Ahseng 5th Gear February 1, 2016 Share February 1, 2016 Hi bros, 1 REF/TOP HOSE (WATER HOSE) 1 $ 190.00 2 FRT BRAKE PAD 1PAIR 1 $ 130.00 3 ENGINE MOUNTING SET 1 $ 920.00 4 COOLANT R30 1 $ 50.00 Prices alright? Or robert pricing? These are the items in the quotation. water hose is the one connected to radiator, If no vibrations felt, issit no need replace engine mounting? ↡ Advertisement Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 1, 2016 Share February 1, 2016 where the quotes come from? workshop or stockist? Link to post Share on other sites More sharing options...
Ahseng 5th Gear February 1, 2016 Author Share February 1, 2016 Quotes came from workshop where the quotes come from? workshop or stockist? Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 1, 2016 Share February 1, 2016 Quotes came from workshop no wonder. Try calling stockist. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear February 1, 2016 Share February 1, 2016 Hi bros, 1 REF/TOP HOSE (WATER HOSE) 1 $ 190.00 2 FRT BRAKE PAD 1PAIR 1 $ 130.00 3 ENGINE MOUNTING SET 1 $ 920.00 4 COOLANT R30 1 $ 50.00 Prices alright? Or robert pricing? These are the items in the quotation. water hose is the one connected to radiator, If no vibrations felt, issit no need replace engine mounting? [knife] [knife] Link to post Share on other sites More sharing options...
GLZT 6th Gear February 1, 2016 Share February 1, 2016 Water hose diy with high grade hose probably less than $15. Link to post Share on other sites More sharing options...
Ahseng 5th Gear February 2, 2016 Author Share February 2, 2016 [knife] [knife] Ahhh...ok understood. Nows the time for the car noob in me to learn how to order from stockist. Wait order sala item then is jiak sai liao. They go by codes, numbers or just tell them the whatever pipe, brake pads they will know? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear February 2, 2016 Share February 2, 2016 Ahhh...ok understood. Nows the time for the car noob in me to learn how to order from stockist. Wait order sala item then is jiak sai liao. They go by codes, numbers or just tell them the whatever pipe, brake pads they will know? number plate enuff Link to post Share on other sites More sharing options...
Shanhz 3rd Gear March 9, 2016 Share March 9, 2016 Hi bros, 1 REF/TOP HOSE (WATER HOSE) 1 $ 190.00 2 FRT BRAKE PAD 1PAIR 1 $ 130.00 3 ENGINE MOUNTING SET 1 $ 920.00 4 COOLANT R30 1 $ 50.00 Prices alright? Or robert pricing? These are the items in the quotation. water hose is the one connected to radiator, If no vibrations felt, issit no need replace engine mounting? front brake pad buy from JAE is $85+gst. excluding labour Link to post Share on other sites More sharing options...
Relaxbrother Clutched March 9, 2016 Share March 9, 2016 number plate enuff I think need to inform the car model number also. This can be found near driver side door or at the passenger side door ( internal frame) Link to post Share on other sites More sharing options...
Furrynadz 5th Gear March 9, 2016 Share March 9, 2016 I think need to inform the car model number also. This can be found near driver side door or at the passenger side door ( internal frame) what for? they can retrieve from lta system number plate is the shortest string of text to provide w/o cocking up the speaking/listening/writing down Link to post Share on other sites More sharing options...
Albeniz Turbocharged December 23, 2018 Share December 23, 2018 (edited) Thinking of getting a 9 year old Teana to renew 10 year COE. In the worst case that the engine or gear box needs to be replaced/repaired, what would be the estimated cost? No need new original parts, second hand or used imported Japan parts would do. Edited December 23, 2018 by Albeniz Link to post Share on other sites More sharing options...
Benchong05 3rd Gear December 26, 2018 Share December 26, 2018 Thinking of getting a 9 year old Teana to renew 10 year COE. In the worst case that the engine or gear box needs to be replaced/repaired, what would be the estimated cost? No need new original parts, second hand or used imported Japan parts would do. Brother, I can recommend you to my friend's workshop as he has done the replacement of gearbox and engine which is directly imported from Japan. My car just reach 10 years old this June and I am the first owner so renew COE is the best choice as my car is well-kept, look at new car. Cost for my gearbox previously is around $2K, engine is around $3K. 1 Link to post Share on other sites More sharing options...
Benchong05 3rd Gear December 28, 2018 Share December 28, 2018 Thinking of getting a 9 year old Teana to renew 10 year COE. In the worst case that the engine or gear box needs to be replaced/repaired, what would be the estimated cost? No need new original parts, second hand or used imported Japan parts would do. Let me know if you are interested, thanks. Link to post Share on other sites More sharing options...
Ichibawa 5th Gear December 28, 2018 Share December 28, 2018 Thinking of getting a 9 year old Teana to renew 10 year COE. In the worst case that the engine or gear box needs to be replaced/repaired, what would be the estimated cost? No need new original parts, second hand or used imported Japan parts would do. Why Teana? Might as well get a Camry. Parts are abundance, Toyota quality and all workshop will know how to fix one. Link to post Share on other sites More sharing options...
Benchong05 3rd Gear December 28, 2018 Share December 28, 2018 Why Teana? Might as well get a Camry. Parts are abundance, Toyota quality and all workshop will know how to fix one. Sorry to say that Teana is more comfort and better in quality compared to Camry not forgetting that Teana is 100% made in Japan while Camry is made in Thailand with parts made from Multi-international Countries. You will understand when you have tried on a Teana versus Camry. 2 Link to post Share on other sites More sharing options...
Ichibawa 5th Gear December 28, 2018 Share December 28, 2018 Sorry to say that Teana is more comfort and better in quality compared to Camry not forgetting that Teana is 100% made in Japan while Camry is made in Thailand with parts made from Multi-international Countries. You will understand when you have tried on a Teana versus Camry. OK. No right or wrong, Nissan does make good cars but not so true after it becomes Nissan-Renault. To each his/her own. Just giving Albeniz more options if he chooses to extend the COE of a car so parts availability for the next 10 years will be crucial. 2 Link to post Share on other sites More sharing options...
Benchong05 3rd Gear December 28, 2018 Share December 28, 2018 OK. No right or wrong, Nissan does make good cars but not so true after it becomes Nissan-Renault. To each his/her own. Just giving Albeniz more options if he chooses to extend the COE of a car so parts availability for the next 10 years will be crucial. True but for extending COE, Nissan parts last longer than Toyota parts as they are made in Japan versus Made in Thailand quaity so it is a wise choice to get Teana when he wants to extend COE for another 10 years. I am doing the same to extend my current ride for another 10 years and I am in the automotive parts industries for many years so I know which are the parts are more reliable. Even though Nissan becomes Nissan-Renault, they operate differently and only some of the Nissan Models are based on Renault design and Renault Parts etc like the QashQai while the rest are still under Nissan, that goes for Mitsubishi which was taken over by Nissan this year. ↡ Advertisement Link to post Share on other sites More sharing options...
2021 3rd Generation Nissan Note (E13)
Car repair and maintenance
Ho Hup Seng......Some good info for our Brudders
Nissan QashQai 2014 Part 2
