Bossman Neutral Newbie August 11, 2015 Share August 11, 2015 Hi all, Recently realised that the car air flow keeps changing from internal circulation to allowing air from outside to enter and then back to internal circulation. When it is switched to the later, the coolness of the aircon drops. It is normal? ↡ Advertisement Link to post Share on other sites More sharing options...
flashbang Turbocharged August 12, 2015 Share August 12, 2015 Hi all, Recently realised that the car air flow keeps changing from internal circulation to allowing air from outside to enter and then back to internal circulation. When it is switched to the later, the coolness of the aircon drops. It is normal? It may be normal for your car. You have to check the manual. For example, Lancer Ex starts in recirculation, but it will automatically switch to fresh air intake when the interior temperature is reached. You have to manually switch it back to recirculation before it stays there. This is with aircon set to Auto speed. ↡ Advertisement Link to post Share on other sites More sharing options...
Exercising and losing weight
Car air-con
Car air-con
Home Aircon
Home Aircon
