JJaassoonn 1st Gear September 25, 2017 Share September 25, 2017 Dear all bro & Sis, Can i still use back my tyre if i had pump in sealant ? hear from some feedback once sealant being pump into tyre, the tyre cannot be use and got to change new tyre. it is true ? ↡ Advertisement Link to post Share on other sites More sharing options...
Doppel Turbocharged September 25, 2017 Share September 25, 2017 Not true. Just go to the tire shop, they would clean out the sealant and carry out a proper tire repair. Caveat applies: if the puncture is in an unrepairable area of the tire, then it cannot be repaired, sealant notwithstanding. 5 Link to post Share on other sites More sharing options...
giraffey99 3rd Gear September 25, 2017 Share September 25, 2017 Once used, have to change tyre Link to post Share on other sites More sharing options...
Mkl22 Twincharged September 25, 2017 Share September 25, 2017 Not true. Just go to the tire shop, they would clean out the sealant and carry out a proper tire repair. Caveat applies: if the puncture is in an unrepairable area of the tire, then it cannot be repaired, sealant notwithstanding. Yes agreed. Tire can be reused. If the sealant can seal then the damage isn’t bad. 2 Link to post Share on other sites More sharing options...
Roberttan 5th Gear September 26, 2017 Share September 26, 2017 it can still be used : Provided is repairable get the shop to remove the sealant + dry + have it properly internal repair the hole remember to re-balance it after remounted if without any marking of original position. any form of external repair is only temporary repair. you have to get it inspect internally for any other damaged which cannot be seen from outside 1 Link to post Share on other sites More sharing options...
BabyBlade Internal Moderator September 26, 2017 Share September 26, 2017 Dear all bro & Sis, Can i still use back my tyre if i had pump in sealant ? hear from some feedback once sealant being pump into tyre, the tyre cannot be use and got to change new tyre. it is true ? From my understanding, there are many types of sealants in the market. Which are you using? For most sealants you have to wash out as soon as you can as the formula will dry out and mess up the wheel after prolonged usage. The puncture that's fixed by the sealant is also not a permanent fix. It may leak again so it's best you drive to your shop to get it permanently sealed. If you're looking for permanent puncture solutions without having to go down to the tyre shop to change a new set of tyres again, and worry about your rims getting damaged, you probably can consider TireCare Sealant. FYI. http://www.sgcarmart.com/news/events_features.php?AID=3371 4 Link to post Share on other sites More sharing options...
Tohto Hypersonic September 27, 2017 Share September 27, 2017 it can still be used : Provided is repairable get the shop to remove the sealant + dry + have it properly internal repair the hole remember to re-balance it after remounted if without any marking of original position. any form of external repair is only temporary repair. you have to get it inspect internally for any other damaged which cannot be seen from outside Talking about internal repair, too many tyre shop are doing the easy way of external repair. Many drivers are not aware of it. Link to post Share on other sites More sharing options...
Roberttan 5th Gear September 28, 2017 Share September 28, 2017 Talking about internal repair, too many tyre shop are doing the easy way of external repair. Many drivers are not aware of it. YES many drivers are not aware of it But some drivers accepted external repair because is cheap and easy and fast. some tire can be salvaged if repaired was done internally some repeat pressure lost can be prevented if repair was done internally some tire burst can be prevented if repaired was done internally Internal repair is not GOD , But at least it help to lower the unnecessary problems to the lowest Good & Cheap & Fast = almost impossible GOOD & CHEAP wont be FAST FAST & GOOD wont be CHEAP CHEAP & FAST wont be GOOD you can only Pick TWO Go for Professional Shop you wont be wrong tires are the only 4 contacts btw your car and road just sharing MHO 2 Link to post Share on other sites More sharing options...
Zzgiggs 1st Gear September 28, 2017 Share September 28, 2017 From my understanding, there are many types of sealants in the market. Which are you using? For most sealants you have to wash out as soon as you can as the formula will dry out and mess up the wheel after prolonged usage. The puncture that's fixed by the sealant is also not a permanent fix. It may leak again so it's best you drive to your shop to get it permanently sealed. If you're looking for permanent puncture solutions without having to go down to the tyre shop to change a new set of tyres again, and worry about your rims getting damaged, you probably can consider TireCare Sealant. FYI. http://www.sgcarmart.com/news/events_features.php?AID=3371 looks interesting, has anyone tried this brand? ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mitsuoka M55
2025 Mitsuoka M55
