Alphas 2nd Gear June 11, 2016 Share June 11, 2016 Engineered, Manufactured, Distributed and Backed by BoschBosch is closely involved in every step of the QuietCast process. From a worldwide R&D network with 2,500 associates and nine test tracks, to dedicated engineers that source and rigorously test all friction materials and formulations, QuietCast brake products are manufactured under the same exacting quality standards as OE components and systems. Industry-leading materials with Molded Shim TechnologyClick to view larger The Complete Brake Pad SolutionThere’s more to value than just a good price. Value also includes quality, extensive coverage, reliable supply and manufacturer support. And that’s just what you get with Bosch. The QuietCast Premium Disc Brake Pad program offers top quality, availability, competitive pricing and full coverage for all makes and models of Domestic, Asian and European automobiles, light trucks and SUVs. Formulations include platform-specific ceramic, semi-metallic and non-asbestos organic (NAO). The Science Behind the SilenceEvery Bosch QuietCast Disc Brake Pad is fitted with the industry’s best pre-attached rubber core shim. This shim style is the most predominant type used by OE manufacturers and is exclusively offered by Bosch for the independent aftermarket. The laminated rubber-core shim is heat and pressure cured between two layers of steel (see Figure 1, opposite page). This process ensures the highest quality bonding of the rubber to steel resulting in lower noise, increased strength, and corrosion resistance. Sound vibrations pass through the friction material and backing plate, but are dissipated by the unique rubber core in the shim for remarkable noise dampening. About Molded Shim Technology (MST)At the time of pressing, heat, adhesive and pressure mold the multi-layer shim to the backing plate and friction material creating an integrally molded unit. The shim stays attached throughout the life of the pad; it won’t walk or slide on the backing plate, providing maximum stability resulting in quieter shim performance over the life of the pad. Has someone used the QuietCast brakepad, does it help solve the moaning sound when the brakes are released after stopping? ↡ Advertisement Link to post Share on other sites More sharing options...
Intermittent rattling noise, car in ICU
Brake Pads
Brake Pads
Steering rack noise on 2010 Altis
Extending quiet time by 1½ hours among recommendations to tackle neighbourhood noise in Singapore
NEA to lower vehicle noise levels from 2023
