IPB
Welcome Guest ( Log In | Register )
Keyword: Search Button
Advanced Search
Most Viewed Discussions
Most Active Discussions
2 Pages V   1 2 >
Reply to this topicStart new topic
Ahbao999
Ahbao999 post Aug 11 2011, 10:14 AM
Post #1
3rd Gear
Warn: -----
Dear car owner,
please kindly share your experience using NGK or DENSO Idirium Spark Plug for your car.
how is the respond, lifespend, fuel consumption and price.
share your car make , model and plug model as well.
thanks and regards
Go to the top of the page
+Quote Post
Meanmachine
Meanmachine post Aug 11 2011, 11:17 AM   |  In Reply To Ahbao999
Post #2
5th Gear
Warn: -----
[quote name='Ahbao999' date='Aug 11 2011, 10:14 AM' post='3930346']
Dear car owner,
thanks and regards
Im using Denso Uridium FK20HBR11, didn't occur to me that it was really good after I call my SE on reaching certain mileage on what to look out for in term of servicing.
He say, about time to change ' Sparkies ', so I took his timely advice and changed last week, my mechanic told me that my sparkies was still in good condition, not black at all, and in good condition, anyway, I 've clocked another 10K mileage & it's about time too.
Verdict, the model plug has no misfiring or any mishaps during my ride and found it very reliable, always stick to AD manual, try not to change to other models unless necessary, coz it was distributor's requirement and they have met the highest test , that goes for tyre, rims and battery ( wear and tear items )
P/s: it is not the car we drive say about us, it's the driver has a part to play too.
Disclaimer: Some content may not be accepted by all as we are not trained counseller / adviser, we seek your tolerant. My advice is based on experiences / exposure/s committed to give an honest & direct answer, no profanity & accusation to be taken of any kind, in an event that it misfired, it should be taken as a pinch of salt. Thank you !
+Quote Post
Meanmachine
Meanmachine post Aug 11 2011, 11:19 AM
Post #3
5th Gear
Warn: -----
Oh , I've missed on your enquiry on D Iridium, mine is Uridium, trust it does add to your knowledge as well.
Cheers!
+Quote Post
Yuan
Yuan post Aug 11 2011, 02:24 PM   |  In Reply To Ahbao999
Post #4
2Fast2Furious
Warn: -----
QUOTE (Ahbao999 @ Aug 11 2011, 10:14 AM) *
Dear car owner,
thanks and regards
I have used Denso Iridium plugs before and I was told that they can last 40k mileage.
At 20k mileage, mechanic took out and checked and realized that the plugs need to be replaced.
Went back to copper and partly also due to the reason that I do not like the idea of using the plugs too long.
I was on voltronic plugs before that. Supposed to last 80k or 100k. I used them till 75k plus before replacement.
|Genuine Original Equipment Manufacturer (OEM) Parts-Specifications|Stoptech Street Performance Brake Pads|3M Crystalline Solar Film|Sachs Race Engineering (SRE) Kit|Orange TPMS|RCD 510-Navigation System|Battery Checker|Itronics ITB-100HD|
+Quote Post
Strudel-
Strudel- post Aug 11 2011, 02:32 PM   |  In Reply To Yuan
Post #5
4th Gear
Warn: -----
QUOTE (Yuan @ Aug 11 2011, 04:24 PM) *
I was told by many that copper is the way to go too. Cheaper and better spark too. Only down side is gotta change pretty often but thats sort of the time I do my service anyway.
God created turbo lag to give V8 a chance.
+Quote Post
Satria_neo
Satria_neo post Aug 11 2011, 03:17 PM
Post #6
3rd Gear
Warn: -----
I have tried both and I would prefer NGK plugs due to 0.6mm center electrode vs 0.4mm for the Denso. Performance wise, there is no difference at all.
However, NGK last longer compared to Denso. But always take note that only the center electrode is iridium and hence resistant to wear. The grounding electrode will be the first to wear out.
Hence need to regap once in a while.
+Quote Post
Satria_neo
Satria_neo post Aug 11 2011, 03:19 PM   |  In Reply To Yuan
Post #7
3rd Gear
Warn: -----
QUOTE (Yuan @ Aug 11 2011, 02:24 PM) *
Denso plugs don't last very long due to the fine 0.4mm center electrode.
NGK last much longer with its 0.6mm one.
+Quote Post
Yuan
Yuan post Aug 11 2011, 03:47 PM   |  In Reply To Satria_neo
Post #8
2Fast2Furious
Warn: -----
QUOTE (Satria_neo @ Aug 11 2011, 03:19 PM) *
I have decided to revert back to stock copper since I always go to stockist to get my parts for servicing.
