BMW M3 Drifted Into Cliff
2BDriver
Either you hadn't watched the video or you don't know what oversteer is.
Watched and I do know what it oversteer is..... do you?
The danger of oversteering :blink:
His front end was pushing wide - this is classic understeer. The front tyres lost adhesion first.
It looked more like understeer to me. The front wheels lost grip and the car couldn't follow the roadlines, and veered off the cliff edge.
Understeer is when you go over the cliff nose first.
Oversteer is when you go over the cliff ass first.
A four-wheel drift is when you go over the cliff juuuust right. [:p]
Moderator
It's understeer, not oversteer [;)]
i driver reverse so shd be oversteer [laugh] [laugh]
UHMMM...that was under- steering.....[:p][cool]
ETA
The danger of being the last to the forum to comment....I wonder if that is called over comment? Or is it under read?
Edited by Darryn
Can be quite confusing to some. I try to remember by this:
Understeer - you want to turn but whole car go straight, rear lost grip.
Oversteer - you want to turn but turns more than it should. Circle becomes oval.
Not exactly technical but it helps me.
Cheers!
Cheers!
There is an easier way to remember...
Under = NOT ENOUGH
Over = TOO MUCH
Under steer - not enough steering, run wide in the corner
Over steer - too much steering, hit the corner too soon, go too far into the corner, turn too far as the arse end slides out and you turn around backwards
Guest
