Sunset73 5th Gear February 16, 2015 Share February 16, 2015 Dear all, Need some help over here. Anybody replaced the above before? Any idea how much it would cost and can it be DIY? Got one workshop told me need to replace the whole meter ↡ Advertisement Link to post Share on other sites More sharing options...
Detach8 5th Gear February 16, 2015 Share February 16, 2015 (edited) Dear all, Need some help over here. Anybody replaced the above before? Any idea how much it would cost and can it be DIY? Got one workshop told me need to replace the whole meter Vios? It's probably a T10 bulb lah. $2 for the bulb. Workshop probably charge you $200 for the labour to take out and replace the bulb. LOL. Just pry out the plastic surrounding your dash meter and the radio. There's a few clips. You can see from this image. There's around 11 clips (4 left, 4 right, 3 top) that holds that piece of plastic down. Once you take that off, you see two screws holding the dash meter down (black screw on white plastic). Unscrew that. You should be able to reach the back and twist off the bulbs. Edited February 16, 2015 by Detach8 Link to post Share on other sites More sharing options...
Sunset73 5th Gear February 16, 2015 Author Share February 16, 2015 Vios? It's probably a T10 bulb lah. $2 for the bulb. Workshop probably charge you $200 for the labour to take out and replace the bulb. LOL. I don't know also. Thought of dismantling myself to replace the bulb.. but not sure whether it will affect the speedometer accuracy once dismantled. Link to post Share on other sites More sharing options...
Detach8 5th Gear February 16, 2015 Share February 16, 2015 I don't know also. Thought of dismantling myself to replace the bulb.. but not sure whether it will affect the speedometer accuracy once dismantled. Won't lah not so lauya one ... arbo the car rattle here and there for 10 years the speedometer already spoilt. Link to post Share on other sites More sharing options...
Sunset73 5th Gear February 16, 2015 Author Share February 16, 2015 Won't lah not so lauya one ... arbo the car rattle here and there for 10 years the speedometer already spoilt. Hahaha.. Steady lah! I try to replace.. lol Link to post Share on other sites More sharing options...
Detach8 5th Gear February 16, 2015 Share February 16, 2015 (edited) Hmm the pic I post is not same as the local VIOS, but it should be quite SIMILAR lah. I suggest you see if the plastic around the radio unit can take out first or not, then you should be able to pry off the bigger piece around that goes up to the speedo. Just pry the plastic off slowly. If you can find a plastic tool (like a putty blade) better to prevent scratches. Sometimes you can stuff a screw inbetween a piece of cloth also. Edited February 16, 2015 by Detach8 1 Link to post Share on other sites More sharing options...
Sunset73 5th Gear February 16, 2015 Author Share February 16, 2015 Hmm the pic I post is not same as the local VIOS, but it should be quite SIMILAR lah. I suggest you see if the plastic around the radio unit can take out first or not, then you should be able to pry off the bigger piece around that goes up to the speedo. Just pry the plastic off slowly. If you can find a plastic tool (like a putty blade) better to prevent scratches. Sometimes you can stuff a screw inbetween a piece of cloth also. Thanks bro.. hope this helps.. because it looks like the FL Vios 2007- 2011. Mine is Gen 1 vios.. hahah. I'll try to figure it out Link to post Share on other sites More sharing options...
TVT Supercharged February 16, 2015 Share February 16, 2015 http://www.mycarforum.com/topic/2695996-help-my-dashboard-led-back-light-had-failed/?hl=dashboard ↡ Advertisement 1 Link to post Share on other sites More sharing options...
[Official] 2024 Lexus LBX
Toyota Corolla Cross
Toyota Land Cruiser Mini
Toyota Corolla AE86 Revival! Initial D Fans COME IN!
Reliable PI: Toyota Camry
