IPB
Welcome Guest ( Log In | Register )
Keyword: Search Button
Advanced Search
Most Viewed Discussions
Most Active Discussions
11 Pages V   1 2 3 4 5 > »
Reply to this topicStart new topic
Vinceng
Vinceng post Aug 28 2012, 07:20 PM
Post #1
3rd Gear
Warn: X----
My Daihatsu Sirion 1.3 has min RON of 91.
Always been pumping 95RON until recently, pumped 2 tankfuls of 92RON discovered some sluggishness whenaccelerating and mileage dropped by about 1km per litre.
My friend who drives a petrol driven Toyota Hiace school bus also told me he pumped 95RON due to lack of power for 92RON.
is this true, or must engine timing be retard for it to accept 92RON?
This post has been edited by Vinceng: Aug 28 2012, 07:21 PM
Go to the top of the page
+Quote Post
JaydenSTI
JaydenSTI post Aug 28 2012, 07:54 PM
Post #2
5th Gear
Warn: -----
Most likely is your mind playing a fool on you...... Since min is 91, anything below that will cause knocking on your engine........ Above that, waste $$........ you pump 120 also won't increase power.......
We are all full, but so yet to be filled.
+Quote Post
Tigershark1976
Tigershark1976 post Aug 28 2012, 08:35 PM   |  In Reply To Vinceng
Post #3
Supercharged
Warn: -----
I have mentioned it many times... ron rating have nothing to do with the engine power. A higher ron rating petrol is required for higher car compression engine to prevent engine from ping. Getting petrol with higher ron rating required is nothing but contributing bonuses to those petrol companies.
Do a blind test, ask your friend to pump petrol for you for a few rounds without telling u what petrol they pump.... trust me, you cant tell the diff....
btw, of pumping higher ron rating could bring more power. Then why buy car with higher capacity?? just pump Ron 98 + ron booster will do the tricks... LOL
This post has been edited by Tigershark1976: Aug 28 2012, 08:38 PM
+Quote Post
Deckbuild
Deckbuild post Aug 28 2012, 08:58 PM
Post #4
6th Gear
Warn: -----
Delete
This post has been edited by Deckbuild: Aug 28 2012, 08:59 PM
+Quote Post
LoverofCar
LoverofCar post Aug 28 2012, 09:09 PM
Post #5
Supercharged
Warn: -----
I only heard turbo car need higher RON petrol...
''Things that destroy are: Politics without principle; Pleasure without conscience; Wealth without work; Knowledge without character; Business without morality; Science without humanity; and Worship without sacrifice.''
+Quote Post
Vinceng
Vinceng post Aug 28 2012, 09:41 PM   |  In Reply To LoverofCar
Post #6
3rd Gear
Warn: X----
I was told that for 16 valve engine, better to pump at least 95RON.
Any truth in this?
+Quote Post
Racing
Racing post Aug 28 2012, 09:48 PM   |  In Reply To Vinceng
Post #7
2nd Gear
Warn: Banned
QUOTE (Vinceng @ Aug 28 2012, 09:41 PM) *
Any truth in this?
look at ur car manual.
i remember latio is min 91
lancer 92.
Jobs For foreign talents
NS for singaporeans !!!!!!!!
+Quote Post
Fd60
Fd60 post Aug 28 2012, 10:01 PM
Post #8
2nd Gear
Warn: -----
r u seriously fking kidding me ? u guys still pump 91/92 ? want ur engine die sooner go ahead . in nowadays car all recommended is 95 . higher performance cars like turbo n v8 uses 97/98 . seriously u guys got to be joking me . YES someone mention retardation of ignition timing auto self adjust system . that is true . tat is why the car will feel sluggish , not to mention knock too . walau please loh . 91 ron realli sad case lei . dirty the engine n no power some more . u tink u guys living in 3rd world country where they have no choice but to use lower octane ar . omg use common sense a bit .
since someone mention a blind test . i dare to take on the bet . 1 full tank . lai come bet wif mi . there is a difference plz .
This post has been edited by Fd60: Aug 28 2012, 10:03 PM
+Quote Post
C-K
C-K post Aug 28 2012, 10:33 PM   |  In Reply To Fd60
Post #9
3rd Gear
Warn: -----
QUOTE (Fd60 @ Aug 28 2012, 10:01 PM) *
In the US, most gas stations only have RON91 to 93 leh... My friend's Corvette (C6) only requires RON91, but he always pumps RON93. So far, nothing is wrong with his car leh..
This post has been edited by C-K: Aug 28 2012, 10:36 PM
+Quote Post
DonNuTs
DonNuTs post Aug 28 2012, 10:48 PM   |  In Reply To C-K
Post #10
1st Gear
Warn: -----
QUOTE (C-K @ Aug 28 2012, 10:33 PM) *
Bro, US fuel uses a slightly different rating. But essentially, it goes like this
It turns out that in Europe, the octane number posted is determined by the RON method (if you live in Europe, check the small print on the gas pump next time you fill 'er up. Wait, filling it up requires taking out a loan nowadays...). In the USA, the number posted is according to the "(R+M)/2" method. Turns out that this is simply the average of the RON number and the MON number. So, would the MON number typically be lower than the RON number? The answer is....yes! Apparently, for modern fuels, the difference between RON and MON (also called sensitivity) is about 10 (RON is higher than MON). Knowing this, we can now calculate the following:
87 octane in the USA = 92 octane in Europe
89 octane in the USA= 94 octane in Europe
92 octane in the USA = 97 octane in Europe
Higher Octane rating does give car more power if the engine can maximise(like Type R and WRX) and the ECU can advance the ignition. But it will hit a ceiling when the ECU cannot advance anymore. Thats why some feel that there is a difference in pumping high octance fuel where some cannot. depend on the car.
