Sunset73 5th Gear June 22, 2015 Share June 22, 2015 (edited) I am currently driving the above. Been having 3 unresolved issues up till now. Steering wheel sometimes pull to one side suddenly for no apparent reason travelling on an even/straight road. Do I need to do wheel alignment/tyre rotation and balancing? Steering wheel sometimes pull to one side during braking. Do I need to do wheel alignment/tyre rotation and balancing? Loud creaky noises from front passenger door when making full turns at low speeds (Occur whenever I drive the car out for the first time in the day). I don't know how to resolve this. Any kind souls can help? Thanks Edited June 22, 2015 by Sunset73 ↡ Advertisement Link to post Share on other sites More sharing options...
24hrsbatteryservices 1st Gear June 22, 2015 Share June 22, 2015 yr alightment or undercarriage bushing might have worn out go to workshop and do a check on the bushing before alightment because after u do alightment if bushing is worn out the alightment will run away .. for turning and having squeaking sound is because of yr rim when full lock the rim will rub against the inner mudguard that why willl have that kind of sound .. hope you solve your problem 3 Link to post Share on other sites More sharing options...
Sunset73 5th Gear June 23, 2015 Author Share June 23, 2015 yr alightment or undercarriage bushing might have worn out go to workshop and do a check on the bushing before alightment because after u do alightment if bushing is worn out the alightment will run away .. for turning and having squeaking sound is because of yr rim when full lock the rim will rub against the inner mudguard that why willl have that kind of sound .. hope you solve your problem Thanks a lot! I will go do a check soon! Will it be expensive to replace bushings? ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Corolla Cross
Toyota Land Cruiser Mini
