aircon fan (in front of aircon radiator) spolit. to check if this is so, you just open up the bonnet. engine must be switched on. aircon also switch on see whether the fan is moving. if fan is not moving, using a mallet or the handle bar of a screw driver to gentlty wack the motor portion of the fan. do not hit the blade of the fan if the fan motor is spoilt, generally by wacking the motor a bit, the motor will move again but not for long. you need to change the motor asap. for the musso aircon fan motor, is $70. ownself change is $22 + time |
Accord
Apr 14 2010, 02:53 PM
Post
#8
3rd Gear Posts: 265 Warn:
For your case, 80% likely to be faulty fan motor of the condenser:)
Blackyv
Apr 14 2010, 04:31 PM
Post
#9
thxs for all those valuable info...
Zyrofillica
Apr 14 2010, 04:56 PM
Post
#10
6th Gear Posts: 4,666 Warn:
might wanna check ur aircon clutch. Same problem for me, car moving no problem very very cold aircon. Once stuck in jam or idling for too long, aircon stops working and blows hot air. If parked for short while and come back while engine is still warm/hot, aircon does not work. only if car left overnight or long time and engine has cooled, aircon works on startup. Mech diagnosed aircon clutch overheating. reconditioned unit is around 300+ for my model. looks like 5th year of car ownership all the problem really start lol~
Yattokame
Apr 14 2010, 05:15 PM
Post
#11
![]() 6th Gear Posts: 3,306 Warn:
Mine was a simple case of weak battery
when driving, aircon cold. Else, it's hot. -------------------- swift1.0/sunny1.6/sonata2.0/156JTS/Brera3.2V6/MINI cooper S cabrio/Grand Picasso/S300L |
Zeee
Apr 14 2010, 05:30 PM
Post
#12
1st Gear Posts: 93 Warn:
what about this: normal city & expressway driving in singapore, air cond is cool. however, at extended period of time travelling on m'sia north-south highway at a constant 150 kph, air cond blows hot air..., but when slowed down to 80-90 kph, it blows cool air. could it be air cond thermostat issue, or something else? |
Mustank
Apr 14 2010, 05:42 PM | In Reply To Zeee
Post
#13
yours sound like some aircon man exam question
anyhow piang answer: compressor should be working since city and sg higyway driving got cold air fan should be working if stationary got cold air belt running the compressor should be ok because city and sg higyway driving got cold air and stationary got cold air guess: maybe conti car, got heater one. car going at 150 kph, maybe radiator water too hot liao. all the heat transferred to the heater. need to re-route radiator water to bypass heater. maybe aircon pipe got no heat shield. |
Contax
Apr 14 2010, 05:56 PM | In Reply To Mustank
Post
#14
the last time I drove to penang , 4 hours into the journey , the aircon start to emit hot air and 'spitting' water out from the vent.
Realise after a while that I have read somewhere that this is call "aircon freeze" , switch off the aircon and continue driving and everything back to normal after an hour when I switch it back on. |
York
Apr 14 2010, 05:59 PM
Post
#15
5th Gear Posts: 1,186 Warn:
could be ur air cond compressor clutch assembly magnet boh lart liao...modern aircon tech will tell u to change the compressor.....if u can meet an old bird aircon mech...he will knock the front metal plate to force the pulley nearer for better contact it 'cluck' again when engine idling.... will last for a couple of months more.
-------------------- Da'blo my "boh lui lang" MPV |
Tohto
Apr 14 2010, 06:03 PM | In Reply To Zeee
Post
#16
![]() 6th Gear Posts: 2,888 Warn:
what about this: normal city & expressway driving in singapore, air cond is cool. however, at extended period of time travelling on m'sia north-south highway at a constant 150 kph, air cond blows hot air..., but when slowed down to 80-90 kph, it blows cool air. could it be air cond thermostat issue, or something else? My previous ride had this problem also. Switch off aircon driving for 10mins and aircon back to normal. But it will become hot again after another hour of high speed driving. At rest area, open the bonnet and check and saw the aircon piping with froze.. Send to ComfortDegro and they can't find the cause. This post has been edited by Tohto: Apr 14 2010, 06:07 PM |
Yoongf
Post
#17
4th Gear Posts: 525 Warn:
Used to have the same symptom. Is faulty aircon fan at the condenser.
Blackyv
Apr 14 2010, 10:30 PM
Post
#18
ok, bil checked the aircon fan... with engine running, aircon running, the fan is moving.. so, can i say aircon fan faulty is out?... next nearest possibility is fault compressor clutch?..uumm....
Yuan
Apr 14 2010, 11:15 PM | In Reply To Blackyv
Post
#19
ok, bil checked the aircon fan... with engine running, aircon running, the fan is moving.. so, can i say aircon fan faulty is out?... next nearest possibility is fault compressor clutch?..uumm.... Go to aircon specialized workshops like Mark Cool to get it diagnosed..... -------------------- |Genuine Original Equipment Manufacturer (OEM) Parts-Specifications|Stoptech Street Performance Brake Pads|3M Crystalline Solar Film|Sachs Race Engineering (SRE) Kit|Orange TPMS|RCD 510-Navigation System|Battery Checker|Itronics ITB-100HD| |
Fcw75
Apr 15 2010, 12:41 AM
Post
#20
Turbocharged Posts: 9,827 Warn:
Yep, Markcool or Tomika is your BIL best bet. No point guessing here and there.
East or West, go Tomika. North, go Markcool. |
Similar Threads
| Topic Title | Forum | Replies | Last Action | ||
Kurt Tay: Singapore's latest superstar | Lite & EZ | 94 | Today, 12:12 AM Last post by: Jman888 |
Mystery of US engineer's death in SG | Lite & EZ | 95 | Yesterday, 11:46 PM Last post by: Atonchia |
Car aircon got water flowing sound | General Car Discussion | 17 | Yesterday, 10:06 PM Last post by: Fcw75 |
SAF's Last chewing Gum | Football Channel | 6 | Yesterday, 06:59 PM Last post by: Mysportwish |
Malaysian police are after S'pore-registered vehicles in JB | General Car Discussion | 164 | Yesterday, 02:29 PM Last post by: Ghostrider |
| Guidelines – Terms Of Service – About Us – Moderators | Lo-Fi Version Time is now: 22nd May 2013 - 04:24 AM