Fuel efficiency does depend on the engine and the RIGHT FOOT.
For more detail on octane rating please read it in wiki.
http://en.wikipedia.org/wiki/Octane_rating
and here.
http://oldeloohuis.com/octane.html
This post has been edited by DonNuTs: Aug 28 2012, 10:49 PM
+Quote Post
Unclelee
Unclelee post Aug 28 2012, 10:50 PM   |  In Reply To Fd60
Post #11
Clutched
Warn: -----
seen like you dun travel enough. Thailand, Indonesia etc.. most petrol station only have 91, u can hardly find 95. why i dun see any engine die there?? just follow your car manual unless you are trying to said they are fool to put 91 on their car manual..pls go and check before you post.
+Quote Post
C-K
C-K post Aug 28 2012, 10:59 PM   |  In Reply To DonNuTs
Post #12
3rd Gear
Warn: -----
+Quote Post
5936
5936 post Aug 28 2012, 11:05 PM
Post #13
6th Gear
Warn: -----
Additives played an important role in today's Reformulated fuel too.
Additives may : reduce friction or/and increase combustion.
+Quote Post
Kwanheng
Kwanheng post Aug 28 2012, 11:47 PM
Post #14
4th Gear
Warn: Banned
i tell you the higher ron you pump the better the millage, who's with me?
tested on 2 cars, both same effect.
i don't travel much and i pump around 300 liters per month.
This is what happens when you do not follow Law :signature guidelines]
chery hafei geely chevy.
+Quote Post
Mllcg
Mllcg post Aug 29 2012, 01:46 AM
Post #15
Warn: X----
watch this video...
posted MANY times on MANY forums
http://www.youtube.com/watch?v=dDHwCWdrtdg
+Quote Post
HOUSENUMBER
HOUSENUMBER post Aug 29 2012, 01:57 AM
Post #16
4th Gear
Warn: -----
+Quote Post
Roadhogger
Roadhogger post Aug 29 2012, 06:47 AM   |  In Reply To Vinceng
Post #17
4th Gear
Warn: -----
Any truth in this?
How about 20 or 24 valves engine?
+Quote Post
Kr_toy
Kr_toy post Aug 29 2012, 06:54 AM   |  In Reply To Tigershark1976
Post #18
2nd Gear
Warn: -----
QUOTE (Tigershark1976 @ Aug 28 2012, 08:35 PM) *
for most japanese car with small engine sold here, there is a difference because the ECU normally is mapped to aggresive timing to optimize power and fuel economy, so if use the minimum octane the power produced is not the best the engine can produce.
Even on Latio manual, even it says min octane 91, it also says don't jackrabbit the car because it may induce knocking and damage the engine. It says to accelerate gently when use low octane.
so far the one that I know does not make difference is those american cars with 2.4 or above like PT cruiser, etc. or some sold in our neighbour country where low quality gasoline is prevalent, e.g. toyota avanza, innova, suzuki baleno, etc.
However beside RON, there is another component in fuel that also plays a part like friction modifier, cleaner, etc as well as delivery and storage issue so sometimes RON 98 in Singapore may not feel better than Malaysia Ron 97.
+Quote Post
Zxcvb
Zxcvb post Aug 29 2012, 07:22 AM
Post #19
4th Gear
Warn: -----
If I drink 100plus everyday, will I run faster??
i eat $3 cai png for daily lunch at work - dats my minimum requirement. Do I have to splurge on $15 meal thai express everyday?? No right??
The point here is, is it worth to pay more?? Depending on your car, get the minimum is good enuff. No, your engine won't spoil. Singaporeans may be well-informed, but they are most gullible onto hype and advertising.
+Quote Post
ER-3682
ER-3682 post Aug 29 2012, 07:22 AM   |  In Reply To LoverofCar
Post #20
5th Gear
Warn: -----
QUOTE (LoverofCar @ Aug 28 2012, 09:09 PM) *
98 petrol is for car with high compression engine....to prevent 'pinging'.
+Quote Post
Similar Threads
    Topic Title Forum Replies Last Action
No New Posts   Topic has attachmentsE power System Performance and Tuning 840 18th May 2013 - 11:55 AM
Last post by: Iczboi
No New Posts   V-Power at Shell 98 Price this weekend 17 - 19 May General Car Discussion 51 18th May 2013 - 07:43 AM
Last post by: Earthboy
No New Posts   Topic has attachmentsGood Workshop for Reparing Power Window of Toyota Estima? General Car Discussion 13 16th May 2013 - 07:04 PM
Last post by: 5936
No New Posts   Power vacuum in washing bay. General Car Discussion 25 16th May 2013 - 12:43 AM
Last post by: Tampinesdude
No New Posts   Radiation higher in Sinkie than most Jeepon city Lite & EZ 3 15th May 2013 - 11:35 AM
Last post by: Kezg1
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
GuidelinesTerms Of ServiceAbout UsModerators Lo-Fi Version     Time is now: 21st May 2013 - 04:22 PM RSS
