Yeobt Supercharged May 29, 2014 Share May 29, 2014 (edited) Am considering to rebuild my honda engine after so many years and at the same time to enhance it for better performance. my questions are; 1. what should i do FIRST for better results? 2. if i can choose only one, which one should do first, PNP piston? change con rod? change cam? or ? 3 .how much it may cost? (base on the item you suggested) my old car TIA. Edited June 2, 2014 by BabyBlade ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic May 29, 2014 Share May 29, 2014 Why not order a new same spec engine from Japan and replace it? LTA will allow the same spec engine to be replaced. Write off this old one for a new one. 1 Link to post Share on other sites More sharing options...
Yeobt Supercharged May 29, 2014 Author Share May 29, 2014 Why not order a new same spec engine from Japan and replace it? LTA will allow the same spec engine to be replaced. Write off this old one for a new one. if i do, i would get a 1.8 engine which is cannot be verified visually. i think i would still preferred to upgrade the performance part by part to feel the shiok. (pocket also not hurt badly) Link to post Share on other sites More sharing options...
Ivanpaseo 2nd Gear May 29, 2014 Share May 29, 2014 b20 block b16 head? 1 Link to post Share on other sites More sharing options...
Yeobt Supercharged May 29, 2014 Author Share May 29, 2014 b20 block b16 head? mine is original engine. just want to upgrade the parts inside to performance standard to withstand another 10 years. Link to post Share on other sites More sharing options...
Djdp Clutched May 29, 2014 Share May 29, 2014 (edited) mine is original engine. just want to upgrade the parts inside to performance standard to withstand another 10 years. Do u wanna rebuild the engine or to get better performance? Rebuild means u hv to most things internal, isn't it? Edited May 29, 2014 by Djdp 1 Link to post Share on other sites More sharing options...
Myxilplix Turbocharged May 29, 2014 Share May 29, 2014 Open up and see what needs to be done lor. At least new pistons/rods/bearings. Probably oversized pistons depending on the cylinder walls. See how your crank is and if need to send for a polish or replace. Don't forget refreshing the head as well. 1 Link to post Share on other sites More sharing options...
Ivanpaseo 2nd Gear May 29, 2014 Share May 29, 2014 (edited) since doing full rebuild. head out do PnP. Do overbore and honing since you changing piston. You might want to do block and head shaving to increase compression. replace all bearing. parts are cheap from ebay! Edited May 29, 2014 by Ivanpaseo Link to post Share on other sites More sharing options...
Watwheels Supersonic May 30, 2014 Share May 30, 2014 if i do, i would get a 1.8 engine which is cannot be verified visually. i think i would still preferred to upgrade the performance part by part to feel the shiok. (pocket also not hurt badly) I do not think it's that easy. LTA will counter check with the invoice on the engine CC and engine serial number. Up to you to decide. Upgrading parts can be quite ex. Link to post Share on other sites More sharing options...
Yuan 6th Gear May 30, 2014 Share May 30, 2014 I do not think it's that easy. LTA will counter check with the invoice on the engine CC and engine serial number. I believe this is correct. Upgrading of the engine to a higher cc specification would entail the process of requiring approval from LTA or government authorities. Am considering to rebuild my honda engine after so many years and at the same time to enhance it for better performance. my questions are; 1. what should i do FIRST for better results? 2. if i can choose only one, which one should do first, PNP piston? change con rod? change cam? or ? 3 .how much it may cost? (base on the item you suggested) my old car TIA. Can I ask if there is anything wrong with your engine (other than that it is old)? If it is working well and fine, then in my opinion, there is no need to do any rebuilding. If it is to enhance it for better performance, then it is another story. Some of the mods may enquire collateral enhancements as well 2 Link to post Share on other sites More sharing options...
Contipro 5th Gear May 30, 2014 Share May 30, 2014 Since you wan to save ur pocket, If upgrading engine internal, then better do it at one go. U pay one time labour for dismantled and assembly work.. No way it can be cheaper to do it one by one.. Unless u DIY... take ur own time... ha ha... 4 Link to post Share on other sites More sharing options...
macrotrust2 5th Gear May 30, 2014 Share May 30, 2014 Bolt a turbo kits- dont need to change engine. save time 1 Link to post Share on other sites More sharing options...
comegetme 2nd Gear May 30, 2014 Share May 30, 2014 Am considering to rebuild my honda engine after so many years and at the same time to enhance it for better performance. my questions are; 1. what should i do FIRST for better results? 2. if i can choose only one, which one should do first, PNP piston? change con rod? change cam? or ? 3 .how much it may cost? (base on the item you suggested) my old car TIA. TS, why dont you buy a new car? this kind of old car not worth to spend so much money and time. reliability also not there. so many new cars that are faster nowadays.... 1 Link to post Share on other sites More sharing options...
Knoobie Supercharged May 30, 2014 Share May 30, 2014 TS, why dont you buy a new car? this kind of old car not worth to spend so much money and time. reliability also not there. so many new cars that are faster nowadays.... what you're saying is like telling a man who is married >10 yrs wanting to give his wife a make over to just divorce her and get a younger chick instead. 8 Link to post Share on other sites More sharing options...
Kurty Supercharged May 30, 2014 Share May 30, 2014 what you're saying is like telling a man who is married >10 yrs wanting to give his wife a make over to just divorce her and get a younger chick instead. +1 rebuild engine gives me a sense of satisfaction too just the ruling too stringent, if not, when the engine dies off.. lup a bigger and better unit. Link to post Share on other sites More sharing options...
Replica Neutral Newbie May 30, 2014 Share May 30, 2014 Am considering to rebuild my honda engine after so many years and at the same time to enhance it for better performance. my questions are; 1. what should i do FIRST for better results? 2. if i can choose only one, which one should do first, PNP piston? change con rod? change cam? or ? 3 .how much it may cost? (base on the item you suggested) my old car TIA. I think when it comes to this ek, theres a few factors to consider... - what u really wan from this car? - will u be changing car soon? - when is e coe expiring? - most important, how much u willing to throw into this rebuilding process? Link to post Share on other sites More sharing options...
Fastfive1 5th Gear May 30, 2014 Share May 30, 2014 A full rebuild on a B16B is probably gonna cost 2+K. Considering you don't have that much on your COE left, no point doing it unless you're damn sure that COE will drop in the next year or so or that you can afford the COE if it remains at 50-60k. I would suggest doing all the upgrades and stuff after you renew your COE. 2 Link to post Share on other sites More sharing options...
Mz3SP0907 3rd Gear May 30, 2014 Share May 30, 2014 (edited) Wa sei! you'll get turbo kick in at 3k rpm and vtec screaming at 6k rpm.... this is out of the world feeling, bro! But... cannot in sgp leh... Bolt a turbo kits- dont need to change engine. save time Edited May 30, 2014 by Mz3SP0907 ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mitsuoka M55
2025 Mitsuoka M55
Pre-2014 Honda Jazz / Fit (GD & GE Series)
