Fourwheels Clutched February 18, 2017 Share February 18, 2017 My headlight burnt. Is the following LED H7 bulb approved by LTA? Has anyone try before? Or similar. Thanks ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 18, 2017 Share February 18, 2017 Install than say. 6000k? 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic February 18, 2017 Share February 18, 2017 My headlight burnt. Is the following LED H7 bulb approved by LTA? Has anyone try before? Or similar. Thanks go buy a cheap halogen replacement and keep it with you while changing to this LED bulb. For headlight, LTA mandates that all LED and xenon HEADLIGHTs to be auto leveling, so the answer is no. What you can do is replace back to the halogen ones during inspection. Link to post Share on other sites More sharing options...
Ake109 6th Gear February 19, 2017 Share February 19, 2017 If your stock is halogen, pls don't change to LED. The optics will be screwed up and you will be causing glare to other users. 3 Link to post Share on other sites More sharing options...
Charmaine12 3rd Gear February 19, 2017 Share February 19, 2017 This type is bright but the throw is poor. 1 Link to post Share on other sites More sharing options...
tcwcola Neutral Newbie May 28, 2018 Share May 28, 2018 (edited) To prevent causing glare to other users, the product should be designed with a lens like this one. https://www.amazon.co.uk/SLuFass-Headlight-Bulb-Module1-White/dp/B0791C4HRT But it is currently unavailable.... Edited May 28, 2018 by tcwcola Link to post Share on other sites More sharing options...
Ake109 6th Gear May 28, 2018 Share May 28, 2018 To prevent causing glare to other users, the product should be designed with a lens like this one. https://www.amazon.co.uk/SLuFass-Headlight-Bulb-Module1-White/dp/B0791C4HRT But it is currently unavailable.... Even with the blanked off tips, as long as the LED light source is moved from wherever the stock halogen point is , even if just a few mm, the optics can still be screwed up and cause glare. Link to post Share on other sites More sharing options...
tcwcola Neutral Newbie May 29, 2018 Share May 29, 2018 Even with the blanked off tips, as long as the LED light source is moved from wherever the stock halogen point is , even if just a few mm, the optics can still be screwed up and cause glare. Agree, so I think it is needed to be confirmed further by a professional goniophotometer. The standard should be followed by regulations like ECE R112 in Europe or DOT/SAE in US to make sure the low-beam light pattern is save with no glare, good visibility distance, good road illumination on the road between 25m and 50m, good width of the beam pattern, not too much light on the foreground and enough light on the landscape. The product announced to be certified with ECE R112 that aroused my interest, but again it should be tested by a professional light measurement system. 1 Link to post Share on other sites More sharing options...
davidy2004 May 31, 2018 Share May 31, 2018 Hi: I find new and good item here. www.bpt-shopping.com Link to post Share on other sites More sharing options...
Ka_kia 1st Gear February 11, 2020 Share February 11, 2020 https://www.powerbulbs.com/eu I usually get my bulbs here. Only get halogen cus my car not so high tech use led. Lol. Sufficient nuff and since is using same type "Halogen" to Halogen, no worries with LTA and no need keep change. Just standardize to white color looks okie can already. Link to post Share on other sites More sharing options...
Ronald728 Neutral Newbie July 28, 2021 Share July 28, 2021 I replaced the halogen headlight on my car with LED, and it looked fine. The bulb I use is HYUGA LED headlight U9. Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 28, 2021 Share July 28, 2021 Need not be like MJ. If its yellow, just be yellow. No need to be white to be different. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
New Hyundai Tucson
New Hyundai Tucson
2017 Hyundai i30
2017 Hyundai i30
