| Joint membership: You may login to MyCarForum using your sgCarMart username & password |
Dashingd
Sep 16 2012, 03:02 PM
Post
#1
![]() 2nd Gear Posts: 127 Warn:
Hi Folks,
Need some help from those car experts here. My car uses a keyless entry/push-start button system. It is factory fitted (JDM). In the last week or so, I started having issues opening doors. Intermittently I'll have to press the door button / keys a few times before the doors will unlock. Today for the first time, my car could not even start! The key could not be detected! Finally after letting the engine rest for a couple of mins, I managed to get it started again. I've changed my key batteries. Confirmed also not the car battery since I changed it only in Feb 2012. What other possibilities are there? Also if the engine can't detect my keys again, what else can I do to get it started so that I can drive it to the workshop? Appreciate your help. Cheers! -------------------- Let's see how close u get before I HIT my brakes... |
Furrynadz
Sep 16 2012, 03:16 PM
Post
#2
Supercharged Posts: 6,327 Warn:
wat car
go ask dealer/agent |
Dashingd
Sep 16 2012, 03:22 PM | In Reply To Furrynadz
Post
#3
Car is a LGT B4.
Yes, intending to go back to MI tomorrow. But am worried car won't start again later or tomorrow morning. Sigh..... -------------------- Let's see how close u get before I HIT my brakes... |
Kchew21
Sep 16 2012, 03:40 PM
Post
#4
1st Gear Posts: 59 Warn:
Did u mix yr keys together with our devices? Someth
Dashingd
Sep 16 2012, 03:44 PM | In Reply To Kchew21
Post
#5
Steptronic
Sep 16 2012, 03:54 PM | In Reply To Dashingd
Post
#6
![]() 6th Gear Posts: 2,743 Warn:
Have you tried checking with the second key?
Rustyz
Sep 16 2012, 04:05 PM | In Reply To Kchew21
Post
#7
![]() 6th Gear Posts: 2,833 Warn:
Dashingd
Sep 16 2012, 04:21 PM | In Reply To Rustyz
Post
#8
OIC...paiseh.
No battery not corroded. Did a check & even changed the batt just to be safe. Steptronic, yes I checked the 2nd key as well. Same problem. -------------------- Let's see how close u get before I HIT my brakes... |
ER-3682
Sep 16 2012, 04:46 PM
Post
#9
5th Gear Posts: 2,391 Warn:
Usually there is a sensor near the centre armrest,check is there alot of stuff inside,i don't know much about Subaru,but for Nissan there is a hole below the dash to put the key in for emergency.
5936
Sep 16 2012, 10:12 PM
Post
#10
![]() 6th Gear Posts: 3,796 Warn:
My Toyota not Subaru, but also Keyless entry/Engine start.
With totally dead battery. i will open door manually with the emergency half cut key. Place the transponder beside the start/stop button for starting. Different car may have different arrangements for emergency starting of car. I tried once in this condition I keep a spare battery for the transponder in the car. Replace it and all back to normal. If you suspect transponder unit faulty, it's around $300-$350 a piece ( 4years ago price) to clone. |
Forhod
Sep 16 2012, 11:16 PM
Post
#11
![]() 2nd Gear Posts: 200 Warn:
Most probably the programming "ran", just need to do the reprogramming. Drop MI line and let them decide whether to tow the car in or the breakdown service guy to come down.
Dashingd
Sep 17 2012, 03:47 PM
Post
#12
Thanks all for giving your advice.
Have tried most of these as given in the manual as well. None did work. Anyhow, an update. Brought it to MI this afternoon. Tech did a check on both my remote keysets and found 1 of the battery to have weak voltage (approx 3volts). So changed the battery and now hoping its simply a weak battery issue. Though it doesn't answer the question about the other 'not weak' keyset experiencing the same issue. -------------------- Let's see how close u get before I HIT my brakes... |
Eddyseri
Sep 18 2012, 01:25 AM
Post
#13
Novice Posts: 17 Warn:
Anyone knows how much to repair or replace internal door guard as my swift door cant be open from inside.... Only can be done from outside.... Passenger right door?
Ckchong8
Sep 18 2012, 03:24 AM | In Reply To Eddyseri
Post
#14
3rd Gear Posts: 411 Warn:
Anyone knows how much to repair or replace internal door guard as my swift door cant be open from inside.... Only can be done from outside.... Passenger right door? Could it be you accidentally actuated the child lock ? |
Eddyseri
Sep 18 2012, 09:43 PM | In Reply To Ckchong8
Post
#15
Wat u mean by tat? Coz usually when u pull the handle, it will have a click sound, but nw its silent n cnt be open from inside.
Eddyseri
Sep 18 2012, 09:45 PM
Post
#16
I mean pull the handle from inside. I do ask some of my frens as they recommend to seek for swift agent. Wonder if normal shop could do.
Ckchong8
Sep 18 2012, 10:54 PM | In Reply To Eddyseri
Post
#17
Wat u mean by tat? Coz usually when u pull the handle, it will have a click sound, but nw its silent n cnt be open from inside. It a safety feature mend for children where you dun want yr kid to accidentally open from inside. Therefore when the door open there is a small level at the side of the door. Maybe it have lifted and only able to open from outside. |
Similar Threads
| Topic Title | Forum | Replies | Last Action | ||
Vehicle Quota System - Most in favour of proposal | General Car Discussion | 80 | Today, 07:54 PM Last post by: Ungtiong |
Performance and Tuning | 840 | 18th May 2013 - 11:55 AM Last post by: Iczboi |
Custom 3M carmat/Push Start/Keyless Entry/2way Car Alarm/DVR | Products & Services | 1,847 | 15th May 2013 - 04:50 PM Last post by: Speed_ong |
AIM not participating in 2013 Town Council system tender | Lite & EZ | 128 | 5th May 2013 - 12:50 AM Last post by: Tiger1 |
General Car Discussion | 23 | 26th April 2013 - 02:25 PM Last post by: Tjkbeluga |
| Guidelines – Terms Of Service – About Us – Moderators | Lo-Fi Version Time is now: 23rd May 2013 - 08:50 PM
