Kingkong 5th Gear January 28, 2013 Share January 28, 2013 (edited) If given the following batteries to select from, which one will you get, and why? 1. Bosch 38AH 2. Amaron 35AH Car's original is 35AH. Fitted with an Amp thats not too high power type. Thanks. Edited January 28, 2013 by Kingkong ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Kingkong 5th Gear January 28, 2013 Author Share January 28, 2013 Anyone have experience with both? Link to post Share on other sites More sharing options...
Fcw75 Hypersonic January 28, 2013 Share January 28, 2013 (edited) Amaron for me. But see which one has higher CCA. Amaron CCA for 35Ah is 335. Check Bosch. Edited January 28, 2013 by Fcw75 1 Link to post Share on other sites More sharing options...
Kr_toy 1st Gear January 28, 2013 Share January 28, 2013 If given the following batteries to select from, which one will you get, and why? 1. Bosch 38AH 2. Amaron 35AH Car's original is 35AH. Fitted with an Amp thats not too high power type. Thanks. Since the difference small, why don't you install 45 ah ? It is better when you have power amp, not to load the battery heavily. 1 Link to post Share on other sites More sharing options...
Pms 3rd Gear January 28, 2013 Share January 28, 2013 If your car got no fancy led, ice and etc, just replace with the same amp battery. Higher cca are meant for cold countries because they need extra power just to crank the engine when cold. When you expend more power just to crank on a higher cca battery, the longer it takes for the alternator to charge the battery. Mix with singapore's start stop traffic, the battery wont last long unless you upgrade the alternator too. As for the battery, you get what you pay for. Link to post Share on other sites More sharing options...
C-K 2nd Gear January 28, 2013 Share January 28, 2013 (edited) Just buy whatever you feel right lor.. Battery lifespan depends on heng suay one. My last time's Amaron batt (60ah) lasted me only 2 years. My current Yokohama brand (45ah) from JB, which is much cheaper than Amaron, has lasted me for the past 3 years and still going strong. Edited January 28, 2013 by C-K Link to post Share on other sites More sharing options...
Kingkong 5th Gear January 28, 2013 Author Share January 28, 2013 So far I've only used Bosch. Lasted 1yr9mths before I experienced first battery flat. Heard Amaron lasts about 2 yrs and more. So was wondering if I should give it a try. My only concern is the simple Amp I had. Its Nothing super duper. Will the 35AH be enough? Not considering going for higher capacity for fear of stressing the altenator out. Another concern for higher capacity is the size may not fit the battery bay. Link to post Share on other sites More sharing options...
Kingkong 5th Gear January 28, 2013 Author Share January 28, 2013 Amaron for me. But see which one has higher CCA. Amaron CCA for 35Ah is 335. Check Bosch. Couldn't find specs for Bosch. Link to post Share on other sites More sharing options...
Tungsl Clutched January 28, 2013 Share January 28, 2013 is it true that if you fit a higher amp battery the alternator has to work a lot harder to charge the battery Link to post Share on other sites More sharing options...
Zniper 2nd Gear January 28, 2013 Share January 28, 2013 amaron, mine lasted 2yrs 2mths and still kicking alive... however, i went to jb WS last wk do someting else and at the same time juz change to another amaron... haha Link to post Share on other sites More sharing options...
Pms 3rd Gear January 29, 2013 Share January 29, 2013 is it true that if you fit a higher amp battery the alternator has to work a lot harder to charge the battery Take example those AA rechargable batteries. It takes a longer time to charge a 2200mah battery than a 1800mah one. The charger wont work harder but it takes a longer time to charge. If you use a higher amp battery with a high cca output or not, the alternator will take a longer time to charge. So on stock electrical system, the stock battery and alternator is enough. If you have fancy led, ice or anything sucking up juice, upgrade both battery and alternator. If you dont, they will stress out because it is discharging faster than it can charge. Link to post Share on other sites More sharing options...
Tungsl Clutched January 29, 2013 Share January 29, 2013 Take example those AA rechargable batteries. It takes a longer time to charge a 2200mah battery than a 1800mah one. The charger wont work harder but it takes a longer time to charge. If you use a higher amp battery with a high cca output or not, the alternator will take a longer time to charge. So on stock electrical system, the stock battery and alternator is enough. If you have fancy led, ice or anything sucking up juice, upgrade both battery and alternator. If you dont, they will stress out because it is discharging faster than it can charge. thanks that sounded reasonable but if the alternator takes a longer time to charge that would also mean that the alternator working hours would be longer hence wouldnt the alternator be working harder here something i am not sure is regardless whether the alternator is charging or not the alternator is always running (true or false) since the alternator is connected to the engine block by belt so their parts are moving all the time if this is true, then in a sense the alternator is working all the time regardless if it is charging or not Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 29, 2013 Share January 29, 2013 (edited) Normally not more than 20% of the recommended battery amp hr. For a 35 amp hr battery the biggest amp hr battery will be 42amp hr ( 45amp hr so be ok ) so long as the alternator is not force to generate max amp @ 80% of the running time. Edited January 29, 2013 by Yeobh Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 29, 2013 Share January 29, 2013 You need to get into the technicality of how an alternator and charging system works. It will be too much to explain the technicality over there. Link to post Share on other sites More sharing options...
Pms 3rd Gear January 29, 2013 Share January 29, 2013 The alternator charging process starts when the rpm is above 1K and it is said that it takes about 30min of driving to recharge the back the energy lost during startup. During idling it wont charge. Link to post Share on other sites More sharing options...
Pms 3rd Gear January 29, 2013 Share January 29, 2013 You need to get into the technicality of how an alternator and charging system works. It will be too much to explain the technicality over there. True. Just use simple and proven methods will do. Link to post Share on other sites More sharing options...
Pisces69 6th Gear January 29, 2013 Share January 29, 2013 If given the following batteries to select from, which one will you get, and why? 1. Bosch 38AH 2. Amaron 35AH Car's original is 35AH. Fitted with an Amp thats not too high power type. Thanks. Both r reputable brands. Just depends on price n also its not made in china or bangladesh. Link to post Share on other sites More sharing options...
Lowrider 2nd Gear January 29, 2013 Share January 29, 2013 I beg the differ. Idling does charge the battery. ↡ Advertisement Link to post Share on other sites More sharing options...
Battery Voltage up & down
My EV journey to the i4
Request for dark mode
The Electric Vehicle Charging Problem
Lithium-Iron Battery (LFP) - New & Better Alternative?
