Nlatio Turbocharged January 31, 2016 Share January 31, 2016 Hi Bro Just to check if the Pioneer AVH-X5850BT can add GPS function?? ↡ Advertisement Link to post Share on other sites More sharing options...
Simplecar 4th Gear February 1, 2016 Share February 1, 2016 Hi Bro Just to check if the Pioneer AVH-X5850BT can add GPS function?? i am about to install the above. Was told that it can be done. Recommended Explorer usingGalactio Map. Have not decided whether to add the GPS module (could cost $400) Link to post Share on other sites More sharing options...
Nlatio Turbocharged February 1, 2016 Author Share February 1, 2016 i am about to install the above. Was told that it can be done. Recommended Explorer usingGalactio Map. Have not decided whether to add the GPS module (could cost $400) Thanks bro. Wow its quite ex... Link to post Share on other sites More sharing options...
Macrosszero Turbocharged February 1, 2016 Share February 1, 2016 Plug in your smartphone and you should be able to get GPS maps by downloading it via AppRadioLive. 1 Link to post Share on other sites More sharing options...
Idaddy88 Clutched February 6, 2016 Share February 6, 2016 just installed this HU. however, when I tried to play avi files via USB, it keeps saying unplayable file. anyone has the same problem? Link to post Share on other sites More sharing options...
VincentQuek Clutched February 12, 2016 Share February 12, 2016 Hi guys, May I know how much is this HU? Thanks Link to post Share on other sites More sharing options...
Vezelian Clutched February 15, 2016 Share February 15, 2016 Plug in your smartphone and you should be able to get GPS maps by downloading it via AppRadioLive. Hi bro, I installed this HU and downloaded AppRadioLive but was not able to connect Google Map from my hp to the HU. How did you do it and is there any special cables required? TIA Link to post Share on other sites More sharing options...
Macrosszero Turbocharged February 15, 2016 Share February 15, 2016 Hi bro, I installed this HU and downloaded AppRadioLive but was not able to connect Google Map from my hp to the HU. How did you do it and is there any special cables required? TIA Google Maps does not work on AppRadio. The list of nav apps that I know work on AppRadio are: EC Touch, Navmii and Waze. Link to post Share on other sites More sharing options...
Vezelian Clutched February 16, 2016 Share February 16, 2016 Do I need to download the nav apps or can I launch them directly from AppRadioLive? Thanks! Link to post Share on other sites More sharing options...
Macrosszero Turbocharged February 16, 2016 Share February 16, 2016 Do I need to download the nav apps or can I launch them directly from AppRadioLive? Thanks!You have to download them yourself Link to post Share on other sites More sharing options...
VincentQuek Clutched March 3, 2016 Share March 3, 2016 Got this Hu recently, playing movies on it is a pain. Link to post Share on other sites More sharing options...
killfire Neutral Newbie April 18, 2016 Share April 18, 2016 Hi bros, newbie here.... Can someone guide how to update the Papago map on a Pioneer AVH x5850BT? Thanks. Link to post Share on other sites More sharing options...
Vezelian Clutched May 3, 2016 Share May 3, 2016 Any GPS module that is compatible for x5850bt? Link to post Share on other sites More sharing options...
ILGTCA Neutral Newbie May 3, 2016 Share May 3, 2016 Any GPS module that is compatible for x5850bt? I thought this HU can link to WAZE... why need GPS module? Got this Hu recently, playing movies on it is a pain. I m getting this HU.. why is it a pain? can share? Link to post Share on other sites More sharing options...
Vezelian Clutched May 4, 2016 Share May 4, 2016 How do u link WAZE to the HU? Can use normal sub cable to connect the HP to HU? I thought this HU can link to WAZE... why need GPS module? Link to post Share on other sites More sharing options...
ILGTCA Neutral Newbie May 4, 2016 Share May 4, 2016 How do u link WAZE to the HU? Can use normal sub cable to connect the HP to HU? Should be self explanatory.. although in another language.. Link to post Share on other sites More sharing options...
raymonnnn 1st Gear May 24, 2016 Share May 24, 2016 Hi all, I just installed the 5850 on my car. Just wonder if 5850 have CarPlay to go with iPhone? And the navigation via the appradio live doesn't seems to be very clear( map is blurry). Link to post Share on other sites More sharing options...
StanleyLee_122496 Neutral Newbie May 24, 2016 Share May 24, 2016 Hi, any chance this hu can show grid lines during reverse parking ↡ Advertisement Link to post Share on other sites More sharing options...
[Seek experts' views] Pioneer Z9250BT vs stock HU
Car immobiliser and GPS tracker recommend?
Is Standalone GPS obsoleting?
Dashcam with GPS
Dashcam with GPS
Car Accessories Workshop in West Area
pioneer sda-835 tab
pioneer sda-835 tab
Pioneer z9250bt keep losing GPS after sometimes.
Needs comment for HU - Pioneer AVH-Z5050BT
