JX83 3rd Gear July 1, 2015 Share July 1, 2015 What happen if I accidentally pump about 9L of diesel into my tank but after that I pump about 42L of petrol to dilute it? I got distracted and luckily the pump attendant came and stop the pumping immediately if not I think my whole car will be full diesel.. Sighzzz... Hope nothing happen.. :( ↡ Advertisement Link to post Share on other sites More sharing options...
Bacteria83 Turbocharged July 1, 2015 Share July 1, 2015 (edited) Diesel in petrol Don't turn on the ignition or start the car This is less common because the standard diesel nozzle is bigger than the filler neck on modern petrol cars. In line with car manufacturers' recommendations, any petrol contaminated with diesel should be removed from the tank and replaced with clean fuel before the ignition is turned on and the car started. Most website gave the same ans, don't start engine clear the whole tank. Edited July 1, 2015 by Bacteria83 2 Link to post Share on other sites More sharing options...
JX83 3rd Gear July 1, 2015 Author Share July 1, 2015 Ya I saw most website will give that answer but I already start my car and move off and travel a bit.. thought should be ok since only 9 litres of diesel.. 42litres of petrol dilute in.. or should I go to the workshop and let them have a look tomorrow? Or monitor 1st.. Link to post Share on other sites More sharing options...
Tcx607 4th Gear July 1, 2015 Share July 1, 2015 For knowledge, diesel does not combust by spark ignition. Diesel will combust under compressed to high pressure. that's why diesel engine do not need spark plug. As such, your diesel in your tank need to be removed before your engine flooded with diesel and you've to spend more $$$ in overhaul. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear July 1, 2015 Share July 1, 2015 TS i hope u learnt your lesson this time. not sure what have lead you to pump diesel to the tank. But i hope after this incident you will be more careful. For now, is better to have the diesel removed from the tank before it done more damage to your engine. Good luck and hope you solve your problem soon. Link to post Share on other sites More sharing options...
Evillusion Supersonic July 1, 2015 Share July 1, 2015 For knowledge, diesel does not combust by spark ignition. Diesel will combust under compressed to high pressure. that's why diesel engine do not need spark plug. As such, your diesel in your tank need to be removed before your engine flooded with diesel and you've to spend more $$$ in overhaul.Un...un...un...un....believable! 1 Link to post Share on other sites More sharing options...
Bacteria83 Turbocharged July 1, 2015 Share July 1, 2015 call for tow car tml and get it flush out should be the most logical choice right now, spend a bit more for a peace of mind bah 1 Link to post Share on other sites More sharing options...
Kangadrool Supersonic July 1, 2015 Share July 1, 2015 Distraction. I nearly kena also by a pesty FT pump attendent. Now, I shoo them away. TS i hope u learnt your lesson this time. not sure what have lead you to pump diesel to the tank. But i hope after this incident you will be more careful. For now, is better to have the diesel removed from the tank before it done more damage to your engine. Good luck and hope you solve your problem soon. 2 Link to post Share on other sites More sharing options...
Kb27 Supersonic July 1, 2015 Share July 1, 2015 Ya I saw most website will give that answer but I already start my car and move off and travel a bit.. thought should be ok since only 9 litres of diesel.. 42litres of petrol dilute in.. or should I go to the workshop and let them have a look tomorrow? Or monitor 1st.. If I were you, I'll try to dilute with petrol as much and as often as possible. Diesel is like 2T oil I'd put in small amount to the petrol tank. If too much, it will quench the spark, leading to misfiring. 1 Link to post Share on other sites More sharing options...
JX83 3rd Gear July 1, 2015 Author Share July 1, 2015 TS i hope u learnt your lesson this time. not sure what have lead you to pump diesel to the tank. But i hope after this incident you will be more careful. For now, is better to have the diesel removed from the tank before it done more damage to your engine. Good luck and hope you solve your problem soon. Ya I know distraction .. :( was thinking of other things thus lead me to that.. Thanks.. If I were you, I'll try to dilute with petrol as much and as often as possible. Diesel is like 2T oil I'd put in small amount to the petrol tank. If too much, it will quench the spark, leading to misfiring. Ya already pump more than 42litres plus of petrol to dilute it already.. 9 liters of diesel inside.. Link to post Share on other sites More sharing options...
Watwheels Supersonic July 1, 2015 Share July 1, 2015 Petrol combust at air/fuel ratio of 10:1, meaning the air/fuel mixture is compressed to a tenth of its orginal volume before the spark ignites the mixture. Diesel do not need spark to ignite but at compression as high as 22:1 in a fuel injector that will cause it to self ignite. Petrol and diesel can mix well together but during combusting in a petrol engine the diesel might not ignite and just pass thru to the exhaust. Given your situation of more petrol dan diesel what you might experience might be a lack of power when you try to accelerate. 3 Link to post Share on other sites More sharing options...
Mkl22 Twincharged July 1, 2015 Share July 1, 2015 You will kill your catalytic converter faster too. Cost $$$. Plugs can be coated with diesel and fire poorly. 1 Link to post Share on other sites More sharing options...
JX83 3rd Gear July 1, 2015 Author Share July 1, 2015 Petrol combust at air/fuel ratio of 10:1, meaning the air/fuel mixture is compressed to a tenth of its orginal volume before the spark ignites the mixture. Diesel do not need spark to ignite but at compression as high as 22:1 in a fuel injector that will cause it to self ignite. Petrol and diesel can mix well together but during combusting in a petrol engine the diesel might not ignite and just pass thru to the exhaust. Given your situation of more petrol dan diesel what you might experience might be a lack of power when you try to accelerate. Ya jus call my friend and he advise me to pump full petrol everyday to keep dilute it as mine only 20% diesel and 80% petrol.. Thanks.. Link to post Share on other sites More sharing options...
Zippaboy 4th Gear July 1, 2015 Share July 1, 2015 Go caltex buy the bottles of techron and add it in. Link to post Share on other sites More sharing options...
JX83 3rd Gear July 1, 2015 Author Share July 1, 2015 Go caltex buy the bottles of techron and add it in. Umm.. Thanks.. Will give it a try tomorrow.. :) Link to post Share on other sites More sharing options...
7hm Turbocharged July 1, 2015 Share July 1, 2015 oddly enough, I vaguely remember reading something about a certain ratio mixture of gasoline & diesel gets you better fuel mileage... I must be crazy 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 1, 2015 Share July 1, 2015 being told its best to flush out yet still want to believe dilution can solve it. all the best to you before you come in to inquire how to repair damge done to petrol engine due to diesel. 3 Link to post Share on other sites More sharing options...
Yewheng Twincharged July 1, 2015 Share July 1, 2015 Ya jus call my friend and he advise me to pump full petrol everyday to keep dilute it as mine only 20% diesel and 80% petrol.. Thanks.. Huh? You still want take risk to keep driving?.. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Be one of 10 lucky winners to win a $10 petrol voucher!
2025 Mitsuoka M55
2025 Mitsuoka M55