This post has been edited by Yuan: Aug 11 2011, 03:47 PM
+Quote Post
Ahbao999
Ahbao999 post Aug 12 2011, 10:05 AM
Post #9
3rd Gear
Warn: -----
thanks guys for the sharing...
copper change every 10k ?
so now more user prefer NGK than DENSO ....
I am using NGK Iridium. Might consider using normal plug if iridium also does not last long. dry.gif
+Quote Post
Gitanic
Gitanic post Aug 12 2011, 10:37 AM
Post #10
4th Gear
Warn: X----
Retired 2012
+Quote Post
Yuan
Yuan post Aug 12 2011, 10:55 AM   |  In Reply To Ahbao999
Post #11
2Fast2Furious
Warn: -----
QUOTE (Ahbao999 @ Aug 12 2011, 10:05 AM) *
It depends on the way we drive our cars I guess.
For copper plugs, my experience is that the mechanic will check and showed me the condition. Then he would advise me whether these plugs need to be changed.
Not all cases, my copper plugs need to be changed every 10k.
+Quote Post
Satria_neo
Satria_neo post Aug 12 2011, 11:07 AM   |  In Reply To Yuan
Post #12
3rd Gear
Warn: -----
QUOTE (Yuan @ Aug 12 2011, 10:55 AM) *
Actually it can last well over 10K with some regapping. Cleaning is optional and not usually needed unless it fouled. But then if plugs are fouled, then its not a plug issue already.
+Quote Post
Yuan
Yuan post Aug 12 2011, 11:22 AM   |  In Reply To Satria_neo
Post #13
2Fast2Furious
Warn: -----
QUOTE (Satria_neo @ Aug 12 2011, 11:07 AM) *
+Quote Post
5936
5936 post Aug 12 2011, 08:31 PM   |  In Reply To Satria_neo
Post #14
6th Gear
Warn: -----
My 76K+ Sill stock Denso iridum.
Plan to change at 80-85K.
These are good plugs, dont waste it away too early.
+Quote Post
Ahbao999
Ahbao999 post Aug 16 2011, 10:26 AM   |  In Reply To 5936
Post #15
3rd Gear
Warn: -----
QUOTE (5936 @ Aug 12 2011, 08:31 PM) *
Wow thats long ...
perhap yours is Iridium Tough. can go 100k.
+Quote Post
5936
5936 post Aug 17 2011, 12:55 AM   |  In Reply To Ahbao999
Post #16
6th Gear
Warn: -----
I am. Lazy person.
So the plug can set for 80-100k, I will go for it.
+Quote Post
Tanhangkiang
Tanhangkiang post Aug 17 2011, 05:51 AM   |  In Reply To Satria_neo
Post #17
2nd Gear
Warn: -----
QUOTE (Satria_neo @ Aug 11 2011, 03:17 PM) *
Maybe u can try oem ngk, 0.7mm tip iridium with platinum enhanced ground. 100k I think.
+Quote Post
Ahbao999
Ahbao999 post Aug 19 2011, 01:58 PM   |  In Reply To 5936
Post #18
3rd Gear
Warn: -----
+Quote Post
Satria_neo
Satria_neo post Aug 19 2011, 05:29 PM   |  In Reply To Tanhangkiang
Post #19
3rd Gear
Warn: -----
QUOTE (Tanhangkiang @ Aug 17 2011, 05:51 AM) *
The problem is I usually side gap my plug. Hence this will destroy the platinum ground tip. Thus I just stikc with the Iridium IX.
+Quote Post
Ahbao999
Ahbao999 post Aug 24 2011, 02:03 PM   |  In Reply To Satria_neo
Post #20
3rd Gear
Warn: -----
QUOTE (Satria_neo @ Aug 19 2011, 05:29 PM) *
what is side gap ???
+Quote Post
2 Pages V   1 2 >
Similar Threads
    Topic Title Forum Replies Last Action
No New Posts   Denso spark plug General Car Discussion 2 20th April 2013 - 03:53 PM
Last post by: Extinguisher
No New Posts   Topic has attachmentsWhere to get spark plug tools? Maintenance & Repairs 22 19th April 2013 - 10:09 PM
Last post by: Wishxsr
No New Posts   Showtime pull the plug on Dexter Lite & EZ 2 19th April 2013 - 12:03 PM
Last post by: Ahseng
No New Posts   How to aim spark plug towards the intake side of the cylinder head Performance and Tuning 12 16th April 2013 - 11:47 AM
Last post by: Nastyportflow
No New Posts   Topic has attachmentsNissan Latio Spart Plug So expensive ? Japanese Talk 51 23rd March 2013 - 06:11 PM
Last post by: Yangdaze
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
GuidelinesTerms Of ServiceAbout UsModerators Lo-Fi Version     Time is now: 20th May 2013 - 03:24 PM RSS
