dcb Turbocharged November 1, 2016 Share November 1, 2016 Sometimes after the wipers wiped and return, there will be a few patches on the windscreen that is foggy for a few seconds. This is irritating and sometimes block the view on the road. Any idea how to remove that? Also what is a good recommendation to remove fine scratches on the windscreen as well? Used the 3M grey sandpaper thing and resulted in scratches. ↡ Advertisement Link to post Share on other sites More sharing options...
inlinesix Supersonic November 1, 2016 Share November 1, 2016 C L A Y B A R to smoothen your windscreen. 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic November 1, 2016 Share November 1, 2016 Those are stains. Try cleaning them with Kao colour bleach undiluted. 1 Link to post Share on other sites More sharing options...
Dxyong 3rd Gear November 1, 2016 Share November 1, 2016 Suspect your aircon somehow blowing at that direction...maybe you show us some picture 1 Link to post Share on other sites More sharing options...
Count-Bracula Twincharged November 1, 2016 Share November 1, 2016 Sometimes after the wipers wiped and return, there will be a few patches on the windscreen that is foggy for a few seconds. This is irritating and sometimes block the view on the road. Any idea how to remove that? Also what is a good recommendation to remove fine scratches on the windscreen as well? Used the 3M grey sandpaper thing and resulted in scratches. I encountered this recently too. Damn irritating 'cos cannot see clearly. 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic November 2, 2016 Share November 2, 2016 Isn't it due to the difference in temperature between the outside temperature and the car cabin temperature? Is it fogginf inside the car or outside? Just fiddle with the aircon temperature to get the ideal setting. If fogging from the inside means you got to turn down the temperature. Outside cold, inside warm. What do you think? If fogging on the outside...turn on the de-misting function. Link to post Share on other sites More sharing options...
dcb Turbocharged November 2, 2016 Author Share November 2, 2016 Plan to do so this sat. C L A Y B A R to smoothen your windscreen. Tried mama lemon and doesn't work Those are stains. Try cleaning them with Kao colour bleach undiluted. There is no vent blowing at the windscreen. Suspect your aircon somehow blowing at that direction...maybe you show us some picture Si bei sian right? I encountered this recently too. Damn irritating 'cos cannot see clearly. The thing is the foggy patches stays for a few seconds and then disappear. Isn't it due to the difference in temperature between the outside temperature and the car cabin temperature? Is it fogginf inside the car or outside? Just fiddle with the aircon temperature to get the ideal setting. If fogging from the inside means you got to turn down the temperature. Outside cold, inside warm. What do you think? If fogging on the outside...turn on the de-misting function. Link to post Share on other sites More sharing options...
Watwheels Supersonic November 2, 2016 Share November 2, 2016 The thing is the foggy patches stays for a few seconds and then disappear. Open the windows and stick your head out. Sometimes things like wind deflectors are useful in such scenerios. Off the aircon, open the windows as wide as the wind deflectors allow so that the temperature can equalise and stop the fogging. The rain won't be able to enter too. 2 Link to post Share on other sites More sharing options...
Volvobrick Supersonic November 2, 2016 Share November 2, 2016 The thing is the foggy patches stays for a few seconds and then disappear. Sounds like air con too cold and de-misting vents blowing at the windscreen. 1 Link to post Share on other sites More sharing options...
dcb Turbocharged November 2, 2016 Author Share November 2, 2016 Its not air con. You can see the fog patches after the wiper returns. its just various parts of the higher part of the screen. Sounds like air con too cold and de-misting vents blowing at the windscreen. Link to post Share on other sites More sharing options...
Count-Bracula Twincharged November 2, 2016 Share November 2, 2016 Its not air con. You can see the fog patches after the wiper returns. its just various parts of the higher part of the screen. Ya exactly like what I see, I think I go change wipers this weekend and also get the glaco liquid for the side mirrorsto repel rain water. Link to post Share on other sites More sharing options...
Kb27 Supersonic November 2, 2016 Share November 2, 2016 (edited) Tried mama lemon and doesn't work mama lemon won't remove the stain. Try kao colour bleach, the liquid form. It will remove the stain, but put on gloves, it might bite your hand. Edited November 2, 2016 by Kb27 Link to post Share on other sites More sharing options...
Maddriver 4th Gear November 2, 2016 Share November 2, 2016 Sometimes after the wipers wiped and return, there will be a few patches on the windscreen that is foggy for a few seconds. This is irritating and sometimes block the view on the road. Any idea how to remove that? Also what is a good recommendation to remove fine scratches on the windscreen as well? Used the 3M grey sandpaper thing and resulted in scratches. For the glass scratches, you probably need to use cerium oxide with a buffer.. not easy to polish glass compare to painted surface. 2 Link to post Share on other sites More sharing options...
dcb Turbocharged November 2, 2016 Author Share November 2, 2016 For the glass scratches, you probably need to use cerium oxide with a buffer.. not easy to polish glass compare to painted surface.Sian 1/2 liao. I will live with the scratches. Just wanna rid the irritating foggy patches mama lemon won't remove the stain. Try kao colour bleach, the liquid form. It will remove the stain, but put on gloves, it might bite your hand. Will give it a try Link to post Share on other sites More sharing options...
Hondauto 1st Gear November 4, 2016 Share November 4, 2016 try changing to a better wiper. I used to have that patchy stains on old wipers. The stain went away once i changed to a better wiper. 1 Link to post Share on other sites More sharing options...
dcb Turbocharged November 4, 2016 Author Share November 4, 2016 Just bought a pair of NWB wipers. Hope it works, try changing to a better wiper. I used to have that patchy stains on old wipers. The stain went away once i changed to a better wiper. Link to post Share on other sites More sharing options...
Rollagt 5th Gear November 4, 2016 Share November 4, 2016 Anyone know how to rectify juttering wipers ? Just changed a set of Bosh wipers last week. 1 Link to post Share on other sites More sharing options...
dcb Turbocharged November 5, 2016 Author Share November 5, 2016 The windscreen gotta be free from wax. Use Mama Lemon to clean. Anyone know how to rectify juttering wipers ? Just changed a set of Bosh wipers last week. ↡ Advertisement Link to post Share on other sites More sharing options...
how to remove micro/fine scratches on windscreen
How to remove stubborn stain on windscreen?
Best water repellent
Windscreen crack
Windscreen crack
