Chongster 6th Gear October 19, 2012 Share October 19, 2012 i noticed a couple of times my odyssey after parking the two front window dropped one inch. what is the cause of that? is it sign of battery dying? sorry if this sound very noob ↡ Advertisement Link to post Share on other sites More sharing options...
Kwanheng 1st Gear October 19, 2012 Share October 19, 2012 i noticed a couple of times my odyssey after parking the two front window dropped one inch. what is the cause of that? is it sign of battery dying? sorry if this sound very noob sensor? power window motor? Link to post Share on other sites More sharing options...
Ckchong8 1st Gear October 19, 2012 Share October 19, 2012 i noticed a couple of times my odyssey after parking the two front window dropped one inch. what is the cause of that? is it sign of battery dying? sorry if this sound very noob Saw in the previous mail from one of the bro's saying dun actuate the master window lock button at the driver control panel something affecting the window lower down. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 19, 2012 Share October 19, 2012 i noticed a couple of times my odyssey after parking the two front window dropped one inch. what is the cause of that? is it sign of battery dying? sorry if this sound very noob Unlikely caused by battery. Link to post Share on other sites More sharing options...
Chongster 6th Gear October 19, 2012 Author Share October 19, 2012 ok, thanks v. much to all. Link to post Share on other sites More sharing options...
Mpeng Neutral Newbie October 23, 2012 Share October 23, 2012 (edited) I am not sure if this is caused by weak battery. My car will jerk slightly when the vehicle is stationary at the traffic light, steeping on the brake. I tried to turn off the aircon and don't experience that jerk. Is this due to weak battery or ?? Does anyone have the same experience? Thanks Edited October 23, 2012 by Mpeng Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 24, 2012 Share October 24, 2012 I am not sure if this is caused by weak battery. My car will jerk slightly when the vehicle is stationary at the traffic light, steeping on the brake. I tried to turn off the aircon and don't experience that jerk. Is this due to weak battery or ?? Does anyone have the same experience? Thanks Try this. At night on low beam lights n run engine at idle. On ac n switch on turn signal. Does yr speedo lights dim n bright as yr turn signal on n off. Then yr batt getting weak. Or press horn also hear sound change tone also batt weak. Link to post Share on other sites More sharing options...
Tcx607 4th Gear October 24, 2012 Share October 24, 2012 If you crank your starter motor at least twice to fire your engine in the morning, likelyhood your batt is almost end of life. Exception if your spark plug is above recommended mileage. Secondly, listen to the crank motor sound, a sluggish crank also indicate weak batt. Thirdly, if your batt is already more than 1.5yrs, it time to change Link to post Share on other sites More sharing options...
TVT Supercharged October 24, 2012 Share October 24, 2012 I am not sure if this is caused by weak battery. My car will jerk slightly when the vehicle is stationary at the traffic light, steeping on the brake. I tried to turn off the aircon and don't experience that jerk. Is this due to weak battery or ?? Does anyone have the same experience? Thanks Unlikely due to a weak battery. You can try out what bro P69 & TCX607 had advise in post#7 & 8 and test it out. Link to post Share on other sites More sharing options...
Ben5266 Supercharged October 24, 2012 Share October 24, 2012 I am not sure if this is caused by weak battery. My car will jerk slightly when the vehicle is stationary at the traffic light, steeping on the brake. I tried to turn off the aircon and don't experience that jerk. Is this due to weak battery or ?? Does anyone have the same experience? Thanks It sounds more serious than weak battery... The car is under power for what ever reason. Perhaps the fuel or the air intake or the spark etc. Turn off aircon will draw less power from the engine... therefore no jerk. So, you need to bring your car to workshop. I suggest... Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 24, 2012 Share October 24, 2012 i noticed a couple of times my odyssey after parking the two front window dropped one inch. what is the cause of that? is it sign of battery dying? sorry if this sound very noob Maybe yr car got special function window drop fr venterlation when park in hot sun? Check yr handbook or dealer if u need to re-set something. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 24, 2012 Share October 24, 2012 I am not sure if this is caused by weak battery. My car will jerk slightly when the vehicle is stationary at the traffic light, steeping on the brake. I tried to turn off the aircon and don't experience that jerk. Is this due to weak battery or ?? Does anyone have the same experience? Thanks The jerk cud b caused by ac compressor cutting in n out. Maybe it needs to b adjusted. Go Markcool at woodlands indl pk E1 n see Ah Huat. He e best person to diagnose fault. Link to post Share on other sites More sharing options...
Limiter Neutral Newbie October 24, 2012 Share October 24, 2012 One side of my HID bulb ocassionally does not lights up when car is running with accessories and aircon. Battery is around 2yrs plus old. Is this some kind of weak/failing sign? Link to post Share on other sites More sharing options...
Kumweng 1st Gear October 24, 2012 Share October 24, 2012 If you crank your starter motor at least twice to fire your engine in the morning, likelyhood your batt is almost end of life. Exception if your spark plug is above recommended mileage. Secondly, listen to the crank motor sound, a sluggish crank also indicate weak batt. Thirdly, if your batt is already more than 1.5yrs, it time to change If I inist not to change battery , will it damage my Alternater in long run? I mean just keep jump start and jump start....Battery age is about 2.8 years old. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 24, 2012 Share October 24, 2012 One side of my HID bulb ocassionally does not lights up when car is running with accessories and aircon. Battery is around 2yrs plus old. Is this some kind of weak/failing sign? Likely yr hid is aftermarket. Maybe a loose connection somewhere. Get e shop that install fr u to chk it fr u. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 24, 2012 Share October 24, 2012 If I inist not to change battery , will it damage my Alternater in long run? I mean just keep jump start and jump start....Battery age is about 2.8 years old. Why u do that??????? So inconvenient to jumpstart all e time. Just change a small cheap battery more practical. Link to post Share on other sites More sharing options...
Limiter Neutral Newbie October 24, 2012 Share October 24, 2012 Likely yr hid is aftermarket. Maybe a loose connection somewhere. Get e shop that install fr u to chk it fr u. thanks bro.. im planning to go for a check. kinda irritating as i have to turn on and off couple of times before it lights up when the problem occurs.. Link to post Share on other sites More sharing options...
TatteredTorn Clutched October 24, 2012 Share October 24, 2012 I dont think it's due to battery. Just send it to the workshop to have it checked. I think the power window mechanism is faulty. If you have problems cranking up your engine, then it's a sign of low batt :p ↡ Advertisement Link to post Share on other sites More sharing options...
Battery Voltage up & down
My EV journey to the i4
Request for dark mode
The Electric Vehicle Charging Problem
Lithium-Iron Battery (LFP) - New & Better Alternative?
Car key fob battery
Car key fob battery
