| Joint membership: You may login to MyCarForum using your sgCarMart username & password |
Wpower
Dec 25 2011, 12:07 AM
Post
#1
2nd Gear Posts: 102 Warn:
Should the workshop proceed to do the repair even without the other party's surveyor assessing ?
What can be the consequences? |
Nzy
Dec 25 2011, 08:17 AM | In Reply To Wpower
Post
#2
6th Gear Posts: 2,851 Warn:
Should the workshop proceed to do the repair even without the other party's surveyor assessing ? What can be the consequences? It was in the news a few months ago. If the accident has been reported already and the other party's insurer has been informed, then the other party's surveyor has 48hrs to inspect the damaged vehicle. If it fails to do so, it automatically waives its right to contest the claim. |
Wpower
Dec 25 2011, 09:59 AM | In Reply To Nzy
Post
#3
It was in the news a few months ago. If the accident has been reported already and the other party's insurer has been informed, then the other party's surveyor has 48hrs to inspect the damaged vehicle. If it fails to do so, it automatically waives its right to contest the claim. thank you.. didnt see the news |
Trusty
Dec 28 2011, 03:53 PM | In Reply To Wpower
Post
#4
4th Gear Posts: 710 Warn:
hi
how does a 3rd party claim work? eg. you are claiming party 1. after reporting the claim at the reporting centre, will the centre submit the report to your insurance company? or is it done by the claim workshop? 2. how can you check if the claim workshop has requested the other party's surveyor for assessment? what are the chances that your insurance company does not acknowledge your claim after the repair work has been done if the claim workshop did not submit the claim to either insurance company? will it directly affect your ncd? 3. under what situation will a 3rd party claim be rejected/denied? TIA |
Passion
Dec 28 2011, 04:17 PM | In Reply To Trusty
Post
#5
![]() 6th Gear Posts: 3,179 Warn:
hi how does a 3rd party claim work? eg. you are claiming party 1. after reporting the claim at the reporting centre, will the centre submit the report to your insurance company? or is it done by the claim workshop? No. It will be submitted to the 3rd party insurance by workshop. It will not be submitted to your insurance if you are not claiming your own insurance. 2. how can you check if the claim workshop has requested the other party's surveyor for assessment? what are the chances that your insurance company does not acknowledge your claim after the repair work has been done if the claim workshop did not submit the claim to either insurance company? will it directly affect your ncd? You wouldn't be able to know unless your workshop tells you. Chances of insurance not honoring is 100% if they didn't notify the insurance of the repair. For free play, 3rd party are given 48hours after notification by workshop to survey the vehicle.If claiming another party insurance,it should not affect your own insurance NCD. 3. under what situation will a 3rd party claim be rejected/denied? Normally wouldn't reject. Unless proven driver no license,driving under influence of alcohol,use for the purpose not stated in the policy. Else,chances are it will not be throw out. TIA I have answer in your post. |
Trusty
Dec 28 2011, 04:24 PM | In Reply To Passion
Post
#6
I have answer in your post. thanks. 2. if the claim workshop did not notify the surveyor at all but proceeded with the repair, then submit the claim to the insurance company. can this happen? assuming this happen, what is the possibility that the insurance company reject/deny the claim? in this case, will your ncd be affected? |
Passion
Dec 28 2011, 08:07 PM | In Reply To Trusty
Post
#7
thanks. 2. if the claim workshop did not notify the surveyor at all but proceeded with the repair, then submit the claim to the insurance company. can this happen? assuming this happen, what is the possibility that the insurance company reject/deny the claim? in this case, will your ncd be affected? They have to wait for surveyor. If they proceed without waiting, they can't claim a cent later. They are at losing end. At your end,you will not be affected because you didn't effect your insurance. To effect your insurance, you need to sign a authorization form to authorize the workshop to claim against own policy. Hope it helps. |
Trusty
Dec 28 2011, 09:17 PM | In Reply To Passion
Post
#8
They have to wait for surveyor. If they proceed without waiting, they can't claim a cent later. They are at losing end. At your end,you will not be affected because you didn't effect your insurance. To effect your insurance, you need to sign a authorization form to authorize the workshop to claim against own policy. Hope it helps. it does clear my doubts.thank you |
Bhauto213
Dec 29 2011, 04:50 PM | In Reply To Wpower
Post
#9
![]() Sponsor Posts: 194 Warn:
The workshop which is doing the claim will bear the consequences. The pratice now is workshop are not allow to proceed repair before 3rd party surveyor survey. But they are given 2 days deadline to have that accident car survey. If the deadline passed and even after workshop sending remainders , the 3rd party surveyor still haven get the car survey then the workshop can proceed with the repair.
