Ronn 1st Gear January 21, 2014 Share January 21, 2014 Hi all toyota wish bros, recently realised that when my '06 wish is accelerating on expressway after 70-80km/h, car starts to vibrate very very ferociously. It's like the car is travelling off road man.. Went to the WS and he said nothing's wrong with my engine. What else could the problem be? Need some serious help here, the TWCSG site is not working for me I can't even register ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Joe6057 1st Gear January 23, 2014 Share January 23, 2014 Hi all toyota wish bros, recently realised that when my '06 wish is accelerating on expressway after 70-80km/h, car starts to vibrate very very ferociously. It's like the car is travelling off road man.. Went to the WS and he said nothing's wrong with my engine. What else could the problem be? Need some serious help here, the TWCSG site is not working for me I can't even register Bro, try wheel balancing 1st.. 1 Link to post Share on other sites More sharing options...
Darryn Turbocharged January 23, 2014 Share January 23, 2014 Is it only on expressway above 70? That would tend to indicate alignment / balancing of wheels. But shouldn't have a sudden onset - would be something that would get gradually worse. Something that happened to me was a horrible vibration when accelerating - which was my engine mounts. But that was not speed dependent. The only other place to look would be suspension. Unless....you haven't knocked a kerb have you? Maybe rim is damaged / or one side suspension is hurt 1 Link to post Share on other sites More sharing options...
Ronn 1st Gear January 23, 2014 Author Share January 23, 2014 (edited) Bro, try wheel balancing 1st.. Recently got a punctured tired, change both side (front) already, all tyres same size leh.. Vibrating issues started before puncture. Is it only on expressway above 70? That would tend to indicate alignment / balancing of wheels. But shouldn't have a sudden onset - would be something that would get gradually worse. Something that happened to me was a horrible vibration when accelerating - which was my engine mounts. But that was not speed dependent. The only other place to look would be suspension. Unless....you haven't knocked a kerb have you? Maybe rim is damaged / or one side suspension is hurt On normal roads up till now I didn't hear any "vibrations" As above, my wheels are recently changed but the vibrations started before wheel puncture Another factor that affect is that because of the vibration my pick up don't much power on expressway above 70km/h (gauged roughly), quite dangerous leh no power when overtaking Called WS and he said maybe engine oil leaking, don't know filter or what Edited January 23, 2014 by Ronn Link to post Share on other sites More sharing options...
PSP415 Supersonic January 23, 2014 Share January 23, 2014 Personally, best to go to a good workshop to find out the cause, like you mentioned, it can be dangerous on expressway if u should suddenly not have enough power to overtake. CNY around the corner. Do have the problem resolved whilst the workshops are open. It's no joke to encounter a breakdown, *touch wood, paper and stone* and available one during the long break as some may take the opportunity to rest longer. And properly cost more too or parts not available cos stocklists also closed. Tikam tikam is guesswork.....hope u manage to rectify the fault without too much hassle. Safe ride Cheers 1 Link to post Share on other sites More sharing options...
Oneguy 1st Gear March 5, 2014 Share March 5, 2014 2006 wish ... based on what i read ... my guess would be the engine mounting. seek a 2nd view if necessary. your current WS might not be looking at the problem correctly. 1 Link to post Share on other sites More sharing options...
laughingor Neutral Newbie May 16, 2014 Share May 16, 2014 I got the same problem. got it fixed at $600 for changing 2 parts. now happily cruising. 1 Link to post Share on other sites More sharing options...
Ken1898 1st Gear July 20, 2014 Share July 20, 2014 I got the same problem. got it fixed at $600 for changing 2 parts. now happily cruising. Please share what parts have you replaced? 1 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged July 29, 2014 Share July 29, 2014 Recently got a punctured tired, change both side (front) already, all tyres same size leh.. Vibrating issues started before puncture. On normal roads up till now I didn't hear any "vibrations" As above, my wheels are recently changed but the vibrations started before wheel puncture Another factor that affect is that because of the vibration my pick up don't much power on expressway above 70km/h (gauged roughly), quite dangerous leh no power when overtaking Called WS and he said maybe engine oil leaking, don't know filter or what i know this a dated post - but do u mind to update what's been done, where u did it n estimated cost? also noted ur vibration affected power - so wouldn't be mounting of engine, suspension or alignment, but sparkies, airflow sensor, fuel pump, ecu (battery change recently?). if u havent done anythin, may consider go for diagnotics or best check w agent / trusted workshop. 1 Link to post Share on other sites More sharing options...
Ronn 1st Gear September 27, 2014 Author Share September 27, 2014 Asked my dad to bring it to a workshop and ended up changing the drive shaft Link to post Share on other sites More sharing options...
LvwMotor Neutral Newbie January 24, 2015 Share January 24, 2015 Please share what parts have you replaced? It's should be drive shafts and mountings. Balancing after changing the parts. Buy from stockist will save you a few hundreds. Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 22, 2015 Share February 22, 2015 (edited) Asking on behalf of friend who ride is a 2009 wish. He can't engage P and hence the key has to be left there as it can't be pulled out. Any solution? Btw he don't have a manual for reference. Edited February 22, 2015 by Hamburger Link to post Share on other sites More sharing options...
So_nice 6th Gear February 22, 2015 Share February 22, 2015 Asking on behalf of friend who ride is a 2009 wish. He can't engage P and hence the key has to be left there as it can't be pulled out. Any solution? Btw he don't have a manual for reference. There should be a shift lock button where he can press and push the gear into P Asking on behalf of friend who ride is a 2009 wish. He can't engage P and hence the key has to be left there as it can't be pulled out. Any solution? Btw he don't have a manual for reference. Hold the button and shift as he would normally 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 22, 2015 Share February 22, 2015 (edited) There should be a shift lock button where he can press and push the gear into P Hold the button and shift as he would normally Thanks bro,shall try it. Initially I thought it's a hole in a slot. Apparently it's a button!!!!! Edited February 22, 2015 by Hamburger Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 22, 2015 Share February 22, 2015 tried and cannot move, according to my friend. mechanical fault???? Link to post Share on other sites More sharing options...
SallyNgoh Neutral Newbie April 7, 2015 Share April 7, 2015 Recently when cornering right, got a metal cranking sound. Still persist after I change the backing plates. anyone got similar experience? Link to post Share on other sites More sharing options...
Wishcumstrue 6th Gear April 8, 2015 Share April 8, 2015 Recently when cornering right, got a metal cranking sound. Still persist after I change the backing plates. anyone got similar experience? What's your odo reading now ? Link to post Share on other sites More sharing options...
evidence 2nd Gear June 18, 2015 Share June 18, 2015 To those driving 2006-7 Wish, do ur car vibrate a bit during traffic lights stop? Have u changed ur radiator before, mine seems to have the red coolant seepage at the top joints? During traffic stops or waiting for people, my aircond seems not very cold but when move off the aircond is cold, anyone facing this issue too? Maybe u all can share Tq in advance ↡ Advertisement Link to post Share on other sites More sharing options...
[Official] 2024 Lexus LBX
Toyota Corolla Cross
Toyota Land Cruiser Mini
Toyota Corolla AE86 Revival! Initial D Fans COME IN!
Reliable PI: Toyota Camry
