Kakabobo Clutched September 4, 2012 Share September 4, 2012 Car headunit ocassionally no sound.power is still on, amp also on. but just no sound from speaker ?something restart help but no always.where can go to do a check ? ↡ Advertisement Link to post Share on other sites More sharing options...
Kb27 Supersonic September 4, 2012 Share September 4, 2012 Loose contact on the speaker clip ? Link to post Share on other sites More sharing options...
Kwanheng 1st Gear September 5, 2012 Share September 5, 2012 Car headunit ocassionally no sound. power is still on, amp also on. but just no sound from speaker ? something restart help but no always. where can go to do a check ? i think some where behind HU never connect well. either bring to shop or take out HU and see if they are using black tape or clip. Link to post Share on other sites More sharing options...
Kakabobo Clutched September 6, 2012 Author Share September 6, 2012 wah jin sian leh. sometime happy then it work ok. suay suay it just no sound. Went to the shop but cannot shop them the problem. test a few time also no problem. can a weak battery also cause such problem ? Regards Terence Link to post Share on other sites More sharing options...
Kieran1975 1st Gear September 6, 2012 Share September 6, 2012 Car headunit ocassionally no sound. power is still on, amp also on. but just no sound from speaker ? something restart help but no always. where can go to do a check ? Just tap on your thread as i also facing "similar problem". Sound go off for 20-30s and then back to normal. Sometime happen once or twice per day. Anyone know this problem? How much to fix it? Thanks. Link to post Share on other sites More sharing options...
Adrianli Hypersonic September 6, 2012 Share September 6, 2012 I did had this problem too. I realised, it was the installer who tried to hide the wires behind the headunit, thus causing the speaker wire pinched between the headunit and car interior. Removed some fittings and moved my fingers behind the headunit and the sound came back. So I brought the car back to the shop and he did it nice nice for me under my supervision. Everything was ok then. Link to post Share on other sites More sharing options...
Kwanheng 1st Gear September 6, 2012 Share September 6, 2012 wah jin sian leh. sometime happy then it work ok. suay suay it just no sound. Went to the shop but cannot shop them the problem. test a few time also no problem. can a weak battery also cause such problem ? Regards Terence weak battery car cannot start liao. this means its time for better audio shop. my fav audio shop never had this problem, i change HU 3 times liao. i suspect behind ur HU, its a black tape forest. Link to post Share on other sites More sharing options...
Kwanheng 1st Gear September 6, 2012 Share September 6, 2012 Just tap on your thread as i also facing "similar problem". Sound go off for 20-30s and then back to normal. Sometime happen once or twice per day. Anyone know this problem? How much to fix it? Thanks. if car is idling and sound just go off, it might be HU problem. unless sound only go off when you driving then its wire problem Link to post Share on other sites More sharing options...
Seanboi 1st Gear June 29, 2017 Share June 29, 2017 i think some where behind HU never connect well. either bring to shop or take out HU and see if they are using black tape or clip. Which is better? Black tape or clip? Clip if never clamp properly can also result in loose connection. I am thinking perhaps using the black tape method would be better. Link to post Share on other sites More sharing options...
justalex Neutral Newbie November 22, 2017 Share November 22, 2017 Car headunit ocassionally no sound. power is still on, amp also on. but just no sound from speaker ? something restart help but no always. where can go to do a check ? I think it would be easier to help you if you have written what head unit or what car do you have. ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding - March 2024
Xiaomi EV is Coming
Xiaomi EV is Coming
Cars at Expo - Apr 2024
New car discount/price/promo