If before 2 days deadline and workshop start repair then the 3rd party will only pay for visible damaged , ur car inner damgaged like panel, exhaust all these they will reject the estimated given by the worshop. So workshop have to bear with the consequences and repair cost for other damaged part. -------------------- BH AUTO SERVICES PTE LTD, MAIN: 213, Kranji Road (Singapore) 739485. OFFICE: 6559 8944 Mobile: 9101 3232 BRANCH: Blk 5033, Ang Mo Kio Industrial Park 2 #01-275 ( Singapore ) 569536. OFFICE: 6759 2393 |
Trusty
Dec 29 2011, 05:14 PM | In Reply To Bhauto213
Post
#10
The workshop which is doing the claim will bear the consequences. The pratice now is workshop are not allow to proceed repair before 3rd party surveyor survey. But they are given 2 days deadline to have that accident car survey. If the deadline passed and even after workshop sending remainders , the 3rd party surveyor still haven get the car survey then the workshop can proceed with the repair. If before 2 days deadline and workshop start repair then the 3rd party will only pay for visible damaged , ur car inner damgaged like panel, exhaust all these they will reject the estimated given by the worshop. So workshop have to bear with the consequences and repair cost for other damaged part. thank you for the information |
Wpower
Jan 7 2012, 06:16 PM
Post
#11
Hi all
i receive the lawyer letter from my claim workshop. im puzzled at 1 of the line "unless i revoke your authority in writing or instruct you otherwise in writing, you have my authority to have full conduct of my claim without the need to seek my approval for each step of my claim" <-- is this the practice? |
Passion
Jan 7 2012, 06:54 PM | In Reply To Wpower
Post
#12
Hi all i receive the lawyer letter from my claim workshop. im puzzled at 1 of the line "unless i revoke your authority in writing or instruct you otherwise in writing, you have my authority to have full conduct of my claim without the need to seek my approval for each step of my claim" <-- is this the practice? From what I see,this is to your advantage? This lawyer is helping you to claim,so he will proceed without your acknowledge to speed things up. No good meh? Unless he writes that other can claim you without your knowledge,then you should reject. |
Crazy_lancer
Aug 6 2012, 09:27 PM
Post
#13
Neutral Newbie Posts: 8 Warn:
Hi, like to ask what if the 3rd party claim failed, what will happen? The owner pay the repair himself ? Or the workshop bear it all?
