| Joint membership: You may login to MyCarForum using your sgCarMart username & password |
Green_carnation
Jul 2 2010, 10:24 PM
Post
#1
![]() 6th Gear Posts: 3,134 Warn:
anyone has such experience? what am i to do now? anyway of salvaging it? or just hv to send for repair?
Bystander50
Jul 2 2010, 10:33 PM | In Reply To Green_carnation
Post
#2
6th Gear Posts: 3,022 Warn:
anyone has such experience? what am i to do now? anyway of salvaging it? or just hv to send for repair? Iphone is a bit problematic compared to other phones. Usually if drop into water, immediately remove the battery to prevent shorting. Next if you can, open up the phone and clean up all the water. If you ain't able to do that, then just leave the phone on open air with wind/fan blowing. 1-2 weeks later, all moisture should have dried up and you can safely use the phone. Iphone and most expensive phones have moisture indicators which is a white round sticker. The dye on the sticker will turn it red/orange when it comes into contact with moisture, effectively voiding your warrenty. What you can do now is to wait for 1-2 weeks and then power on your phone to see if it works again. |
Green_carnation
Jul 2 2010, 10:40 PM | In Reply To Bystander50
Post
#3
Iphone is a bit problematic compared to other phones. Usually if drop into water, immediately remove the battery to prevent shorting. Next if you can, open up the phone and clean up all the water. If you ain't able to do that, then just leave the phone on open air with wind/fan blowing. 1-2 weeks later, all moisture should have dried up and you can safely use the phone. Iphone and most expensive phones have moisture indicators which is a white round sticker. The dye on the sticker will turn it red/orange when it comes into contact with moisture, effectively voiding your warrenty. What you can do now is to wait for 1-2 weeks and then power on your phone to see if it works again. Wow.. thanks bro.. if send for repair at service centre? can be salvaged? They probably will also blow dry? Problem is i cant open up the phone to blow dry.. |
Blackyv
Jul 2 2010, 10:45 PM
Post
#4
![]() NOS-ed Posts: 10,531 Warn:
I like apple juice......hehehe....
SimonTan
Jul 2 2010, 10:52 PM
Post
#5
Turbocharged Posts: 8,888 Warn:
I think to let it dry over a week is ur only choice!
Pray that the circuits inside are not shorted and damaged! How to send for repair since the water indicator will tell Apple it was water Damages! Look on the bright side, it's a sign foe u to get the iphone4. |
5936
Jul 2 2010, 10:55 PM | In Reply To Blackyv
Post
#6
![]() 6th Gear Posts: 3,801 Warn:
Check the earphone jacks and the USB jack. Red band may appear if kena water.
Agent may offer you factory rebuilt handset. |
Green_carnation
Jul 2 2010, 10:57 PM | In Reply To SimonTan
Post
#7
I think to let it dry over a week is ur only choice! Pray that the circuits inside are not shorted and damaged! How to send for repair since the water indicator will tell Apple it was water Damages! Look on the bright side, it's a sign foe u to get the iphone4. hmm my 3gs less than a yr old.. |
Armvalkyrie
Jul 2 2010, 11:02 PM
Post
#8
1st Gear Posts: 70 Warn:
hi,
i had a flooded iphone in a bag due to water bottle leak.... quickly off it n let it dry under sun..... after half a day, on it back.... running without speaker sound... after a day or 2, sound came back... now the onli fault is that the battery inidicator doesnt show properly, the iphone off by itself if not charged.... no red warning... no other issues.... :) |
Stevel
Jul 2 2010, 11:04 PM | In Reply To Green_carnation
Post
#9
2nd Gear Posts: 236 Warn:
hmm my 3gs less than a yr old.. will cost u a fair bit to get the refurbished phone, think about $300-$400 as water damage is not covered by warranty. -------------------- Better To Keep Quiet & Be Considered A Fool Than To Speak & Remove All Doubts |
Chickenbackside
Jul 2 2010, 11:08 PM
Post
#10
6th Gear Posts: 2,621 Warn:
Put it in a bucket of rice.
Bystander50
Jul 2 2010, 11:10 PM | In Reply To Green_carnation
Post
#11
Wow.. thanks bro.. if send for repair at service centre? can be salvaged? They probably will also blow dry? Problem is i cant open up the phone to blow dry.. Don't bother sending to apple. If u can't wait, then send to ur neighbourhood hp shop, see wat they can offer. If u feel u r confident enough, no harm anyway coz ur phone might already be dead, go youtube n search, there are videos teaching u step by step how to "stand by iphone". I dropped my 6110 navigator into water b4. Immediately removed the battery n dismentled the phone. normal phone function works, but the gps was dead. I used it for another 6 mths b4 getting a E71. |
Babyt
Jul 2 2010, 11:14 PM
Post
#12
![]() Supercharged Posts: 7,174 Warn:
just buy another phone lor..can easily get smartphones less than 1k.
Green_carnation
Jul 2 2010, 11:41 PM | In Reply To Armvalkyrie
Post
#13
hi, i had a flooded iphone in a bag due to water bottle leak.... quickly off it n let it dry under sun..... after half a day, on it back.... running without speaker sound... after a day or 2, sound came back... now the onli fault is that the battery inidicator doesnt show properly, the iphone off by itself if not charged.... no red warning... no other issues.... :) wow.. nice to hear that.. hopefully mine will be fine.. i just leave the ait from my lappy to blow it.. at some instance the light came on.. i saw the logo.. and how wet the screen was.. |
Green_carnation
Jul 2 2010, 11:43 PM | In Reply To Stevel
Post
#14
Green_carnation
Jul 2 2010, 11:45 PM | In Reply To Bystander50
Post
#15
Don't bother sending to apple. If u can't wait, then send to ur neighbourhood hp shop, see wat they can offer. If u feel u r confident enough, no harm anyway coz ur phone might already be dead, go youtube n search, there are videos teaching u step by step how to "stand by iphone". I dropped my 6110 navigator into water b4. Immediately removed the battery n dismentled the phone. normal phone function works, but the gps was dead. I used it for another 6 mths b4 getting a E71. yeah i think the repair shops shud not be able to do much ya.. will wait n see if it dries up almost completely will still be functionable.. |
Green_carnation
Jul 2 2010, 11:46 PM | In Reply To Babyt
Post
#16
Sony
Jul 2 2010, 11:56 PM | In Reply To Green_carnation
Post
#17
![]() 2Fast2Furious Posts: 21,690 Warn:
Put it in an air tight contain with rice as suggested by chickenbackside. it work and work very well.
Daniel3
Jul 3 2010, 12:02 AM | In Reply To Green_carnation
Post
#18
1st Gear Posts: 57 Warn:
Bystander50
Jul 3 2010, 12:04 AM | In Reply To Daniel3
Post
#19
Daojeff
Jul 3 2010, 12:05 AM
Post
#20
Novice Posts: 19 Warn:
wait for iphone 4!!! lol..
Similar Threads
| Topic Title | Forum | Replies | Last Action | ||
Wax mixed into water to wash car | Detailing | 32 | Today, 08:37 PM Last post by: Vivant511 |
Lite & EZ | 55 | Today, 03:43 PM Last post by: Fitvip |
Used Car dealers Feeling The Heat Liao! | General Car Discussion | 864 | Today, 12:40 AM Last post by: Meanmachine |
Lite & EZ | 71 | Yesterday, 12:46 PM Last post by: Pisces69 |
Products & Services | 776 | Yesterday, 11:53 AM Last post by: Beacon_Enterprise |
| Guidelines – Terms Of Service – About Us – Moderators | Lo-Fi Version Time is now: 25th May 2013 - 08:40 PM
