IPB
Welcome Guest ( Log In | Register )
Keyword: Search Button
Advanced Search
Most Viewed Discussions
Most Active Discussions
3 Pages V   1 2 3 >
Reply to this topicStart new topic
Panhard
Panhard post Apr 23 2010, 10:41 AM
Post #1
4th Gear
Warn: -----
should I change my stock rubber tyre valves to the metal type, any difference, is it better???
Go to the top of the page
+Quote Post
Help1
Help1 post Apr 23 2010, 10:58 AM
Post #2
6th Gear
Warn: -----
what is your ride, your rim model n tyre?
My favorite site
+Quote Post
0_Kewl
0_Kewl post Apr 23 2010, 11:14 AM   |  In Reply To Panhard
Post #3
Clutched
Warn: -----
Metal looks nicer for sure but whether it is better is arguable. There are still rubber components when using the metal valves, which are necessary in order to have proper air seal. So you still need to change these metal valves every so often. Problem is, it takes a little longer to change since you need to screw it down properly.
Benefits of an all rubber valve is that it is quick to change and easy to change so it does get changed more often than the metal ones...which unless you specify to the tyre shop, most probably wont get changed ever! And this would not be a good thing.
This post has been edited by 0_Kewl: Apr 23 2010, 11:16 AM
+Quote Post
Panhard
Panhard post Apr 23 2010, 11:17 AM   |  In Reply To Help1
Post #4
4th Gear
Warn: -----
QUOTE (Help1 @ Apr 23 2010, 10:58 AM) *
its stock alloy rims 195/65/15"
+Quote Post
Octopus
Octopus post Apr 24 2010, 12:04 PM   |  In Reply To Panhard
Post #5
6th Gear
Warn: -----
Some valves may looks like metal, but its just a metal sleeve slide over the rubber valve body.
+Quote Post
Fcw75
Fcw75 post Apr 24 2010, 12:47 PM
Post #6
Warn: -----
The real metal valve has a nut on it. The one with the metal sleeve doesn't have. Quite easy to differentiate.
+Quote Post
Panhard
Panhard post Dec 21 2010, 05:47 PM
Post #7
4th Gear
Warn: -----
is it more for cosmetic reasons or the metal valves are more durable & not likely
to leak so easily.....
+Quote Post
Unfair
Unfair post Dec 21 2010, 05:53 PM
Post #8
5th Gear
Warn: X----
Tire caps make no difference in practicality.
Just looks.
But looks might tempt pple to steal your caps....
Pepi1802us (For Fifa13)
+Quote Post
Yeobh
Yeobh post Dec 21 2010, 06:50 PM
Post #9
Supercharged
Warn: -----
Rubber tubless valves are snapped into position by a level tool. Metal tubless valves are hold to the rim by thread stem and lock nut
This post has been edited by Yeobh: Dec 21 2010, 06:51 PM
Attached File(s)
Attached File  Tubeless_Valve_Rubber_.jpg ( 30.67K ) Number of downloads: 43
Visit My Facebook for the latest automotive breaking news & innovative specialty tools.
+Quote Post
Roberttan
Roberttan post Dec 22 2010, 10:05 AM
Post #10
4th Gear
Warn: -----
i prefer the rubber and the shorter the possible
anyway mine looks more like TR76E neither metal nor rubber
+Quote Post
Wolfy3769
Wolfy3769 post Dec 22 2010, 10:21 AM
Post #11
4th Gear
Warn: -----
I think the metal or rubber... it mainly for the cosmetic (to match ur rim)..
frankly.. i will use the rubber one... it will be change whenever i change a new tire... so the rubber hardening will not affect the seal.
also my one i use was like hybrid... the base was all rubber.. but the stem was metallic... not those nut lock type.
+Quote Post
Lectrosphere
Lectrosphere post Dec 22 2010, 10:26 AM   |  In Reply To Yeobh
Post #12
6th Gear
Warn: -----
QUOTE (Yeobh @ Dec 21 2010, 06:50 PM) *
the whole metal valve one looks neat, any idea where to get it? so far the tyre shops i went to all don't have wink.gif
+Quote Post
Roberttan
Roberttan post Dec 22 2010, 02:04 PM   |  In Reply To Lectrosphere
Post #13
4th Gear
Warn: -----
QUOTE (Lectrosphere @ Dec 22 2010, 10:26 AM) *
why bother about metal valve, if you end up getting 1 and could be old stock valve (rubber seal also hardened)
it will only give you more problem in the near future.
seems like some people put cosmetic in prior to safety
+Quote Post
Cephas
Cephas post Mar 19 2012, 03:04 PM
Post #14
3rd Gear
Warn: -----
Changed my cracked rubber valve to metal type. Look like TR -48E in the above picture. The crack was scary. Metal won't have this kind of issue. Changed at S$10 x 4pcs.
Lambo with open pod....weeeee
+Quote Post
Cephas
Cephas post Mar 19 2012, 04:29 PM   |  In Reply To Cephas
Post #15
3rd Gear
Warn: -----
QUOTE (Cephas @ Mar 19 2012, 03:04 PM) *
+ inclusive of nitrogen top-up.
+Quote Post
Dafansu
Dafansu post Mar 19 2012, 06:54 PM
Post #16
6th Gear
Warn: -----
metal look nicer but then higher chance to get stolen
+Quote Post
Grx80
Grx80 post Mar 19 2012, 07:20 PM   |  In Reply To Cephas
Post #17
1st Gear
Warn: -----
where did you change yours? I need to change one of my metal tyre valve too.
Thanks!
+Quote Post
Cephas
Cephas post Mar 19 2012, 09:35 PM   |  In Reply To Dafansu
Post #18
3rd Gear
Warn: -----
QUOTE (Dafansu @ Mar 19 2012, 06:54 PM) *
how exactly to steal it when it is tightened from inside of the rim?
+Quote Post
Cephas
Cephas post Mar 19 2012, 09:37 PM   |  In Reply To Grx80
Post #19
3rd Gear
Warn: -----
QUOTE (Grx80 @ Mar 19 2012, 07:20 PM) *
Thanks!
west side...if convenient, i pm you the shop name.
+Quote Post
Stanong11
Stanong11 post Mar 19 2012, 10:26 PM   |  In Reply To Cephas
Post #20
3rd Gear
Warn: -----
QUOTE (Cephas @ Mar 19 2012, 09:35 PM) *
I guess he meant the tire valve cap. The external ones. Used to cover the valves.
+Quote Post
3 Pages V   1 2 3 >
Similar Threads
    Topic Title Forum Replies Last Action
No New Posts   Tyre For SUV Tyres and Rims 22 23rd May 2013 - 07:17 AM
Last post by: Newdrive
No New Posts   Best underdog tyre, Nokian Z G2? Tyres and Rims 51 18th May 2013 - 12:04 PM
Last post by: Micb
No New Posts   Tyre Upgrade from XM2 Tyres and Rims 51 15th May 2013 - 02:19 PM
Last post by: Lewis042
No New Posts   Topic has attachmentsTyre patch Tyres and Rims 111 14th May 2013 - 08:21 PM
Last post by: Roberttan
No New Posts   What is the recommended tyre??? Tyres and Rims 11 27th April 2013 - 04:34 PM
Last post by: Marlboro79
2 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
0 Members:
GuidelinesTerms Of ServiceAbout UsModerators Lo-Fi Version     Time is now: 26th May 2013 - 11:29 AM RSS
