Jonbummer Neutral Newbie July 13, 2010 Share July 13, 2010 (edited) hi bros just got my ride. a used Sunny, so just questions (silly as some of it may seems) 1. alarm. does the stock alarm trigger a sound from the car? cos now i lock, unlock, and even depressing the 'car finder' the car will only blink its signal lights. i just wonder if the 'horn' linked to the alarm is faulty. 2. since mine's a 2006 Sunny, i believed it's a FL version. is the headlight H1 or H4? confused.... 3. anywhere i can find a replacement for the compartment at the centre of the dashboard? the spring seems to be loose liao, meanin it can remain open. dun think it supposed to be like this, rite? thanks in advance... and apologised again if my qnn is 'strange' cos can't find answer Edited July 13, 2010 by Jonbummer ↡ Advertisement Link to post Share on other sites More sharing options...
BoneStock 5th Gear July 13, 2010 Share July 13, 2010 hi bros just got my ride. a used Sunny, so just questions (silly as some of it may seems) 1. alarm. does the stock alarm trigger a sound from the car? cos now i lock, unlock, and even depressing the 'car finder' the car will only blink its signal lights. i just wonder if the 'horn' linked to the alarm is faulty. 2. since mine's a 2006 Sunny, i believed it's a FL version. is the headlight H1 or H4? confused.... 3. anywhere i can find a replacement for the compartment at the centre of the dashboard? the spring seems to be loose liao, meanin it can remain open. dun think it supposed to be like this, rite? thanks in advance... and apologised again if my qnn is 'strange' cos can't find answer 1) Yes, lock is one beep, unlock 2 beeps. 2) no idea 3) Can try Fong Tat. If you prefer refurbished can try the scrap yards are woodlands park e Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie July 13, 2010 Share July 13, 2010 (edited) 1) Alarm : The previous owner must have activate the silent mode. Just press both the Lock/Unlock button together to return to normal mode. FYI, Nissan OEM alram is made by Wheels and the model is HC-333. Nothing fantastic about this alarm model and you can get the whole set for $50 @ sunshine plaza. 2) Headlight : H1 3) Centre console : Try rent a Sunny and swapped it over. Edited July 13, 2010 by Godfinger Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie July 13, 2010 Author Share July 13, 2010 (edited) thanks bros ! Godfinger... u are evil... i like! hahaha but not going to do that la and will try to see if i can revert it to the normal mode. cheers Edited July 13, 2010 by Jonbummer Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie July 14, 2010 Author Share July 14, 2010 hi again... any idea of how much gear oil is required for the manual gearbox? thanks Link to post Share on other sites More sharing options...
Seanboi 1st Gear July 14, 2010 Share July 14, 2010 hi again... any idea of how much gear oil is required for the manual gearbox? thanks Bro u need 3 quarts. Link to post Share on other sites More sharing options...
Albeniz Turbocharged July 14, 2010 Share July 14, 2010 (edited) hi bros just got my ride. a used Sunny, so just questions.... thanks in advance... and apologised again if my qnn is 'strange' cos can't find answer What happened to your presea, sent to scrap? Is the FC better than your previous ride? Thinking of changing too. Edited July 14, 2010 by Albeniz Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie July 14, 2010 Author Share July 14, 2010 thanks Seanboi! Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie July 14, 2010 Author Share July 14, 2010 hi hi i sold it off via sgcarmart. i think the FC of the sunny is better. but will need to monitor. overall happy with the Sunny. although i maintained the Presea quite well, it's nonetheless a 19 year old ride this sunny being only 4 years gave a more comfortable drive and ride Link to post Share on other sites More sharing options...
Gordon011 Neutral Newbie October 14, 2010 Share October 14, 2010 Hi, I would like to ask when the O/D OFF is light up... Is the O/D on/off? I am confuse.... Link to post Share on other sites More sharing options...
Ben5266 Supercharged October 14, 2010 Share October 14, 2010 Hi, I would like to ask when the O/D OFF is light up... Is the O/D on/off? I am confuse.... OD OFF light is up means OD is off. It is so call 3rd gear. When OD is ON, or no light, it is 4th gear. Link to post Share on other sites More sharing options...
Gordon011 Neutral Newbie October 14, 2010 Share October 14, 2010 OD OFF light is up means OD is off. It is so call 3rd gear. When OD is ON, or no light, it is 4th gear. Ben, Thank you... Can I ask u something... When i travelling at 100km/h... and I release the accelerate and it start slow down to 80 km/h veri fast... Is there anything i can install to help on it? Link to post Share on other sites More sharing options...
Gordon011 Neutral Newbie October 14, 2010 Share October 14, 2010 (edited) 1) Yes, lock is one beep, unlock 2 beeps. 2) no idea --- mine is H1 3) Can try Fong Tat. If you prefer refurbished can try the scrap yards are woodlands park e Edited October 14, 2010 by Gordon011 Link to post Share on other sites More sharing options...
Ben5266 Supercharged October 14, 2010 Share October 14, 2010 Ben, Thank you... Can I ask u something... When i travelling at 100km/h... and I release the accelerate and it start slow down to 80 km/h veri fast... Is there anything i can install to help on it? I think this has to do with the gear ratio for the AT. I am not sure on how to fix it. Also, you might want to check your break. Just in case the pad is touching the disc. ↡ Advertisement Link to post Share on other sites More sharing options...
2021 3rd Generation Nissan Note (E13)
Nissan QashQai 2014 Part 2
Top 5 questions to ask every used car dealer
Nissan Teana Experience
2023 Tan Chong Car Challenge
