MacDuck 1st Gear June 18, 2011 Share June 18, 2011 http://www.michelin.com.my/tyre/patetailIs it available in SGP yet? ↡ Advertisement Link to post Share on other sites More sharing options...
SimonTan 2nd Gear June 19, 2011 Share June 19, 2011 Looks like a good tyre. I like tyres with lesser groves. This one got only three longitudinal groves....less void space...more rubber blocks. I think most tyres now got the four groves design. Link to post Share on other sites More sharing options...
Passion 5th Gear June 19, 2011 Share June 19, 2011 Not much groove got as enough grip a not? Link to post Share on other sites More sharing options...
Help1 1st Gear June 20, 2011 Share June 20, 2011 XM2 not yet arrive Link to post Share on other sites More sharing options...
Watwheels Supersonic June 20, 2011 Share June 20, 2011 Yes. I saw at the "cinema" tire shop. What size available I did not look. Link to post Share on other sites More sharing options...
Triton Neutral Newbie July 20, 2011 Share July 20, 2011 The XM2 has arrived. I was looking to get the XM1 but was told that the model was discontinued and was offered the XM2 instead. The wider rain groove pattern seems to indicate a better wet handling. It cost $125 per piece for the 185/70R14 88H version. Didn't do enough kilos to give any meaningful review, though my initial impression is that it is pretty quiet and smooth. My previous set was a Falken FK-07U which has excellent dry grip but does poorly during hard/sudden braking in the wet (causing ABS to kick in frequently). Hopefully the XM2 can achieve a better harmony between dry/wet performance. Link to post Share on other sites More sharing options...
Help1 1st Gear July 20, 2011 Share July 20, 2011 at the moment XM2 comes in limited sizes as there are outstanding stocks in XM1 Link to post Share on other sites More sharing options...
Jeffc 5th Gear July 21, 2011 Share July 21, 2011 The XM2 has arrived. I was looking to get the XM1 but was told that the model was discontinued and was offered the XM2 instead. The wider rain groove pattern seems to indicate a better wet handling. It cost $125 per piece for the 185/70R14 88H version. Didn't do enough kilos to give any meaningful review, though my initial impression is that it is pretty quiet and smooth. My previous set was a Falken FK-07U which has excellent dry grip but does poorly during hard/sudden braking in the wet (causing ABS to kick in frequently). Hopefully the XM2 can achieve a better harmony between dry/wet performance. Last year I changed XM1 same profile as yours at $80 per pcs. XM2 so ex? Link to post Share on other sites More sharing options...
Triton Neutral Newbie July 21, 2011 Share July 21, 2011 Last year I changed XM1 same profile as yours at $80 per pcs. XM2 so ex? Commodities prices has skyrocketed over the past year hence price increase is no surprise though I must say it's pretty expensive. Anyway the price includes replacement of the air valves for all four rims that was not changed since i bought the car. After having driven it a little more, the tyre do really have significantly lower rolling resistance. This can be easily felt when driving off from any carpark lot.. You just tap the gas pedal a little and the car will the glides out very smoothly even when you turn the steering to make the 90deg turn. Only time will tell whether it will translate into better FC. Having said that, I hope it could still maintain good traction in high-speed corners. Link to post Share on other sites More sharing options...
Tasman Neutral Newbie July 21, 2011 Share July 21, 2011 just check prices last week in JB. 185/55R/15 @ SGD103per pc including balancing and alignment. Should be lower with negotiation. Understand cheaper in Klang only SGD97/ pc. Will visit klang next month and will change 4 pcs there. Link to post Share on other sites More sharing options...
Toxic118 Clutched July 22, 2011 Share July 22, 2011 just check prices last week in JB. 185/55R/15 @ SGD103per pc including balancing and alignment. Should be lower with negotiation. Understand cheaper in Klang only SGD97/ pc. Will visit klang next month and will change 4 pcs there. made in Thailand? Link to post Share on other sites More sharing options...
SimonTan 2nd Gear July 22, 2011 Share July 22, 2011 I love the new three grooves design. Less void, more rubber on the road. Four grooves are excessive, which seems to be the common design. Link to post Share on other sites More sharing options...
Triton Neutral Newbie July 22, 2011 Share July 22, 2011 (edited) made in Thailand? Well the ones I've got here are Made in Thailand. Edited July 22, 2011 by Triton Link to post Share on other sites More sharing options...
Patricklyb Clutched July 22, 2011 Share July 22, 2011 Last year I changed XM1 same profile as yours at $80 per pcs. XM2 so ex? sometimes has to see where it is made! i bought my 225/45/17 mic ps3@$250pc made in spain but made in thailand same spec $170/-! so what the different? try you will know! Link to post Share on other sites More sharing options...
Dldm Neutral Newbie July 25, 2011 Share July 25, 2011 pattern nearly same with Conti EcoContact3 Link to post Share on other sites More sharing options...
Stonesix 1st Gear August 5, 2011 Share August 5, 2011 The XM2 has arrived. I was looking to get the XM1 but was told that the model was discontinued and was offered the XM2 instead. The wider rain groove pattern seems to indicate a better wet handling. It cost $125 per piece for the 185/70R14 88H version. Didn't do enough kilos to give any meaningful review, though my initial impression is that it is pretty quiet and smooth. My previous set was a Falken FK-07U which has excellent dry grip but does poorly during hard/sudden braking in the wet (causing ABS to kick in frequently). Hopefully the XM2 can achieve a better harmony between dry/wet performance. Hi Triton, care to share where did you change your XM2? Price inclusive of balancing, valve cap, free lifetime rotation? Link to post Share on other sites More sharing options...
Triton Neutral Newbie August 5, 2011 Share August 5, 2011 (edited) Hi Triton, care to share where did you change your XM2? Price inclusive of balancing, valve cap, free lifetime rotation? San Ming Huat Tyre & Battery 784 Upper Bukit Timah Road Singapore 678127 Tel: 6760-6753 Price includes balancing, replacing valves/caps but no free tyre rotation though. Just an update on my tyres after running just over 1000km. Good dry grip and seems to be pretty good wet grip as well. I have yet to drive in torrential rain to find out how well the tyre could slice through the puddles. The very low resistance could take a little getting used to becos even if you lifted the pedal, the car can still maintain at speed for quite awhile... so do judge your braking distance accordingly. Overall I am very pleased with the XM2. Edited August 5, 2011 by Triton Link to post Share on other sites More sharing options...
Stonesix 1st Gear August 7, 2011 Share August 7, 2011 Thanks Triton... Went to some tyre shops near at First centre to look for XM2, was recommend to use Firestone and Marangoni Verso, said no need to waste money on some branded tyre, which was due to their advetising that led these branded tyre to be expensive. Doubt about their recommendation, any bro here have any idea how were they perform? Not cheap though, for price in the range $120 ~ $130/pc. However, package incl. balancing, valve cap, lifetime rotation and GST. ↡ Advertisement Link to post Share on other sites More sharing options...
Michelin Pilot Sport 5 Improves On The Best Tire In The World
Continental ExtremeContact Sport 02 Challenges Michelin Pilot Sport 4S
Michelin Pilot Sport S5
Michelin Primacy 4 vs Continental Premium Contact 6 vs Goodyear F1A5
