Glml Neutral Newbie October 1, 2012 Share October 1, 2012 Hi all, 2009 avante 1.6a sport model. Just got today. Hope there are kind souls out there to help. Current Issue: - When aircon temp set at 25,26,27,28 deg celsius, i get hot air. Even after 3 minutes. - When aircon temp set at 24 and below, I get cold air. I don't think this is normal. I was afraid that the hot weather was affecting however it is the same even at night. Thanks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
Darren4182 Neutral Newbie October 1, 2012 Share October 1, 2012 Hi all, 2009 avante 1.6a sport model. Just got today. Hope there are kind souls out there to help. Current Issue: - When aircon temp set at 25,26,27,28 deg celsius, i get hot air. Even after 3 minutes. - When aircon temp set at 24 and below, I get cold air. I don't think this is normal. I was afraid that the hot weather was affecting however it is the same even at night. Thanks in advance. i think is normal. i was told air con the highest to set is 24 to ensure proper coldness. Link to post Share on other sites More sharing options...
Leijasper 1st Gear October 1, 2012 Share October 1, 2012 Ya it's normal.. 25 can gets cold air too.. I've driven my avante for couple of years already.. Can go Hyundai forum to find out more if u wan.. Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear October 1, 2012 Share October 1, 2012 Which month of 2009? Komoco practises free extnded warranty if service by them.. Link to post Share on other sites More sharing options...
Passion 5th Gear October 1, 2012 Share October 1, 2012 I don't know about Hyundai. My Toyota set the temperature at 28 is the same as 25. So probably is the same as Toyota, not spoil. Link to post Share on other sites More sharing options...
Wishxsr 2nd Gear October 2, 2012 Share October 2, 2012 Hi all, 2009 avante 1.6a sport model. Just got today. Hope there are kind souls out there to help. Current Issue: - When aircon temp set at 25,26,27,28 deg celsius, i get hot air. Even after 3 minutes. - When aircon temp set at 24 and below, I get cold air. I don't think this is normal. I was afraid that the hot weather was affecting however it is the same even at night. Thanks in advance. You try to remove the thermostat, should be able to solve your problem. Link to post Share on other sites More sharing options...
Hondasteam 1st Gear November 10, 2012 Share November 10, 2012 You can try changing your aircon(cabin) filter to see whether it helps. See Link for more details. Thanks. Link to post Share on other sites More sharing options...
Lanshan75 Neutral Newbie December 12, 2012 Share December 12, 2012 I have been annoyed by this problem for a long time,so thank you for your post, it is really useful for me. __________________________________ share love,share happy,share useful information about Buy Diablo 3 Gold and WOW Gold Link to post Share on other sites More sharing options...
Lilukl 1st Gear December 17, 2012 Share December 17, 2012 Is normal... Not a problem..same to my advante.. Link to post Share on other sites More sharing options...
Gendut 2nd Gear February 23, 2013 Share February 23, 2013 Who in the world sets the temp at 25degC? You're better off opening the window. Link to post Share on other sites More sharing options...
RadX Moderator February 23, 2013 Share February 23, 2013 Who in the world sets the temp at 25degC? You're better off opening the window. totally agree Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 23, 2013 Share February 23, 2013 Hi all, 2009 avante 1.6a sport model. Just got today. Hope there are kind souls out there to help. Current Issue: - When aircon temp set at 25,26,27,28 deg celsius, i get hot air. Even after 3 minutes. - When aircon temp set at 24 and below, I get cold air. I don't think this is normal. I was afraid that the hot weather was affecting however it is the same even at night. Thanks in advance. So easy. Just set yr temp at a comfortable level. Ignore degree setting as it might not b accurate. I usually set at coldest on hot days but use e fan speed to adjust till comfortable during day or cool nights. Not really rocket science. Link to post Share on other sites More sharing options...
Erykool 1st Gear February 23, 2013 Share February 23, 2013 it depends on the temp outside of the car. if the outside temperature is 27 degrees and u set 25 or 26 degrees, then the air blow out will be not so cold or even a bit warm. This is how the avante air con works. example for a few times recently when raining whole day, the outside temp as detected by the car air con is 23 degrees and if I leave my aircon at 22 degrees, the air it blows out not so cold la. and also check if the internal air circulation is on. If the temp outside is 33 degrees, then if you set 25 or 26 degrees the air should be cooling la. if its hot air then better bring back to check. you have lemon law to protect you remember? Link to post Share on other sites More sharing options...
Hondasteam 1st Gear December 12, 2013 Share December 12, 2013 You can try changing your aircon(cabin) filter to see whether it helps. See Link for more details. Thanks. Repost link. They carry JS air & cabin filters from Japan. Good stuffs! ↡ Advertisement Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