Ramenplay
Nov 27 2012, 02:09 PM | In Reply To Nzy
Post
#14
Neutral Newbie Posts: 3 Warn:
It was in the news a few months ago. If the accident has been reported already and the other party's insurer has been informed, then the other party's surveyor has 48hrs to inspect the damaged vehicle. If it fails to do so, it automatically waives its right to contest the claim. Hi, My car just got into an accident with a cab. It is the cab's fault although she is denying liability (50/50 case). I've filed a claim against her cab's insurance. However, I was told that the insurance company will not be sending a surveyor to check my car as the cabbie claims that she is not at fault. I was told that if I want to proceed, I will have to engage my own surveyor (~$200-300) to check my car for damages. Shouldn't her insurance company engage and send a surveyor since I have filed a claim against them? So in this case, how? |
Jaxel
Nov 27 2012, 11:22 PM | In Reply To Bhauto213
Post
#15
Neutral Newbie Posts: 13 Warn:
The workshop which is doing the claim will bear the consequences. The pratice now is workshop are not allow to proceed repair before 3rd party surveyor survey. But they are given 2 days deadline to have that accident car survey. If the deadline passed and even after workshop sending remainders , the 3rd party surveyor still haven get the car survey then the workshop can proceed with the repair. If before 2 days deadline and workshop start repair then the 3rd party will only pay for visible damaged , ur car inner damgaged like panel, exhaust all these they will reject the estimated given by the worshop. So workshop have to bear with the consequences and repair cost for other damaged part. Hi bro, i was rear ended by a commecial mini bus....i sent my car bak to c&c to do third party claim. However it had been 3 weeks, and c&c is telling me that they can't do anything as the bugger who had rear ended me did not report,and the only option i hav is to either do a claim on my insurance or file a civil suit against the bugger. Can i jus check is this rite??? I hav pics of my car being rear ended by the mini bus, but the third party insurance is not sending a surveyor down cos no report made to them. Meaning to say next time i bang ppl i dun report i can get away scot free??!! |
Bhauto213
Nov 28 2012, 11:10 AM | In Reply To Jaxel
Post
#16
Hi bro, i was rear ended by a commecial mini bus....i sent my car bak to c&c to do third party claim. However it had been 3 weeks, and c&c is telling me that they can't do anything as the bugger who had rear ended me did not report,and the only option i hav is to either do a claim on my insurance or file a civil suit against the bugger. Can i jus check is this rite??? I hav pics of my car being rear ended by the mini bus, but the third party insurance is not sending a surveyor down cos no report made to them. Meaning to say next time i bang ppl i dun report i can get away scot free??!! bro sorry to hear that. This is what happen when these commercial vehicles belong to company, if the drivers act blur or never update their company then their company will not know there is an accident occured. This is why touch wood if we encounter accident with these commercial vehicle remember to take down the company particular and office number, most of these vehicles having decal which having their company detail and office number on either side of the front door. If you have the company number you can call them up and tell them their vehicle had an accident with. i will pm you to expalin to you more . Hope im able to help you. :) -------------------- BH AUTO SERVICES PTE LTD, MAIN: 213, Kranji Road (Singapore) 739485. OFFICE: 6559 8944 Mobile: 9101 3232 BRANCH: Blk 5033, Ang Mo Kio Industrial Park 2 #01-275 ( Singapore ) 569536. OFFICE: 6759 2393 |
Chrispie
Nov 29 2012, 11:19 AM
Post
#17
![]() Supercharged Posts: 6,225 Warn:
from all these examples, i wonder why we buy insurance.
-------------------- 'Don't trust anyone. Not even your own fart.' - Anonymous. |
CMS
Apr 18 2013, 10:24 PM | In Reply To Chrispie
Post
#18
1st Gear Posts: 82 Warn:
CMS
Apr 18 2013, 10:26 PM | In Reply To Crazy_lancer
Post
#19
Briansoh
Apr 18 2013, 11:00 PM
Post
#20
2nd Gear Posts: 161 Warn:
Workshop not stupid one. They will cover backside by getting you to sign some indemnity letter stating that if everything cannot claim, you will have to pay.
Similar Threads
| Topic Title | Forum | Replies | Last Action | ||
Lite & EZ | 1,646 | Today, 12:41 AM Last post by: Babymiaomiao |
Starcraft 2: Heart of Swarm coming 3rd Dec | Lite & EZ | 90 | 14th May 2013 - 11:44 AM Last post by: Watwheels |
Third Party Toyota Workshop | General Car Discussion | 130 | 25th April 2013 - 03:13 PM Last post by: Raymondism |
Lite & EZ | 24 | 23rd April 2013 - 12:32 PM Last post by: Mustank |
3rd party insurance claim | General Car Discussion | 40 | 20th April 2013 - 09:53 PM Last post by: Fongmy |
| Guidelines – Terms Of Service – About Us – Moderators | Lo-Fi Version Time is now: 20th May 2013 - 07:24 AM
