Luxury Car Option Available as Aftermarket
Amsyl
TyreDog TPMS Tyre Pressure Monitoring System
http://sgauto.wordpress.com/tpms/
2009 Winner of SEMA Show, New Product Award
TPMS Tyre Pressure Monitoring System was previously only available on luxury sedans such as Mercedes S-Class, BMW 7-Series, Lexus and subsequently made standard on models with runflat tyres. This luxury feature is now available for your car whether a family sedan, MPV or a high performance car or even for track days.
External Sensors
The TPMS is a Wireless based system that remotely measures both tyre pressure and temperature. This system automatically warns drivers should the tyre pressure or temperature go pass a set parameter that is programmable. This gives the driver ample warning before any drastic situation happens such as losing control of the vehicle due to a flat tyre or a tyre being torn to shreds because the driver was unaware of a flat tyre. The cost of replacing an expensive shredded tyre or rim is already a ROI Return On Investment for this product.
General Features
Pressure alerts when tyre pressure below or above the setting range
Temperature alerts when tyre temperature over the setting range
Easy read out graphic icon
Real time monitoring tyre pressure & tyre temperature.
Increase tyre expectancy
Improve fuel consumption
Increase driving safety and reduced braking distance.
Reduce CO 2
Reduce rubber wastage
Instantly detects air leakage and tyre over heat
Easy to installation (X-type)
High accuracy
Amber Backlight
Not affected by bumpy roads
User can preset the pressure and temperature range.
Uses 2 x AAA Batteries or Cigarette Lighter Plug
Accuracy: +/- 0.5 psi
Operates even when the car is stationary
External Sensor, Anti Theft
The TD1000 supports four tyres and users can install this system without any mechanical knowledge and with easy to read graphic interface LCD monitor. It is the best solution for drivers to keep track of the tyres condition and maintain tyres in tiptop shape .
Installation
TYREDOG
