Spken1976 1st Gear March 21, 2014 Share March 21, 2014 Hi bros, need your help. My car vibrate quite badly when switching to the drive mode. It's worsen when picking up. What might be the cause? Any mobile mechanic recommend? Thanks. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Blackyv Turbocharged March 21, 2014 Share March 21, 2014 check engine mount ... Link to post Share on other sites More sharing options...
Spken1976 1st Gear March 21, 2014 Author Share March 21, 2014 check engine mount ... Bro, tomorrow going to workshop. Roughly how much to repair if the mounting faulty. Dun wan to kanna chop. Thanks. Link to post Share on other sites More sharing options...
Blackyv Turbocharged March 21, 2014 Share March 21, 2014 Bro, tomorrow going to workshop. Roughly how much to repair if the mounting faulty. Dun wan to kanna chop. Thanks. dont know, my 7yrs old latio still ok so far, ...hehehe... Link to post Share on other sites More sharing options...
Xanavi 4th Gear March 21, 2014 Share March 21, 2014 Tyre wear? Doez steering wheel move alot? Link to post Share on other sites More sharing options...
Kb27 Supersonic March 21, 2014 Share March 21, 2014 Hi bros, need your help. My car vibrate quite badly when switching to the drive mode. It's worsen when picking up. What might be the cause? Any mobile mechanic recommend? Thanks. Auto gear ? Could be the transmission solenoids going bad. Best to bring it to workshop to diagnose. Link to post Share on other sites More sharing options...
Spken1976 1st Gear March 21, 2014 Author Share March 21, 2014 Auto gear ? Could be the transmission solenoids going bad. Best to bring it to workshop to diagnose. Don't know what went wrong also. But there is some tire burnt smell also. Bringing to workshop tomorrow. Will be going to Tek Soon Motor at Autobay. Any comments? Link to post Share on other sites More sharing options...
Spken1976 1st Gear March 21, 2014 Author Share March 21, 2014 dont know, my 7yrs old latio still ok so far, ...hehehe... My latio seem a lot problems. Link to post Share on other sites More sharing options...
Bonafidestack 4th Gear March 21, 2014 Share March 21, 2014 Most prob is the engine mounting. Wear and tear. There is a rubber thingy on the engine mount get that change and should be okay le. Nissan Latio is quite a sturdy car... Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 21, 2014 Share March 21, 2014 your description is vague. Need for info. Link to post Share on other sites More sharing options...
Spken1976 1st Gear March 21, 2014 Author Share March 21, 2014 Most prob is the engine mounting. Wear and tear. There is a rubber thingy on the engine mount get that change and should be okay le. Nissan Latio is quite a sturdy car... Oh ok. Last year happen once before. I had changed the coil and spark plugs. Cost me $400. But don't know why so fast happen again. Most prob is the engine mounting. Wear and tear. There is a rubber thingy on the engine mount get that change and should be okay le. Nissan Latio is quite a sturdy car... Btw est how much to change the rubber thingy on the engine mount? Thanks. Link to post Share on other sites More sharing options...
Optramagnum 6th Gear March 21, 2014 Share March 21, 2014 Likely to be engine mount. Very common wear and tear part due to long mileage. Cost was about $320 for my car. After that, you will feel your car will have less vibration like a new car. Nevertheless, do check for other fault, I may be wrong. Link to post Share on other sites More sharing options...
Spken1976 1st Gear March 21, 2014 Author Share March 21, 2014 Likely to be engine mount. Very common wear and tear part due to long mileage. Cost was about $320 for my car. After that, you will feel your car will have less vibration like a new car. Nevertheless, do check for other fault, I may be wrong. Hi yours also Nissan Latio? Link to post Share on other sites More sharing options...
Optramagnum 6th Gear March 21, 2014 Share March 21, 2014 Hi yours also Nissan Latio? Sorry buddy, mine it's a Chevrolet as shown in my profile pic. But I had same problem and changed at $320. I hope Japanese cars parts are cheaper. Link to post Share on other sites More sharing options...
Kangadrool Supersonic March 21, 2014 Share March 21, 2014 Nope, Jap parts are no cheaper than others. In fact, some are more ex than contis. However, quality especially rubber, seals and gaskets are typically top notch quality. Sorry buddy, mine it's a Chevrolet as shown in my profile pic.But I had same problem and changed at $320. I hope Japanese cars parts are cheaper. Link to post Share on other sites More sharing options...
Bonafidestack 4th Gear March 21, 2014 Share March 21, 2014 Oh ok. Last year happen once before. I had changed the coil and spark plugs. Cost me $400. But don't know why so fast happen again. Btw est how much to change the rubber thingy on the engine mount? Thanks. If i never remb wrongly is less than 400. Link to post Share on other sites More sharing options...
Blackyv Turbocharged March 21, 2014 Share March 21, 2014 Don't know what went wrong also. But there is some tire burnt smell also. Bringing to workshop tomorrow. Will be going to Tek Soon Motor at Autobay. Any comments? Ummm...smell... Are you sure the smell is like tyre? Might be your disc brakes jammed... Go take a look, is the brake disc blacken? Did your brake no longer biting or very weak the longer distance you drive?.. If yes, better drive very slow and get it fix asap it could be the disc brake need to change the kit, it's also a rubber thing where it suppose to release the grip when let go of brake pedal but when it failed, the brake pad will bite the disc all the way... Link to post Share on other sites More sharing options...
Jman888 Moderator March 21, 2014 Share March 21, 2014 Don't know what went wrong also. But there is some tire burnt smell also. Bringing to workshop tomorrow. Will be going to Tek Soon Motor at Autobay. Any comments? engine mount not a serious problem, engine won't drop off one burning smell could be some plastic bag stick to the exhaust. ↡ Advertisement Link to post Share on other sites More sharing options...
2021 3rd Generation Nissan Note (E13)
Nissan QashQai 2014 Part 2
Nissan Teana Experience
2023 Tan Chong Car Challenge
